I'm working on a theoretical project - don't laugh .. SV1/SV2/AP6 Valiant with 3.5L alloy V8 - and was checking out weights of these vehicles (so I can determine if a 215ci V8 can suitably repower a car originally with a 225ci /6). The MAXIMUM weight I can find for one of these is 1218kg. My rough understanding of modern cars is that a Commodore is roughly 1600kg and a Falcon 1700kg ... so modern cars are carrying 400-500kg more weight than their "family sedan" equivalents of 40years ago and they were ALL steel. So despite all the plastic, aluminimum, CAD/CAM, etc we have to lug around the equivalent of 4-5 fat guys just to get down the shops!
Yes I understand all the benefits of modern cars, and yes this is an overly simplistic view, but what about building a smaller, lighter, 6/V8 powered vehicle? Fourty years ago an average family with three kids would fit in an AP6/EH/XP .. why is it now that anyone with (god forbid!) two kids needs a SUV the size of a Hummer!! |
V8 Powaah
Safety pretty much, reinforced crossmembers, crumple zones and all increased steel reinforcing not to mention stuff likely much larger brakes, tyres, more complicated suspensions, bigger and more complicated motors (no pushrods and EFI), airconditioning, more complicated exhauts power steering, god knows how much electical wiring, stereo's, carpeting/soundproofing not to mention stuff like thicker steel all add up to one heavy car.
I find it a bit dodgy too, but it seems to be the way it is 1.5ton+ cars are going to be the future. As for the 3.5 V8 are you thinking of using the Rover V8, cause that would be certainly interesting. Though if you wanted to try something different you could use the Leyland 4.4V8 (dont know if it fits) or perhaps a more modern 6 cylinder
FG G6E Turbo- Seduce & Cashmere - Sold XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
PHEW, I thought you were taking the pi** out of me :jab:
igodabigblackshinycar and I relented and allowed a BMW into the garage. ![]() |
#4 | |||
![]() Join Date: Dec 2004
215ci V8 would mean less torque for the Val. Personally I'd stick with the six, unless you're after that wonderful exhaust note
![]() lol you know you want the V8 and just want it as a cruiser ;) |
#6 | |||
IWCMOGTVM Club Supporter
Why dont you try to get your hands on a 265 hemi, unless you just want a cruser. A few small mods (tripple webber carbie and exhaust) can give you about 200kW (cant remember if it was at the wheels or flywheel). Also it's one reliable engine. Also as it's a valiant motor you should have less hassles implementing it. |
LPG > You
I say go for the Rover 215. Its something different... and its a very good engine. They get plenty of power out of them in the UK, and its got some interchangeable bits with the SBC (cyl heads for example... so you can put AFRs on it :evil3: )
LPG Lovers Association President & Member #1. ![]() ![]() |
they extra weights in safety as stated above. It's also in sound proofing and rust proofing ;)
If your keen on staying with a 6cyl. CHI makes these ![]() Flow chart comparisons here -> http://www.chiheads.com/heads_04.html#
74 XB Fairmont (street car) 11.07@123.02mph. 08 LV Ford Focus XR5 (daily). Tuned by Hallam Performance |
Yeah but fuel economy is better, can we really complain?
While I'm annoying people with an O/Tish subject .. does anyone know if a RoverV8 still uses the original Buick/Oldsmobile/Pontiac trans boltpattern of the "original" 215ci? ... O/D auto anyone? [ the 3.8LV6 holden is a derivative of this engine ]
The car's got pickup
Yep, new cars are heavy - our ZC with Alloy Head II, Air, Stereo, 850 litre boot etc is only 1450kg.....
Gets 11l/100km fully loaded with two adults and a baby and all their gear (boot full and passenger side of rear seat stacked with bags). That will improve to sub 10l/100km with 205/65R15 tyres instead of the 215/65R14 tyres... |
#12 | |||
A.k.a wolf159
Sorry if I went a little off topic there, but stick with the 225 if you can they are a beast of a motor with more torque than you can shake a stick at, might be a bit thirsty though. |
#13 | ||
The Rover 3.5 is a good motor,i was building a hot rod from a '49 Vauxhall Velox with LJ Torana front end and diff with a Rover V8,and from memory the motor was about the same weight as a Holden 6(?). But inthe Val it would be pretty gutless,as they (Rover V8's) could hardly pull the Rover they came from. BTY a Slant 6 weighs 525lbs, approx.239kg. Try the Toyota or Nissan alloy Hemi's??
#14 | |||
#15 | |||
