Rob
Hey guys,
What spark plugs do you recommend using, due for some new ones car is I6 auto. Any links . prices would be good too thanks.
99 liquid silver AU Classic -Sold
Supercharged Nissan 350z 280rwkw Blueprint series 3 AU V8 manual |
i just stick with the iridiums , good for 150,000kms , so they say ,dont know if there are any advantage's using others on the intech , correct me if im wrong.
unless your motor has had a lot of work done to it , even then im unsure 03/00 - 06/03 FORD Fairlane AUII, AUIII 4.0L 6 Cyl., HP, VCT NGK- Spark Plug Part No. Recommended Plug IGR5C13 - Plug Gap 1.3 supercheap seem to be the cheapest around the $20 ea mark
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak! AU SERIES 3 LIQUID SILVER BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS 123.4 GROUND TEARING RWKW'S , LOL |
Flairs - Truckers Delight
BPR5EY-11's
i put them in mine, made my car worth even more than $9k
ahhhhh ha ha ha , then mine must be worth $9500, cause iridiums are dearer , more goodara.
#5 | |||
Rob
My car will be a bargain then ![]()
#6 | |||
EACH $4.50 Notify me when on SpecialAdd to wishlistSend to a FriendShare on FacebookPrint page Click here to find your nearest store Shipping is calculated through checkout. Please check store for availability if picking up. Enlarge image 8894 Be first to rate View ratings / reviews Add to Cart a bit dear me thinks
Rob
yep.
only $4.50 not 450 lol
#8 | |||
$2 each
Rob
Thanks sleeper =)
Will buy them now.
#10 | |||
use the same as Mr Hardware, mated with some Bosch Motorsport leads
will different plugs make any difference to engine performance , smoother , better fuel eco , etc , etc ? ? ? , im running bosch motorsport leads and iridiums,
#13 | ||
Autolite 985 S/Plugs, these are the one that jmm uses , whether that make a difference ???????????????
#14 | |||
Just slidin'
Pretty much no. Just buy cheap ones and be done with it.
MD Mondeo - For the family
#15 | ||
Rob
Yea, there's some that can cost upward of $20.. they all do the same job, they may last a little longer.. but is it really worth it. Id rather pay $12 for 6 ... then $12 for 1.
If i cant get what i want for the car, ill prob do the leads and coilpack to.. Iv heard Eagle leads or something thrown around a bit.. thoughts on leads?
#16 | |||
#17 | |||
apparently top gun leads arent too bad, might plan on getting some within the next week as my current motorcraft ones are most likely gone (spark plugs were replaced at service just not the leads)
anyone recommend anything?
Daily: 2003 BA Fairmont Ghia - Mercury Silver | Sunroof | Tint | XR6T 3.46 LSD Project: 2001 AU II Fairmont Silhouette | Optioned 17" Tickford wheels + Sports suspension | Tint Weekender: 1989 NA II Fairlane - Rosewood | Standard (with functioning SLS!) Quote:
#18 | ||
as XR-CHIEF said bosch motorsport leads are the good stuff , iv'e got em on mine they are top quality , and look the bizz too !!!
[IMG] ![]()
#19 | ||
I was under the impression iridium plugs were a waste without thicker leads. Oh and you can't go wrong with the genuine leads
Current Blueprint 03 xr8 ![]() 5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives 256rwkw ![]() ![]() BA manual Typhoon Fully optioned, 340rwkw@16psi (thanks Bluepower)! The old ride.... AU Fairmont, cammed beast, R.I.P you made my p plate years bearable! 150.8rwkw courtesy BPR |
#20 | ||
Rob
Ford would charge what.. 3 times the amount then after market tho??
#21 | ||
Not sure I got mine at an average price just over 100 I believe but that was through the mechanic that put them on
#22 | ||
I paid 80 odd from supercheap for the bosch motorsports, the standard bosch leads are around $60 from memory. As sleeper said they look pretty good and are top quality
#23 | ||
rexnet
yeah i got the blue bosh motorsport leads. worth the $80 for the pretty blue. although i did notice it ran a bit crisper when i put them on. weather my old standard bosch leads where dead. im not sure.
Idrinium plugs are pretty expensive tho |
#24 | ||
Teh Baest
I also have the blue bosch leads. Good stuff and look awesome. Would look great with the blue silicone hoses too.
I have the regular NGK plugs, seem good enough. I just cant warrant spending $15 per plug
1999 Liquid Silver AU Show: XR6 Kit, Low, RDA Slotted's F&B, Fully Tabouli Sound System, Altezza Tailights (Good ones!) Go: K&N Pod w/ 3" intake, XR6T Snorkel, Pacie Comp 4480's, 2.5" Cat Back, CMS Stg2 Cam, Custom Tune, Tranny Cooler Coming..CMS Stg2A Cam, 68mm TB Later.. 4.5L w/ BOOOOOOOOOOST or XR6T or AUIII XR8 220 Currently: 151kW (165 on other dynos ![]() |
#25 | ||
Rob
alright thanks for the help guys,
NGK plugs in when they come, and then depending if car sells, might get some bosch leads
#26 | |||
just picked up some bosch motorsports from super cheap today, $79.99 better be worth it from what you guys say :P im too lazy to put them in though haha ill get around to it eventually
#27 | |||
T3/Sprint8
![]() Join Date: Jan 2005
Better price than ngk bosch etc bonus !
#28 | ||
I just bought some NGKs from Auto one, Cost me $27, for 6 plugs,
They seem to do the job pretty well seeing though i was running the orignal plugs on that engine i bought, man were they rooted,
Welder/Fabricator at Beaudesert Exhuast Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors |
#29 | ||
rexnet
yeah old thread i no. but the the bosch motorsport plugs 8,9 or 10 mm leads? i've look and cant find anything
