Old 03-04-2010, 10:26 AM   #1
ebxr8240
Performance moderator
ebxr8240's Avatar
Default Ford Designing a Laser Ignition System
This could be added to direct injection engines..
Ford is teaming up with the University of Liverpool to design a laser ignition system for automotive engines. According to the university’s web site, a fiber-optic cable will shoot the laser beam to a focusing lens that would create an intense pinprick of light. As fuel is injected into the engine, the laser is fired and produces enough heat to ignite the fuel.
University researchers claim that the new technology is more reliable and efficient than current spark plug technology. Although the laser will need to fire more than 50 times per second at 3000 rpm, it will require less power than current spark plugs. The lasers can also reflect back from inside the cylinders to relay information based on fuel type used and the level of ignition, enabling the control unit to readjust the quantities of air and fuel for optimum performance.
The lasers can be focused and split into multiple beams to give multiple ignition points, which give a far better chance of ignition and can really improve the performance of the engine when it is cold; a time when around 80 per cent of the exhaust emissions are produced and the engine is at is least efficient. The laser also produces more stable combustion so you need to put less fuel into the cylinder.
Ford said that it plans to implement the new technology into its top of the range vehicles within the next few years, and then make the laser ignition system available for its remaining models sometime thereafter.
Other advantages of laser ignition include:
§ Choice of ignition location and potential variation within a cylinder.
§ Non-invasive, there are no electrodes which can disturb the cylinder geometry and can quench a propagating flame kernel.
§ Possibility of varying ignition energy for engine control.
§ Multiple ignition positions in a cylinder.
§ Lower ignition energies needed for combustion.
§ More stable combustion and increased engine performance.
§ Reduced tailpipe emissions.
§ Combustion of leaner air-fuel mixtures.
§ Shorter ignition delays and faster combustion duration.
Daily driver GTE FG..
Old 03-04-2010, 10:29 AM   #2
mick457
mick457's Avatar
im my opinion just something eles that can go wrong
my build thread
Performace
DBA 4000s, Blue power intake, Whiteline swaybars, FG manifold, PWR Radiator, king springs low, Monroe gt sport
DJR bobtail, LSD 3.46, 20%UD
Pacemaker 4490s, Venom cat, redback catback
mick457 is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2010, 10:34 AM   #3
wulos
Forum Director
wulos's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: All the behind-the-scenes effort. Technical Contributor: For members who share their technical expertise. - Issue reason: For his advice, tips/tricks in the Art and Photography section of the Forum.
Some interesting tech there - certainly appears to have the potential for some interesting times ahead.
Like everything, there is the potential for failure, but if we didn't try something new, we'd all still be living in caves, & walking around on foot...
wulos is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2010, 10:34 AM   #4
BOSHOG
avenge me
BOSHOG's Avatar
sounds expensive
FULL OF Autotech GOODNESS!
BOSHOG is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2010, 10:40 AM   #5
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
http://fordforums.com.au/showthread.php?t=11269959
Falcon Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2010, 10:42 AM   #6
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Or my original thread:
http://www.fordforums.com.au/showthread.php?t=11266723
Old 03-04-2010, 12:32 PM   #7
Franco Cozzo
Franco Cozzo's Avatar
Indeed, but if we stuck to that mentality we'd be crusing around in Ford Model Ts.
Old 03-04-2010, 02:46 PM   #8
barra265t
Haha, they should bring back the Ford Laser, this time the name would actually mean something
barra265t is offline   Reply With Quote Multi-Quote with this Post
