Really need the torque setting for a 2LTR fly wheel to crank
pressure plate to flywheel I have searched the net and found nothing So if someone can pull out the Gregorys manual and help us out the would sweet as ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
tufLTD
Are you using standard bolts?
If so, flywheel bolt torque is 75 ft/lbs, pressure plate bolts 15 - 20 ft/lbs. I always use something like Loctite 242 medium strength on flywheel bolts. |
Cheers big help if I cant find that book i may need a few more later on
Any one got the the head torque settings
75 ft\lbs is what i've always done them too. Your gasket set should tell you the tension, but usually its a broad spread.
When the flag drops... The bullsh!t stops... |
