Old 05-07-2009, 11:59 PM   #1
race-van
Default Escort 2 Litre Questions...
I have been sourcing parts for my MK2 escort 2 Litre project for about a year now and I have found the engines called a few different names so here is I know are stupid qustions but I need help...
Is the 2L in the MK2 escort a PINTO?
Is there such a thing as a long and short version of this engine?
What is the differnce between the everyday 2L and the RS2000 engine?
And I also have some gearbox questions...
Does the 5 speed cortina box just bolt straight in?
If not is there a 5 speed out there that does?
I look forward to your response...
Thanks heaps....
race-van is offline   Reply With Quote Multi-Quote with this Post
Old 06-07-2009, 12:16 AM   #2
rag top
rag top's Avatar
2L escort motor is also referred to as a Pinto.
Aussie 2L RS2000 motor and the everyday 2L motor are the same; German RS2000 engines had some differences (carb/exhaust, etc).
AFAIK cortina's had the 4sp; The sierra 5sp would go close to bolting straight in.
Old 06-07-2009, 12:05 PM   #3
JamesR
Thanks heaps....
the 2ltr is a Pinto. but some people have been using Zetec/ Duratec engines, which can come as 2lts, but completely different.
"long" just means a complete engine- head and block etc.
"short" just means a block, no head.
as for 5 speeds, as said above, a Sierra box will bolt straight up, but the gearbox tunnel will need enlarging, unless the car was previously an Auto.
other popular choices include the Celica box, but not sure what needs to be done to mount that up.
1977 MkII Escort Ghia.
2006 MY07 Subaru Liberty GT Spec B wagon.
my photo blog;
http://www.jamesruff.net
JamesR is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2009, 11:39 PM   #4
esci-fan
[/QUOTE] as for 5 speeds, as said above, a Sierra box will bolt straight up, but the gearbox tunnel will need enlarging, unless the car was previously an Auto.
other popular choices include the Celica box, but not sure what needs to be done to mount that up.[/QUOTE]
My Mk 2 (which I am yet to get on the road) has an auto tunnel with a 2ltr in it but with the standard 4 speed fitted. If i was to fit a five speed would the Sierra be the easiest and cheapest, I have heard that the earlier sierra 5 speed (type 9 i think) will bolt straight up, Is this the case or is there any modification to the gearbox mount or gear lever slot in the tunnel? I have heard the Celica ones are good but can be expensive to make fit?
esci-fan is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2009, 09:57 AM   #5
tufLTD
tufLTD
tufLTD's Avatar
[/QUOTE]My Mk 2 (which I am yet to get on the road) has an auto tunnel with a 2ltr in it but with the standard 4 speed fitted. If i was to fit a five speed would the Sierra be the easiest and cheapest, I have heard that the earlier sierra 5 speed (type 9 i think) will bolt straight up, Is this the case or is there any modification to the gearbox mount or gear lever slot in the tunnel? I have heard the Celica ones are good but can be expensive to make fit?[/QUOTE]
The Sierra 5 speed will bolt straight up but the gear lever is about 2 inches further back than the 4 speed. You will need to cut a new hole in the trans tunnel.
tufLTD is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2009, 10:01 AM   #6
tufLTD
tufLTD
tufLTD's Avatar
There are several 2ltr motors. The best is the 105 block which has more webbing around the crankcase area. It also has better quality crank & rods. Definitely the best choice if you're going to modify the engine. You can pick these engines up pretty cheap, around $1500 complete with EFI.
Old 12-07-2009, 02:00 PM   #7
mickas
I thought it was a 205 block. 200 blocks are better but $$ a rare...
Standard block are fine to a certain degree unless boosting and racing....
mickas is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2009, 09:15 PM   #8
cram72
The easiest way to put the five speed in is to remove the gearbox mounts from the body. Using the standard gearbox mount, cross drill it, ie widen the holes allowing sideways movement, bolt the body gearbox mounts to the gearbox mount, adjust em, tech screw em on the tunnel and then weld them. Once finished machine four times spacers to allow for the different ride height and hey presto she's in. Simple to just reposition the selector hole. I can take some pictures of mine if that helps. This method gets around lowering blocks and is a damn lot tidier.
cram72 is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2009, 02:57 PM   #9
race-van
Thanks everybody for the help it makes things alot clearer....
Sorry for delayed response my computer spun a bearing...
Any other advice would be apreciated....
Old 18-07-2009, 03:06 PM   #10
race-van
While I am asking stupid questions where is the best place to find the Sierra five speed?
