you'd be popular too
Hey guys,
Where would the best place to ask (if not here) for the spec's on the 220kw cam? Thanks Al |
Falcon, Fairlane, Mustang 302, 351from 1991
Hydraulic Roller Camshafts (Not suitable for non roller blocks) With 1.62:1 rocker ratio PART NO. VALVE TIMING DUR .050" DUR. L/C VALVE LIFT POWER RANGE PART KIT COMMENTS 62952 IN. 16/60 EX.60/16 260 260 198 198 117 .455" .455" 1000 4500 K6201 Standard replacement roller hydraulic cam 621339 IN. 16/72 EX.75/20 268 275 203 209 118 .455" .455" 1500 5000 K6201 Mild cam for near stock engines. Also ideal for supercharger applications *** 621338 IN. 18/74 EX.74/18 272 272 210 210 118 .458" .458" 1600 5200 K6201 Mild touring cam. 6213711,2,a IN. 29/77 EX.79/27 286 286 216 216 115 .505" .505" 1800 5800 K6202 Medium performance cam for auto trans cars 6213171,2,a IN. 26/64 EX.66/24 287 279 222 217 112 .538" .538" 2500 6500 K6202 Medium cam for manual trans. 6213541,2,a IN. 31/77 EX.81/27 288 288 222 222 115 .510" .510" 2700 6700 K6202 High performance cam for manual trans. Thats the EFI windsor range, im pretty sure it's the (mild touring cam profile.) Last edited by dreadly; 15-06-2009 at 08:08 PM. |
Gimme Shelter
ring crow cams and ask for Johnny Marshall, those guys spent a fair whack of time developing that cam for the AU (if that's what asking about).
He'll have all the time in the world for you. promise. |
#4 | |||
Boost is here!!
To clear the specs up they are. Duration @ .050" = In. 203deg, Ex. 209deg. Valve lift (1.6 rockers) = In. .455", Ex. .455" LSA = 118deg Now im pretty sure that lift spec is with 1.6 rockers which would make lift with 1.7's .483". Now to go off the subject here i'd say the 200kw AU XR8 engines must have had 1.7 rockers aswell, which is what alot of people have found.
STREETBUILT RACING '99 XHII XR8, 363w, GT4508R on 16psi, E85, C4, 910rwhp - ET coming soon! '78 XC Falcon 500, Desert Gold, 351w, V2 on 16psi, E85, C4, 9" - 10.15@132mph! |
#5 | |||
Sweet as jeff, ;) But wasnt the 200kw more aggressive because it only had the 1.6 RR's And the 220kw got 1.72's and head porting by yella terra? |
#6 | |||
Made the 300 :0)
New Owner of a fiesta ST |
With da Warlords
220kw cam specs are as follows;
Cam; specs 220 intake valve timing 16/72 .050" 203 vale lift .477" exhaust v/t 75/20 .050" 209 valve lift .477" Rocker ratio 1.7.1
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 ![]() ![]() XR50T Ute - 300rwkw (give or take depending on the day)
#8 | |||
yeah but everyone thinks the cranecam rollers are 1.6, when they were 1.7's. According to yellow terra the change over was purely due to a reliability issue with the crane "cobra" rockers whereby the roller tip pin slides out cause they never had a circlip grove cut in them, i have had this happen on 2 of the AU 200kw crane roller rockers i have, and i have checked the part number with crane and they are listed as 1.7's.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm. |
Boost is here!!
Yeah thats what i was thinking, they HAD to be 1.7's, the lift with 1.6's is just too small.
Dont worry about the cranes only mate, you should see the Yella Terras from the 220's after 150,000kms aswell, not a pretty sight.
#11 | |||
Originally Posted by XH5LWEPN
AUII XR8 ute, Manual, Powerdyne supercharger, 1.72 roller rockers, Herrod exh, Herrod brake kit. T3 TS50 #25. Manual, Narooma Blue. |
