Lil Henry
Why do they make it so difficult to Change the bulbs in a headlight. you needs security screws to be removed the front grill to remove then the whole light assemblly before unscrewing a cap to put in a new bulb. the back ones are abour the same. thats just crap!
It's not that bad, only a few torx screws. I takes under 2mins to get both lights if need be. IF you've got a torx set of course ;-)
2004 Fiesta Zetec Colorado Red Elbach Lowered Coils - Rear sway bar - 12.5mm Axle Spacers - Rear disc brake conversion - 16" MP3 Rims Tinted windows - Tinted Headlight surrounds - Clear side indicators- Phillips Xenon lighting - Colour Coded - ST Rear Spoiler - Smooth Rear Wiper - Ford leather gear knob & boot – Zetec S Sill Covers & Steering wheel - Leather centre armrest - Pioneer USB/CD player - JL Audio 4ch Amp, subwoofer & splits - Short aerial The most "Standard" car I've ever owned!
Its not so bad. Torx sets are cheap and torx fasteners are used on so many cars now you may as well grab a set.
At least you don't have to take the headlight out to check the power steering fluid like in our LS Focus ;)
Current Rides: 2012 KK Jeep Cherokee Limited CRD - Still going strong 2019 MG ZS Essence 1988 RD Mitsubishi Colt GL - 59kW of Fury 2022 Kia Stinger GT |
Yeah, they could of made it a little easyer. Since we are on the head light topic. I have been trying to find the manual adjustment for the head lights but i cant find it. The adjuster in the car doesnt tilt the headlights up enough. At night I have almost hit some debris on the road because the lights are not tilted up enough. can any one help me out with this one
Thanx |
Get in the van!
The adjuster should be on the same panel as your headlight switch. Have it set to 0 for the greatest distance.
The Dad Bus (TM): 2004 BA XT Wagon, soon to be set up as a camper and tourer. |
#6 | |||
There are two of them per head light and they are cream coloured. There is one for the left/right adjustment and the other is for the up/down. They are located on the lower leading edge and rear upper of each unit and are fairly accessible. Just need to get an 8mm (or 10mm cant remember) allen key to turn them, though you can almost just use your fingers. Turn the headlights on to make it easier to tell how your doing and if you get stuck let me know and I'll try take a pic of the adjusters.
GGR | SCT | Tein | Samco | Whiteline | Mongoose | Forge
Thanks for you help every body. I found them, I should of looked a bit harder, they were looking straight at me. No more hitting things on the road and also it makes it handy to get those annoying people that have there head lights tilted to high with the tilt adjusment in the FEZ.
