02-10-2008, 08:47 PM | #1 | ||
Hey guys i got a relatively new ford focus LS LX 2006 model. I need to do a oil change, and i need to know what oil to use and plus what coolant to change also.
02-10-2008, 09:46 PM | #2 | ||
Canola oil, and not that cheap home brand stuff either....
5W30/40 Castrol edge... go all out. Any green coolant. |
02-10-2008, 11:27 PM | #3 | ||
2007 Ford Focus Zetec
If your vehicle came with Red coolant from factory, stick to that.
Nulon Red Long Life Top-Up Coolant which comes pre-diluted. If you ever decide to sell your focus, buyers will pick this up straight away and think you've had some sort of cooling issue. |
03-10-2008, 01:34 AM | #4 | ||
yum
Focus waterpumps are pretty particular on the coolant concentrate. You'll end up with a noisy waterpump if its not at the correct ratio. So just don't dilute whats already in there with plain water.
2005 LS Focus LX
Nov05 | Manual | Black Sapphire 250,000kms. |
03-10-2008, 10:10 AM | #5 | ||
I would stick the Ford brand coolant. In my Focus I did a radiator flush with it, and had no complaints with it. But I agree stick to the red coolant
2015 MK7 VW GOLF GTI __________________
Previous Cars 2002 AUIII XR6 1995 EF Falcon XR6 2003 LR Focus Zetec 1989 KE Laser TX3 |
03-10-2008, 12:09 PM | #6 | ||
Badly Focused
I'd use ONLY the factory coolant, unless you're going to do a complete flush and change...as far as oil goes, a good brand with the correct specs for the car. Out of curiosity, why aren't you getting it serviced by a mechanic? Doing it yourself will void the warranty...
-RM.
07 LT CL, CAI, timing, XR5 springs, LS Zetec wheels 16.045...0.05 of a second! I wanted a 15sec pass! 93 GSR/Evo3...too much to mention, 12.2sec 1/4, FOR SALE! *Maybe we don't try putting holes in things that sink, yeah?* |
03-10-2008, 02:41 PM | #7 | ||
haha canola oil, good 1. I'll get that castrol edge stuff tho, but the coolant has
got the factory red coolant, but I dont know what it's called and where to get it from. The green colant probably wouldnt be much difference, same stuff anyway right? (If i did a flush) |
03-10-2008, 03:08 PM | #8 | ||
Badly Focused
The colour is a bit of a scam, it started with the Toyota Red coolant (which is awesome), and now most manufacturers are making a red one, but it's often the same stuff with different dye in it. The coolant DOES make a difference, and with the complexity of modern alloys in engines you have to make sure you get a compatible coolant. For the cost of doing it, and for such a rare occurence, I'd just get the proper stuff. No-one minds spending big $$$ on oil (which is done every 10k), but then buys crappy $10 coolant. Oil keeps things slippery, coolant stops the whole lot welding itself into a nice anchor. And the genuine coolant is probably good for 50,000+km...
-RM.
03-10-2008, 03:35 PM | #9 | ||
Motorsport Guru
Quote: "Focus waterpumps are pretty particular on the coolant concentrate. You'll end up with a noisy water pump if its not the correct ratio".
Would this also apply to Focus LR models?
Interior Enhancements: Footwell Lighting, Brushed Alum. H/brake Handle, 6 Disc In-Dash System. Exterior Enhancements: ST170 Wheels, Richbrook Shorty Aerial, Euro-Spec Hatch Handle. Performance Enhancements: Ate Callipers/EBC Rotors/EBC Greens Stuff Pads, ST170 Suspension, Herrod's Custom Tune, Ford Racing Coated Exhaust Manifold & Bespoke 2.25in Exhaust. Awards: AFD '07 EFOC Best Focus, SFS '09 EFOC Best Focus, SFS '10 RSOC O/all Best Focus, AFD '10 CFC O/all Best Focus. |
03-10-2008, 04:05 PM | #10 | ||
Badly Focused
Most likely...modern engines and modern alloys are very touchy...
-RM.
03-10-2008, 04:17 PM | #11 | ||
yum
Eddie, As far as I know only the Duratecs. Apparently there's very tight tolerances in the LS waterpump, and uses the coolant to lubricate itself. That's the spiel Ford gave me anyway. The word "viscosity" was used a lot.
2005 LS Focus LX
03-10-2008, 04:21 PM | #12 | ||
Old enough to know better
Stick with the factory coolant.
Don't use Castrol Edge. Use a real synthetic. Mobil1. Or Motul 300v Power Racing (Sorry...was that a bit direct??) :monkes:
03-10-2008, 04:30 PM | #13 | ||
yum
I've swap between Castrol Edge and Fuchs 5w-30. Every now and then put some Lucas oil stabiliser.
2005 LS Focus LX
03-10-2008, 05:15 PM | #14 | ||
Badly Focused
They're all good oils, but in a standard car, almost pointless. If factory standard mineral oil can do 15,000km to a service, then a good synthetic can do 30+, but who's going to leave an oil change that long? 'proper' synthetics are made from a pure polymer, like BelRay synth or Redline oils, most others are a mix of pure synthetic polymers and refined mineral oils (yep, refined mineral oils class as synthetic after a point), and Magnatec for example is about 2% polymer based synthetics (hence the 'magnetic' effect).
Oils are very, very complicated, and there's a lot of money in advertising them...so be careful you're buying a good oil, and not an expensive advertisment. -RM.
03-10-2008, 05:20 PM | #15 | ||
Badly Focused
Oh....and on a side note, you can use motorbike oil in a car engine, but not the other way around. The difference between the two is that motorbike oils have stabilisers to stop the oil shearing between the gears in the gearbox (because bikes share a common oil)
-RM.
03-10-2008, 07:52 PM | #16 | |||
This is a pet subject of mine : My wifes Audi A4 recently had the cylinder head overhauled by an Audi specialist (there was an unexplained oil leak at the rear of the cylinder head). The car has over 100,000km on it and I bought it new. He discovered that a bypass valve had not been installed at the factory, and it's whole life the oil has been bypassing the oil filter!!! The mechanic was horrified. He was then further amazed however. In his words, "he had never seen an A4 engine in such pristine condition". He told me..."no I'm serious. I pull these down all the time, and this is the best condition I've ever seen an A4 engine in. It looks virtually brand new. I don't get it" 100,000km with the oil bypassing the oil filter, yet the engine in as new condition. It should be stuffed. But it's not Why? The engine has only used Mobil 1 since its very first oil change. It was the only thing protecting the engine So don't tell me that good oil is pointless. We pay $80 for a tank of fuel that lasts a week. Yet begrudge $80 for a top quality oil that protects your engine month after month after month, no matter what you throw at it. Oils ain't oils. And Mobil 1 is vastly superior to Castrol Edge, and Motul superior again (Double ester synthetic) You get what you pay for, and it's the cheapest insurance you'll ever get
03-10-2008, 10:24 PM | #17 | ||
Badly Focused
Noooo, don't take me the wrong way on this...good oil is VERY important, as is the correct grade oils for the engine. I'll never dispute that. I'm just saying that you have to be sure you're getting what you're paying for...your experience sounds similar to mine, I ran my MR2 on BelRay semi-synth from when I got it (90,000km) to 160k and when I pulled the motor down at 160k the hone marks were still clearly visible in the bores. The oil was changed every 10,000km, the engine was reguarly used in competition, redlined at 8,000 and suffered 14psi of supercharged air everyday. After the first couple of changes, the oil came out in almost the same condition it went in...and kudos to Toyota for that motor, it was TOUGH.
-RM.
04-10-2008, 08:36 AM | #18 | |||
04-10-2008, 02:20 PM | #19 | |||
I have done both water and oil, never voided any warranty. |
04-10-2008, 06:15 PM | #20 | ||
ALright thanks for all ur help guys, much appreciated!
10-10-2008, 12:56 PM | #21 | ||
How about Nulon engin oil (5w-30)? did anyone try that?
10-10-2008, 06:22 PM | #22 | |||
11-10-2008, 03:39 AM | #23 | ||
yum
No doubt better than what's coming out of the big 44gal drums at the dealers.
2005 LS Focus LX
13-10-2008, 01:05 PM | #24 | ||
Yesterday, I tried some Mobil 1, the car runs smoother than before (I used castrol edge sport before)
