Old 05-08-2008, 12:48 PM   #1
AnthonyTDCi
Focus TDCi
AnthonyTDCi's Avatar
Default quick question
quick question guys... my TDCi has 20k on the clock and i need to top up my coolant resivoir. can i buy coolant from autobarn or somewhere or do i need to buy stuff from Ford???
anthony
AnthonyTDCi is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2008, 12:51 PM   #2
Turbodiesel
Torquer
Turbodiesel's Avatar
I'm not sure myself as I haven't had to touch anything since I bought the car, why is your coolant low?
2007 LT Focus TDCi S
Bluefin Remap - K&N Apollo CAI - 2.5" Turbo-back Straight Pipe - 24mm Rear Sway bar - LT Zetec Bodykit - Black Projector Head Lights - LED Tail lights - DMB Overlays - Alloy Pedals - Scuff Plates - Sports Gear Knob - LV XR5 Springs - LV XR5 Wheels - Pirelli P-Zero Nero
Turbodiesel is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2008, 02:21 PM   #3
melbzetec
Old enough to know better
melbzetec's Avatar
I'd get the Ford stuff. You have to be really careful mixing different colours etc. The Ford stuff is not that expensive
Old 05-08-2008, 02:26 PM   #4
WindsorXR
FGII XR6, Focus Sport, XR
WindsorXR's Avatar
Sometimes if you mix different coolants then it'll start to go jelly like and clog up your radiator and will be damn annoying to flush out.
If it just needs a minor top up just use a bit of water. It should be at about a 33% coolant and 67%water, but it's only a rough estimate.
How far below the low line is it??
Living Ford dreams
2011 Purple FGII XR6
2016 LZ Focus Sport
BA XR8 Build Thread (SOLD)
1966 XR Falcon Build Thread
WindsorXR is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2008, 09:59 PM   #5
AnthonyTDCi
Focus TDCi
its only just under the min mark. checked it while the engine was cold and also hot. i know not to mix colours... ill pop into ford tomorrow and pick some up.
Old 05-08-2008, 10:40 PM   #6
Mullett
Badly Focused
Mullett's Avatar
either use ford coolant or top it up with DISTILLED water, NEVER mix coolants...if you need to change coolant, flush the system totally...
RM
07 LT CL, CAI, timing, XR5 springs, LS Zetec wheels
16.045...0.05 of a second! I wanted a 15sec pass!
93 GSR/Evo3...too much to mention, 12.2sec 1/4, FOR SALE!
*Maybe we don't try putting holes in things that sink, yeah?*
Mullett is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2008, 11:41 PM   #7
AnthonyTDCi
Focus TDCi
Yeah its only a top up...not a change.
thanks for your help guys
anthony
Old 06-08-2008, 11:00 AM   #8
BlackLS
yum
RM
For those with petrol LS's they are really sensitive to coolant visocity, as the coolant lubricates the waterpump. If you get too weak of a coolant to water ratio, you'll get noise from the waterpump pully.
2005 LS Focus LX
Nov05 | Manual | Black Sapphire
250,000kms.
BlackLS is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2008, 06:58 PM   #9
AnthonyTDCi
Focus TDCi
Does this apply with the TDCi?
Old 07-08-2008, 12:09 AM   #10
AnthonyTDCi
Focus TDCi
ok got some coolant from Ford today.....1lt bottle was $41.... not happy about that but meh
bottle says to top up mix 10% concentrate to 90% water (im guessing)...can anyone confirm this seeing as BSSXR8 said about 33%...which i have always done with other cars?
Old 07-08-2008, 12:54 AM   #11
BlackLS
yum
Check the specs section of the owners manual.
2005 LS Focus LX
250,000kms.
Old 07-08-2008, 04:42 PM   #12
AnthonyTDCi
Focus TDCi
ok...after a bit of reading...and a few calls to other ford dealers....turns out the dealer i went to sold me R150...which is a corrosion inhibitor that gets added to the cooling system. the other dealers said i need R152...which is correct after looking in the manual.
the service manager said that the difference in code is only because of the different size bottles the coolant is available in :
i called the dealer today and after about 30mins of arguing with them they still did not admit they sold the wrong stuff to me.
Old 09-08-2008, 10:55 AM   #13
blue_focus
Ford can never be wrong lol.. I noticed that my coolent kept droping slowly and I was constantly filling it up. Turned out that i had a leak in my radiator. Bloody FOCUS!!
blue_focus is offline   Reply With Quote Multi-Quote with this Post
