Old 28-05-2008, 06:45 PM   #1
OJ_Pursuit
OJ_Pursuit's Avatar
Default Drag rim/tyre combo for BA ute?
G'day people,
My question is for the drag racers out there.
What wheel and tyre combo do you use when your at the track in your BA ute?
Mine has the standard GT brakes (Mark II) which are blue front and rear.
I was thinking drag radials on stock steel rims but I dont know what fits or what sizes are available.
Thanks
Travis
2004 BA MKII FPV Pursuit 6sp manual in Mandarin
MMR Built short motor, all the good gear.
Kenne Bell 2.6 intercooled kit from BPR
Tuned by Xtreme Ford Tuning - 400rwkw
Build thread here
OJ_Pursuit is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2008, 09:06 PM   #2
Quadcams
Quadcams's Avatar
Location: Working, chasing after my daughter and working
Originally Posted by OJ_Pursuit
G'day people,
Thanks
Travis
I think the only size that will fit over your brakes is 17' rims, get your self some second hand 17" rims preferalably alloys and tyres you can get MT streets in 275/50/17 (Rocket Industries sells them), there are a few other tyres you can use but they are proberly the best priced.
Quadcams is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2008, 09:11 PM   #3
atec77
G'day people,
Thanks
Travis
you need to find the smallest rim that will fit over the brakes , then find a tyre size that will compliment the diff ratio with the tallest sidewalls you can get so they bag and grab . easy huh
atec77 is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2008, 04:31 PM   #4
OJ_Pursuit
OJ_Pursuit's Avatar
OK Cheers for that info, btw do you reckon the stock clutch would be ok for a few runs, or would I be better off fitting a better clutch when using drag rubber?
Thanks
Travis
Build thread here
Old 29-05-2008, 07:28 PM   #5
Quadcams
Quadcams's Avatar
Thanks
Travis
When I had MT streets I had a better clutch than std, as soon as I changed my diff gears too 4:1's the clutch went up in smoke so I wouldnt think the factory clutch would last to long with some good rubber like the MT's, also to get a good launch out of a manual you need to slip it off the line, do that to the factory clutch and it will die real quick, the factory clutch's run a organic disc which dont like heat, the more heat the more they will slip, get them to hot and you glase the flywheel/pressure plate and its cactus.
From my experiances the best clutch for the strip is the Textralia Z grip, still has good street manners but can handle alot of punshiment at the strip, so yeh it would proberly be a good idea to upgrade the clutch before you head out.
Old 29-05-2008, 07:42 PM   #6
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
with the standard brakes you can fit a 16" wheel over them
Pit Lane Performance
20 Rosella St Frankston 03 9783 8122
Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2008, 08:14 PM   #7
Quadcams
Quadcams's Avatar
Thank for clearing that up Mick, my mate couldnt fit 16's over his BF xr8 rear brakes so I thoulght the BA GT/Pursuit rears would have the same issue.
Old 29-05-2008, 09:58 PM   #8
ratter
ratter's Avatar
No worries mate,
I ran widened 16 on my when I was racing it and then Bren260 used the same rims and tyres but his was an XR8.
If Brembo's are fitted it would be a different story
Old 29-05-2008, 11:30 PM   #9
xt3valve
xt3valve's Avatar
Are there different types of steel rims you can use for the ba or are the stock black falcon steelies the ones to use with M/T's. If there are different ones where can I get some in Perth. I can fit 16's on the back of my car being an XT.
Im getting a PD blower kit fitted on my 3v in a couple of weeks and will need the extra traction for the strip.
2003 Ba xt Falcon 3v 5.4l
Engine: Eaton M122h supercharged 8psi, water to air intercooled, FRPP Hot Rod cams, 85lb/hr injectors, custom fuel rails, Shelby GT500 carbon fibre intake, maxed out factory 3v heads, fuel cell
Drive shaft: Veems modified 1310 series components, 3" X 0.65" tube, solid cross universal joints and heavy duty centre bearing. Weight saving of 2.2kg and an increase in critical speed of 2,000RPM.
Gearbox: Fully rebuilt BTR 4sp, Chryogenicaly treated, high stall
490rwhp E85
xt3valve is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2008, 09:18 AM   #10
ratter
ratter's Avatar
I had a couple of stock steel rims widened to 8" to fit the tyres
Old 30-05-2008, 06:06 PM   #11
OJ_Pursuit
OJ_Pursuit's Avatar
No worries mate,
Yeah they're not brembo's but the blue pbr calipers with grooved discs from the ba fpv's
I've got 18" wheels on it ATM and there looks to be a good 1 1/2" to 2" clearance on the internal diameter of the rim, but maybe the depth might be an issue.
I will see if I can find someone with a stock ba steelie spare that I could borrow and test fit. If that works ill buy a pair and get them widened to 8"
Travis
Build thread here
Old 30-05-2008, 07:01 PM   #12
punktured
punktured's Avatar
Try looking around for some cheap ba alloys, be a bit lighter than steelies. Wish i kept 2 of my old ones :
With the brakes, would they be the same as the PBR upgrade ones (the red ones)? If so 16" will fit on the back but not on the front
punktured is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2008, 04:39 AM   #13
xt3valve
xt3valve's Avatar
where can you get the steelies widened. Does any tyre place do it. Wouldnt the stock 16inch steelies be lighter than 16inch alloy wheels. I know alloy is lighter than steel but there is more of it in wheel.
490rwhp E85
Old 31-05-2008, 08:35 AM   #14
Bluepower
KenneBell Australia
Bluepower's Avatar
G'day people,
Thanks
Travis
Use a 16" rim with a 255 MT drag radial - dont drop the pressure below 22psi.
Less than 22psi may help with a launch but will eat up HP bigtime down the bitumen.
275 is a bit big and hungry on the HP too.
Buzz me from the track if u need "on the spot" advice - 0438 351 351
Chris
Bluepower Racing Developments
Proud Australian Distributors of Kenne Bell superchargers
The Quickest, The Fastest, The Baddest Boss Blower of all.
www.bluepower.com.au
Bluepower is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2008, 12:27 PM   #15
OJ_Pursuit
OJ_Pursuit's Avatar
Chris
Thanks Chris.
Build thread here
Old 31-05-2008, 04:21 PM   #16
ratter
ratter's Avatar
I used Ajax Wheels in moorabbin to do mine
Old 07-06-2008, 06:14 PM   #17
dadem0n
The Anti XLR8V8
dadem0n's Avatar
How do cars fit 15" Welds? Like below...
Does anyone know what brakes fit under welds or convo pros?
dadem0n is offline   Reply With Quote Multi-Quote with this Post
