Old 14-09-2007, 04:43 PM   #1
eski666
eski666's Avatar
Default Roll cage specs
Does any one know what the ANDRA regs are on roll cages as in what material must be used for times run and when you must have one fitted?
eski666 is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2007, 04:51 PM   #2
GTP owner
GTP owner's Avatar
Go buy the book from andra - it's all there. Failing that, get a kit from a supplier like Mcdonald Bros for your car and weld it in. What times do you want to run? A cage is necessary once you are into the tens (10.999) or if the car has significant structural changes, such as the firewall.
The thickness, diameter, and mountings are detailed in the book.
XA coupe 8.8sec @ 150mph http://www.fordforums.com.au/showthr...coupe+drag+car
BA GT-P for the shed
Mustang GT for the other half
E3 chubsport - fully fat (and slow), sitting there waiting for me to get sick of it and sell it.
BA XR6T for a daily
NT Pajero for the bush
XB 4 door project- swallows a BF xr6 turbo
My dad is a generous bloke. He gave away his dead car batteries free of charge....
GTP owner is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2007, 03:46 PM   #3
eski666
eski666's Avatar
Hopefully running in the 10's and was told I needed a chrome-moly 6 point cage that needs to be welded in. Didnt the ANDRA info used to be online?
Old 15-09-2007, 04:16 PM   #4
nugget378
Weezland
nugget378's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to impart knowledge in the technical areas.
Thats right,and also if you have a modified monocoque,
ie: mini tubs or any altering of the body you need a welded in intrusion bar,if you dont have any body altering intrusion bars can be bolt in untill 10.499 from memory?
Crome moly is better due to it being lighter a 6 piont in a falcon is 35odd kg,but I think you can use mild??
but it needs to be of a thicker guage and so even heavier,the cost is in the labour not so much in the material,so moly is the only way to go IMO,
best to get in touch with andra and have everything clear with one of their inspectors before you start if doing it yourself,I got a professional to do mine who builds race cars and have had it tech inspected,going this way saved any hassle.
nugget378 is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2007, 04:31 PM   #5
[dave]
would ally be any good ??
[dave] is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2007, 07:18 PM   #6
nugget378
Weezland
nugget378's Avatar
Not for racing,illegal.
Old 15-09-2007, 10:50 PM   #7
ToddZC
Thunderbolt driver
ToddZC's Avatar
A 4 point cage is good down to 9.99s. I have a bolt in 4 cage with drivers side intrusion bar in my Fairlane, it is both street legal in WA and meets the ANDRA specs.
Definitely get hold of the ANDRA rule book, it has all the required specs in it.
Thunderbolt Racing Team
You can't spell FEar with out an FE.
ToddZC is offline   Reply With Quote Multi-Quote with this Post
Old 16-09-2007, 01:01 AM   #8
Tiapan
XF 393 3v CHI heads
Tiapan's Avatar
hey todd, does your cage have a taxibar for the harness? dont you live in esperance or something like 6 hours from the city? i would like a tied in 4 or 6 point just to make my flimsy xf a little stiffer thorugh the corners, also im taking it to a drift practise day for a bit of fun later
XF Falcon, 393 Clevo. 11.01@123mph
"RAZNREVNU"
Tiapan is offline   Reply With Quote Multi-Quote with this Post
Old 16-09-2007, 07:51 PM   #9
schnoods
schnoods's Avatar
Ally is combustable in the right conditions, plus strength wise the wall thickness would have to be pretty heavy gauge and if ever a fire broke out, it would all be compromised.
A philosopher is a person who finds a problem for every solution . :Reverend:
95 EF XR8, Advance headers, Vortech V2 t trim blower, Ported Cobra Manifold, Capa Switch Chip Eliminator. 307 rwhp 395 ft/lb 13.2 @ 105mph
Now NA- AFR 165 heads, 1.6RR, Ported Cobra 269rwhp 14.2 ... needs stall and 4.11's
1977 CL Chrysler Panel Van, 360, 727 torqueflite auto soon to be restored.
schnoods is offline   Reply With Quote Multi-Quote with this Post
Old 16-09-2007, 10:49 PM   #10
jd dad
andra.com.au is the web address, book is $25 from memory. 08 82715355 is the office number
successfull trades with davway,ozziechief,Damon, Big Trev, Howey, BJ , Niko, Davocol,klawsterfobik and XCwillo
jd dad is offline   Reply With Quote Multi-Quote with this Post
Old 16-09-2007, 11:52 PM   #11
TruBlu351
3 Pedals R Better Than 2
TruBlu351's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Has given endless help in the cleveland section over the years. Knows his stuff and happily tests on the track and gives no fuss results.
That's good. I didn't realise they were street legal in WA.
What sort of $$ did the cage cost?
Tiapan, Todd's local Perth.
After seeing a few Youtube muscle car crashes, it would be nice to have one even if you aren't in the 10's.
XE Falcon - Under Construction
434 E85 Lawn Dart underway
TruBlu351 is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2007, 08:32 AM   #12
GTP owner
GTP owner's Avatar
My roll cage cost just under 1k from Mcdonald bros and welded straight in. It was a mild steel unit and was a fairly straight forward instal. Chrome mold is lighter, but more expensive and requires tig welding.
Alloy is outright a nono.
BA XR6T for a daily
Old 17-09-2007, 04:09 PM   #13
ToddZC
Thunderbolt driver
ToddZC's Avatar
I had the cage done with a whole heap of other mods at the same time, so can't give you an exact figure. Although, around the $1k mark for a weld in mild steel cage sounds about right. Bolt in or CM steel are an added expense.
Old 17-09-2007, 04:10 PM   #14
ToddZC
Thunderbolt driver
ToddZC's Avatar
Tiapan, my cage does have the taxi bar and I mount the shoulder straps of the harness on it. As Trublue said, I'm local Perth.
Old 17-09-2007, 08:28 PM   #15
jd dad
Bloke here had a CM cage made for an LH Hatch, was around $2000 I think. Made to sub 10.99 ANDRA specs
Old 26-09-2007, 11:49 PM   #16
ebxr8240
Performance moderator
ebxr8240's Avatar
over 800 lb...rollcage
1 5/8 tube with .116 wall thickness
mild steel...
shoulder and frame rails ..1 1/4 with .075 thickness
uprights and crossmembers
as above
diagonals..22mm / 7/8 dia with 1.5 mm / .060 thick...
from page 117 Andra Rule book...
All mild steel specs..
Daily driver GTE FG..
