15-06-2007, 03:11 PM | #1 | ||
any clues there is a water dripping onto floor on driver side (top left corner, looks like water is running from or over heater pipe for feet), only when raining (last night about a liter of water inside)
15-06-2007, 06:15 PM | #2 | ||
Possibly a rust hole under the cowl, only thing I can think of.
Remove the plastic trimming around the wipers and clear out all the gunk and see if you can find any holes. Suneep |
15-06-2007, 06:39 PM | #3 | ||
i agree with sunny
that would be about the only thing i can think of jason
no longer have a ford but a ford man at heart R.I.P 98 EL MAY YOU HAVE A GOOD LIFE IN FALCON HEAVEN [SIGPIC][/SIGPIC]
16-06-2007, 01:31 AM | #4 | ||
Leaves collect near the corner of the bonnet causing the water to leak in near the door - open bonnet and remove leaves etc
regards Blue |
16-06-2007, 11:45 AM | #5 | ||
eec tweaker
Windscreen seal.
water runs down the inside of the A pillar and onto the floor. Happened in my EA. |
16-06-2007, 03:58 PM | #6 | ||
ORSM Ford Cruisers
check if you closed the window? i know it might be stupid but you may have left it open. also i agree with the window seal and a hole under all the plastic where your wipers are. heaps of stuff always gets cought in there.
ORSM Ford Cruisers < click here
1993 EB2 Gli---->Build Thread 2008 FG XR8 SEDAN 300RWKW N/A 2008 FG XR6 TURBO-UTE>>> SOLD 2002 AU3 XLS UTE>>>SOLD |
20-06-2007, 02:59 PM | #7 | ||
Thanks a lot, I believe it will be the windscreen seal. Will try it soon.
21-06-2007, 04:07 AM | #8 | ||
Aspiring mr efxr
well both times ive had water inthe passenger footwell its been the heter core (whole dash needs to come out), this is on an EF, on an EL it may come down the drivers side for all i know, could be wrong. if it only does it while its raining out id say u wouldnt have to worry about this.... probably just some rubber gromets in the firewall are loose or some bullshit reason thats a pain in the bum-end....
EF Wagon Project: Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA |
