Old 12-05-2007, 10:15 PM   #31
RG
Back to Le Frenchy
RG's Avatar
Originally Posted by agony
They'd be fun to try to set up in the engine bay of an AU lol.
Old 13-05-2007, 02:08 PM   #32
66 coupe
around the place
66 coupe's Avatar
Originally Posted by XA5800
I use a system 1 filter, had it for about 10 years , its great.
I suppose if you have a $10.00 engine you would use a $10.00 filter.
For me its cheap insurance as you can remove the inspection plate & get a great indication of any problems.
The way i see it, if you've got an engine problem and your getting metal in the filter, then you've got an engine problem, and its putting metal in the filter. Whether you see the metal in the filter or not doesnt really matter, because you still have an engine problem. All the filter is going to do is confirm that something is wrong - same effect as putting the used engine oil through a cloth screen or mesh filter in a funnel.
Sometimes your best not knowing whats in the filter and drive it till it drops because end of the day, if metals gone round the motor its still going to cost you the same amount to fix it.....
And if you use a purolator filter, you can spend the extra $290 on fixing the engine at some stage later on.
Also just a word of warning, I've come across K&N filters that had metal filings on them out of the box, seems they dont put too much effort into quality control at the K&N factory, hence im now using pure one filters.
GPS Tracker for your vehicle - PM me for info
66 coupe is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2007, 03:07 PM   #33
RG
Back to Le Frenchy
RG's Avatar
I think I'd like to know A.S.A.P if there is an issue within my engine. That way I can fix it before it potentially damages something else.
Old 13-05-2007, 03:15 PM   #34
66 coupe
around the place
66 coupe's Avatar
How often are you going to check / clean the filter, daily?
If you check it once per service (5000 or 1000km), and find metal, then chances are the damage is already done to the cam / bearings / oil pump etc (we're talking road cars here, not drag cars, where in that case, yeah you could do it once per meet)
Old 13-05-2007, 05:54 PM   #35
RG
Back to Le Frenchy
RG's Avatar
Finding it at 5k is better than not knowing about it until it goes bang.
Old 13-05-2007, 09:51 PM   #36
yift
Technical Contributor: For members who share their technical expertise. - Issue reason: Countless sensible, accurate mechanical advice on all things Falcon and Territory.
instead of using z9 oil filters use z89a they are shorter hence you will get better oil pressure.
yift is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2007, 10:33 PM   #37
RG
Back to Le Frenchy
RG's Avatar
Just started using them and the difference is noticeable at start up.
Old 13-05-2007, 10:38 PM   #38
b2tf
not here much anymore
b2tf's Avatar
thats cos theyre the correct ones for your car :hihi:
2024 F150 XLT
Old 13-05-2007, 10:42 PM   #39
RG
Back to Le Frenchy
RG's Avatar
I know I know but I only just found out where I can get Purolater ones for $8.
