Old 29-01-2007, 12:19 AM   #1
needaXYGT
AU II XR8
needaXYGT's Avatar
Default what ECU will work with my car?
hi, im looking for an ECU that will work with my car. its an 88 EA 3.9 manual.
im after an MPI ECU because im soon to convert it from CFI to MPI. i have everything excpet the ECU. everything else came of an EB including the new loom. the EB was a manual. iv been told i can use any MPI ECU of an EA, EB or ED, but others have told me i can only use a manual mpi ECU out of an EB since all the other parts are from an EB?
if it matters, my car has an immobilisation system.
all help much appreciated!
AU XR8 II ute
XD FAIRMONT GHIA 302
XA FAIRMONT 302 TOPLOADER
needaXYGT is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2007, 12:34 AM   #2
kyro_02
V8 wannaabeee
kyro_02's Avatar
well my mate put a eb auto ecu in his nc .. i'd say it would be all the same
im selling an ed auto ecu :P
kyro_02 is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2007, 03:01 AM   #3
Nostalgia
LOW AND SLOW
Nostalgia's Avatar
Hi im considering doing the exact same conversion real soon so any info on this will be a great help. Im also aware Snypereb recently converted his with great results.
"Any Color You Like As Long As It's Black, Matt Black, With Flames, And A Bit Of Pinstriping".
Nostalgia is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2007, 03:56 PM   #4
NZ
NZ's Avatar
Smartlock and non smartlock ecu's are what you need to watch out for here.
A Smartlock ECU won't run at all without the smartlock system there. This includes the module, wiring, ignition key at the minimum.
I don\t really see the point of changing all the looms as theres only one wire you need to change to convert a CFI engine loom to work properly with Multi Point. It takes half an hour to do properly or 5 mins if you dodgy it up. To use the EB looms you would need to do the entire car as the EB stuff won't mix and match with the early EA stuff. Plugs are all different shapes and it would be a nightmare to do.
Also any EA or EB1 ECU (including Auto) will run a manual car just fine. Its when you get to the EB2 with the integrated Auto control that you get funny things happening.
EF Falcon Sedan 5.0 auto with IRS
"the man that crashs AFF"
NZ is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2007, 05:56 PM   #5
needaXYGT
AU II XR8
needaXYGT's Avatar
ok thanks alot for the help!
but one more question. If i were to use a CFI loom, it would mean i would need to add all the other injector plugs as well as changing the other wire. correct?
if i were to use a loom out of a MPI EA to EB1, it should be fine?
AU XR8 II ute
