Old 06-12-2006, 01:15 AM   #1
aufairy
Unhappy one thermo
hi all i have a problem with the thermo,s on the au only one is kicking in. if you turn on the cc the air con will turn it self on and off blowing warm then cold and only one fans runs until temp gets up near the l on normal not sure what the problem is. all relays and fuses seem ok. and i just had air con regassed when you turn the air con off you can hear the gas running through the lines dont know what the go is with that
aufairy is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2006, 08:59 AM   #2
Mechan1k
Mechan1k's Avatar
Only one normally works from memory ... then at a certain temp (and when A/C turns on) both fans work at "low-speed".
When you turn the A/C on fan speed 3 and above ... both the thermos switch to "high-speed" ... it also happens in extreme heat as well when needed.
Although I did have my thermos replaced recently as they weren't spinning fast enough and without enough power from the motors ... you could stop them with your hand (which you shouldn't be able to.).
