Old 10-04-2006, 03:16 PM   #1
Caretaker
Caretaker's Avatar
Location: In the Beutyfull Upper Orara Vally near Coffs Harbour
Default Laser Driveshafts ????
Can Anybody tell me if I can use the Driveshafts from an 86 Laser Auto on a Manual. I want to convert an Auto to Manual. :thebirds:
Caretaker is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2006, 07:52 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
Default gearbox conversion
yes you use the same
if you need quick confirmation ring a cv joint supplier to see if they are or repco for the same part number
find vipppen in the members list he is the lazer guru
watch out fo the tricks and traps in converting
rear engine seal replace and the driveshaft seals on the way back in
the pedal box fitting
spigot bush in the flywheel may be different but not sure
My car goes Brumm Brumm
dirty hands is offline   Reply With Quote Multi-Quote with this Post
