MADED.6
as title says i have my motor out and when i put it back in i want to know whether to go thermos or not. i dont want to kill my battery as i heard can happen and i also dont want my car overheating when warming tyres up at drags which i heard thermos are bad for as the only come on at certain points where as clutch fan stays on most of the time and will keep air flow coming better. will thermo fans do much for responsiveness or power and fuel economy.
cheers josh.
TUFAU-8 Get Stroked. AU Stroked 5.6L GHIA |
Lovin the Manual.
wel.. ive had both....
id say go th thermos man... 1. no shitty loud *** fan noiske when ya car is cold... 2. makes a big difference to responsivness/econemy when fan is in full swing... (hot day aircon on.... or at 1st start up) 3. if thermos made ya car over heat when ya did standstills... every car on this forum from ef onwards would be dead =P lol 4. if ya battery would die... again every car from ef onwards would hav dead batteries =P just make sure u set up the thermo switch to come on at the right temp. and ur set! |
[EBGLT]
Next mod on my car will be thermo's!!
[EBGLT] Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/ |
just keep the clutch fan if the noise doesn't bother you.
#5 | |||
bettering 13.7
thermo's all the way IMHO lot less drag on the motor and alot quieter.
std stroke, alloy heads, comp cam, tfs manifold, 75mm t/b, 70mm maf, 30lb inj, adj fuel press reg, twEECer FPV/Tickford Club of W.A Performance is Electronic BPT Motorsport |
Virtuous Bogan (TM)
![]() Join Date: Jan 2005
When I put AU thermos in my last EA it made a noticeable difference. Its way better, this discussion as be done to death but there is a definite power difference, no matter how small.
Not only that your car wont sound like a hover-craft.
I didn't notice any power difference on the Fairlane. But it sounds better.
Virtuous Bogan (TM)
Maybe "power" isn't the right term, but it certainly feels freer; which must equate to some kind of power gain no matter how small.
Steve
I noticed no power or economy difference really. Only the noise factor. I very rarely heard the clutch fan, but now I hear this loud noise everytime I sit at the lights.
Silver PJ Ranger XLT ...with goodies... |
![]() Join Date: Oct 2006
Cools better in my NB and they last longer than clutch fans (average life 2 years) but in the height of summer in WA with aircon on max and all the Fairlane goodies running I do get a flat battery.
regards Blue |
EBII XR6
thermos are on the way for my car too! as said they're not loud when you rev the motor like clutch fans!
DEVLXR
#12 | ||
Location: Under the bonnet, trying to keep as clean as above!
they are 100% better if you set them up right.
/\/\etaL and V8s -Awesome
Thermo's man, I have taken tooooo long to put these onto my car, and they work a treat. I have since taken the Davies Craig switch off and put a more 'factory' look switch in the thermostat housing. The car will be more responsive, considering it doesnt have to spin a spring/viscous fan, and I can tell you the temp range for them to come on is 95°C ON - 90°C OFF. This is just under half when they come on, and they go down to just above 1/4 which takes 30 seconds to acheive this.
Wiring is simple and the EF fans are very reliable. Go For It!. Please also see my other post - EB - Thermo fan Conversion Success. Cheers ViGiLaNtE351
Nothing Sounds Better Than A V8 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ BA XR8 MKII EB Falcon ThermoFan Conversion http://www.fordforums.com.au/showthr...t=vigilante000 BA Falcon ICC Speaker Wiring http://www.fordforums.com.au/showthread.php?t=11342785 BA Wiper Motor in XE http://www.fordforums.com.au/showthr...=1#post5393955 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ |
#14 | ||
FirstOnRaceDay
How much is a thermo conversion... I am looking at doing it...
And also what is the ideal temp for thermo's I would like to set it a 1/4 instead of 1/2 temp...
MY BRAND NEW RIDE NC Fairlane GHIA Series II I6. Mods. 2.5" cat back Clarion HU Soundstream speakers amp and subs Lowered DL LTD rims ![]() For the moment... ![]() |
#15 | ||
unless you are planning to pop the tyres doing a skid at the drags, you wont have any problems. if it does get hot doing a little skid, maybe your radiator is shagged, or you have cooling problems. i took the radiator out of my little brothers car on the weekend when fitting thermos, and it would have been at least 1/4 blocked with **** between the ac condensor and the radiator.
i cleaned the radiator, and got most of the **** out between the fins. also fitted a cooler thermostat. i have been driving it around with no fans at all, and its even cooler than what it was with the fans on 100% of the time. thermos are the way to go. i never had any problems with low voltage. if your battery dies with thermos, it was on its way out anyway. I drove Rollins car for 2 odd hours, with stereo pumping, A/C, etc on a warm December day, no dramas... with a 75amp alternator. The voltage gauge was dipping to 10v quite regularly...
Powered by Rollin Motorsport Turbo Barra ED 4L
#16 | |||
Conversion cost less than $200 Cheers ViGiLaNtE351
#17 | ||
MADED.6
yeah i think i will do it just that most cars other than falcons i see overheat with them as in commodore vr-vs with them all the ppl i no with them just idling through drive throughs they overheat. but yeah if u guys say they are good then i will have a crack at doing them. can anyone pick them up sheap for me or tell me a place to try.
cheers josh.
#18 | ||
V8 Ute V8 Boat
yer i will be giving it ago soon
VE SS Ute manual 09 AU XR8 UTE 200KW manual 02 Challanger Ski boat V8 01 125 Thumpster 2010 Swag All set for the weekend |
