Old 15-09-2021, 07:32 PM   #31
Metdevil
Default Re: the f@#%!&* starter motor top bolt!
Originally Posted by jack theman View Post
Go in from the top - way easier. Take the air filter and associated ducting off.
Remove the top half of the air manifold intake (its in 2 parts). Put a small stool in front of the car and a blanket across the engine and then climb up and lie flat across the engine and you can see and access the top bolt from the very back of the engine with a standard ratchet. Way less niggly.
You removed the top half of the BBM? Man, that seems like a lot of work to access one bolt
I found that you can get to it from (nearly) the front of the engine with a series of extension bars. It's still by no means easy, but once I figured it out it cut down on niggle time significantly.
Metdevil is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2021, 08:41 PM   #32
wodahs
wodahs's Avatar
i sure hope he got it in by now as this thread is longer than the starter bolt thread ~ going back 3 years now
yes still (as money n time permit) doing the
rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually
just remember don't be afraid to try something new.
Remember, amateurs built the Ark...Professionals built the Titanic!
I have taken up meditation... at least it's better than sitting around doing nothing !!
wodahs is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2021, 09:04 PM   #33
Metdevil
Three years? Nah, that sounds about right
