Just been to Middy's electrical supplies talking about solar power systems.... Basically the salesman has turned me off it because he says that if I am not home during the day using the power off the panels directly, then there is no savings to be had.... The only way to store the power made from the panels is using a battery pack but those presently cost around 20K.... Only business's can benefit from solar because they use the power being made through the whole day.
A much cheaper option is to change all the light bulbs in the house or at least the ones that are used the most to LED bulbs....I just bought a couple of large screw in types for $24 each and they last 30,000 hrs... Much cheaper than blowing 8.5k on a solar system that wont really save me much! ![]() |
That's why I just dance!
I personaly am interested to see other peoples opinions on this (and the whos gone solar thread), I currently havent got any solar,but am looking to build a new house in the next 12 months and its somthing I'm sonsidering.
so I like reading all I can about this as well as the real life (non spec sheet) pros and cons of the systems and they're alternatives
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
Well the salesman said to save the power you HAVE to have battery packs and they can cost 20k.....He also reckons that solar panels actually work more efficiently on overcast days than bright sunny days ....how the hell does that work?
Turn the A/C and the pool pump during the day
Thailand Specials
I've got about 16 halogen globes changed to LED, the phillips 50W equivilent is the only one worth buying as the rest are crap, very dim.
#8 | |||
Dent Removal
Look at anything in your home running a motor or an element this is where the biggest savings can be easily had, for example and spare Beer fridge running during winter, a column or bar radiator left running while nobody is near it, pool timers not set correctly, exhaust fans left on, hot water system left on while away on holidays etc
Here's an awesome site for anyone wanting to save a few dollars.....And read all the facts about LED's.... They can last for 80,000hrs!
http://www.ledified.com.au/ Last edited by GASWAGON; 18-07-2013 at 07:14 PM. |
Led lights are definitely more efficient but you would have to have to light running for 3 years straight to notice a difference on your bill mate.
As mentioned above, anything that produces heat (hot water system, cook top, oven etc) is the cause for larger bills. When LEDs go down in price ($24 for a Compton light is an absolute rip off) then they will serve a purpose, but in the current market there are too many poor quality led globes being made that give out less light output and don't last anywhere near their alleged life span |
#12 | |||
YE-US! Wait. I don't know
Yep, LED lightbulbs are cheaper than solar panels. They won't save you much though (they'll pay for themselves sure).
8k is a lot, and yeah you need to have a battery pack installed (or three depending on the packs), it was my impression this was standard (this is how we had to design them at uni when I did remote area power supply subjects, but that could have been because we were doing off the grid designs). It's all in the maths, what's your current cost, how long will the system last, and how much will you save. When I buy I'll be looking for something with solar installed, and if it hasn't been, I'll be getting it installed as a priority.
"Well. Apparently you're looking for a lion-snake named Harriet." Daily: '06 BF XL Ute,Shockwave Blue, Column Shift, eGas BEAST.
Gone: 77 HZ panel van, 253, column. The Weekender: '06 BF Pursuit, Toxic, lumpy af |
#14 | ||
It all adds up and every bit counts..... Go LED's!
#15 | |||
BANNED
Are you for real with this thread title matey? I can get a 200w solar panel for $190. For $8k I can get 8kw of panels making about 30-60kw a day depending on the season....without govt rebates. You really should do some research before posting threads like this one. |
#16 | ||
Pity the fool
Anyone able to provide more info about these battery systems?
Fords I own or have owned: 1970 XW Falcon GT replica ![]() Proud to buy Australian and support Ford Australia through thick and thin |
#17 | ||
BANNED
#18 | |||
#19 | |||
BANNED
mate...the peak rate lasts till 11pm....any excess power makes your meter run in reverse till you need it again. The grid is your battery pack......kapeesh???? Power that panels generate offsets power from the time you get home till you go to bed. I can't explain it any simpler than that. But some life skills advice?...you need to stop making friends with Middys salesman who are intent on selling you overpriced bulbs and talking sh it. |
#20 | |||
Pity the fool
#21 | ||
Only if you want to get off the grid entirely.
#22 | |||
If I were you I would take back to LED bulbs and buy some standard energy saving fluorescent globes. They will do the exact same thing for a fraction of the price and you will profit $20 per a globe |
#23 | ||
You do realise that there is more to a solar system than just the panels.
#24 | ||
The whole key to saving energy is to use as little as possible. If you switch to led lights or energy savers you will cut your bill by a nominal amount.
Solar will save you in 2 ways. 1) if you are using power while the system is generating you will be using less grid supplied power hence saving you. 2)If you are not using power while generating then you are exporting back to the grid reducing your billable total. To make it worth while you would need a 2-3KW plus system to offset an average families usage. battery banks only work via invertors to convert your dc voltage back to ac. You would need a significant bank to power a house for a nights usage. The solar cells would not be generating power to export to the grid but would be used to charge the cells. You can only make money on solar so long as you have sun as well. I find with my system that it is inefficient on overcast days and hot days. Was solar worth it? yes it has saved me a bit but no not really that much. I only have a 1.6KW system and only got it cause i had it installed for round $1950.
HendrixHC ![]() --------------------------------------------------- 1966 Mk1 Cortina 1982 XE Falcon 1978 XCGS Falcon 1993 XG Ute 2015 FGX XR8 |
#25 | ||
BANNED
#26 | ||
BANNED
#27 | ||
OK some things about LEDS.
Lighting in your home is about 10% of your power bill, you probally have around 15 to 20 globes in your house. So if you upgrade your lights to LED, you will be saving X amount on 10% of your bill. Which means nothing as you have just spent $24 each on a LED globe's. Probably save less than $5 a year as you have only got a couple of globes. Now for the solar. Yes you get the most out of it by using your power during the day, but even if you are not home, solar can still save on your bill. You still have items running during the day when you aren’t home, such as a fridge/freezer, items on Standby etc. Also if you do not use power during the day and you put it back into the grid you will get a buy back. Even a buyback of 8 cents per Kwh will net you more money back than the LED Globes will save you. |
#28 | ||
O.k well at least I only bought two globes then......Thanks for all the info guys because I wasn't sure about what to do with my power bills as they have gone up 50% in the last three years....I will DEFINATELY be looking at a 5-6kw solar system in a few months time when I get some money together.
#29 | ||
that salesman is full of s#*% check poppa's thread on solar . im in sa on the low rebate paid $7000 for a 4kw system and in 12 months I have saved about $1600 and am in credit $380 my system would now be well under that price .do some research its well worth the effort.
clevo mafia (sadly sold) 351c xe manual (now with short shifting 5sp goodness) xc gs coupe project...hmm more clevo for me new daily 2005 ba sr |
#30 | |||
GT
my electrician workmate also sprukes about LED LIGHTS he has changed all of his lights to LED and is saving heaps on power bills , something i think i will be doing also . good thread . thanks my friend does not have solar and his bills are rediculously low , around $150 per quarter i have 83 light globes in my place . i have paid in excess of 1000 / per quarter in summer with air on and 550 in spring without aircon |
