04-02-2007, 03:49 PM | #1 | ||
Hi all,
New here so please be nice, i have a 94 Telstar and am having a problem with the brakes Whilst driving the 4wabs light on the dash turns on and occasionally the brakes start to lock up when you stop and the car doesnt really stop very well does anybody now what could be causing this ? Thanks for your help |
04-02-2007, 04:48 PM | #2 | ||
Over Thinker
replace the brake fluid
a ceasing caliper or warped rotors get them checked by a brake specialist
My car goes Brumm Brumm |
05-02-2007, 11:03 PM | #3 | ||
Disk rotors tend to warp easy on these babies, good idea to check them out.
05-02-2007, 11:37 PM | #4 | ||
Back with Boost!
Brake fluid is unlikey to be the cause but if it hasn't been changed in a while it's a good idea (and a bastard to do if you get an air bubble in the hydrolic clutch)
Firstly the 4ws light comming on means the fluid is low or the hydrolics have failed. Jack the car up and check for leaks around the rubber boots and check the system is working by turning the wheel to full turn and looking at the rear. Also as far as locked up brakes, your (most likely rear) calipers are seized on. There is a fault in the mazda626/telstar that causes the handbrake to lock the rear discs. This intern may well cause your rotars to warp. |
