Jiggy Up Yourself Man
Hey guys well looks like my EF has sprung an oil leak, the sump gasket is fine and ive nipped up all the bolts and the gasket is in good shape and oil isnt coming from it but it does appear to be comming from the front of the engine above the front of the sump where I think the timing chain assembly is, any ideas what it could be and what im up for?, Im told you need a special tool to get at it also. Anyone recommend any good reasonable mechanics in Gold Coast Area?
Cheers PS: cant beleive the sump bolts on these are so small im amazed.
CURRENT BLUE OVAL: 1995 EF II FUTURA, CHAMPAINE |
Last warning
i'm lookin' forward to mine doing the same thing as my sump is currently not bolted up and will get done up today (your right on how small they are, 8 mm :o )
If mine leaks... silicon is my friend :/
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
windsor user
sounds like the timing case seal unsure what you have to remove to get at it, but id imagine the usual suspects ( crank pulley and harmonic balancer, waterpump)
