12-03-2010, 07:41 AM | #1 | ||
I drive way too much...
Problem: ABS light comes on when I turn the wheel left, and then stays on and the abs system seems to disable itself as a precautionary measure. Haven't had a chance to test it for real as I just fitted new tyres during which the abs sensor disks were cleaned up, so I'm not about to skid about on brand new tyres!
ABS engages at low speeds when braking very occasionally, but limited testing time due to the fact that the system stops alltogether as soon as I turn left. What could be causing this? I've perused the abs threads but I can't seem to find the same problem anywhere. The front sensor cables seem okay not pulling or anything and as far as I can tell without taking the wheels off the connections near the disks are fine. Car is AU series 3, 02 LPG model, just purchased a few weeks ago. If it helps, I believe this is the original bosch abs unit, although looking over the service history receipts this problem has been worsening over the last few years. Any ideas? I'm in Perth, so if anyone knows of a place here where they've had good service with ABS let me know please. Kieran |
12-03-2010, 10:00 AM | #2 | ||
Chairman & Administrator
It sounds like either the wire to one of the wheel speed sensors is loose or the sensor itself has failed.
Cheers Russ
Observatio Facta Rotae
12-03-2010, 10:36 AM | #3 | ||
Yeah Id say one of the sensors aswell. Mine has only lit up the ABS light once and it happened the first time it was run on a dyno, stayed on all day then a week later when I drove it next it was good and hasnt come on since. Weird.
01-04-2010, 06:27 AM | #4 | ||
Had a scan done when the recent Perth storms knocked out my transducer, and it is indeed the left front ABS sensor. Well done guys you were right on the money!
01-04-2010, 02:17 PM | #5 | ||
VFII SS UTE
i can only referance holden!!
common cause was metal dust build up sticking to the sensor, (brake rotor dust)front. road grime, blue metal stone's, tar, on rear sensor's . clean with kero soaked cloth.
I don't often hear the sound of a screaming LSX. But when I do, So do the neighbours.. GO SOUTHS
