13-02-2005, 04:11 PM | #1 | ||
Interceptin'
Where's the best place to put ratchet type Axle Stands on the front end of an EF falcon? Any pictures would be helpfull.
Thanks
'95 EF II Falcon, 'INTERCEPTOR' '72 XA Fairmont Coupe, 'XA Muscle' |
13-02-2005, 07:26 PM | #2 | ||
Depends what you want to do. Under the chassis rails or under the K frame if you can lift the car high enough
14-02-2005, 10:05 AM | #3 | ||
Interceptin'
Alrighty, And I guess I should use those points and the rear axle to jack it up. My scissor jack was USELESS jacking the car up. Apart from busting my nuts cranking it and bending the U-joint on the thing, it still wasn't high enough to put an axle stand on the rear even at it's lowest form.
Plus, I bent one of my jack points using my mates trolley jack! Darn weak metal crap! Time to go by my own trolley jack... (sooo effort-LESS)
14-02-2005, 11:21 AM | #4 | ||
Ute Forum Moderator
Don’t use a trolley jack on the normal scissor jack points, as you found out the sheetmetal flange will not support the weight. (If you had a block of wood with a slot cut in it to mimic the head of the scissor jack and push on the metal beside the flange it would work)
For a trolley jack or axle stands, use the chassis rails or the crossmember at the front, they are a bit further inboard from the normal jacking point. At the rear, place the trolley jack under the diff centre, and axle stands under the axle towards the outsides, making sure you don’t squash anything (handbrake cable etc). Use a bit of rag (a couple of thicknesses) to protect from scratches (scratches could expose bare metal = bad, so worth taking a simple precaution to prevent) |
14-02-2005, 11:37 AM | #5 | ||
I wouldnt be jacking up just one corner either, you'll twist the chassis/body of the car. Its not unheard of for windows to crack in such situations.
14-02-2005, 12:30 PM | #6 | ||
What those last 2 clever gents said.
Also, when buying your trolley jack remember bigger is better! You don't want something made for a Jap/Korean micro car under your Falcon and each succesive model isn't getting any lighter.
14-02-2005, 04:08 PM | #7 | ||
Interceptin'
This info is extremely usefull. Thanks champs!
14-02-2005, 05:08 PM | #8 | ||
Two > One
In allot of cases we dont have the luxury of jacking the car up square (middle of diff or crossmember) by using a large jack. A cheep-o 1800kg jack doesnt fit under my front or back bumper, or my side rails to reach a decent jacking point, subsiquently jacking the car up on one side is nessacary to puerly get the jack under a point to which the car can be jacked square.
Driving the front or back wheels up and onto a block of wood is often the only way to get a square jacking point or get a trolly jack under the side of the car.
14-02-2005, 05:13 PM | #9 | ||
You could buy some ramps and drive the car onto them? Very easy, and effortless..
14-02-2005, 05:15 PM | #10 | ||
Last warning
haha...
don't try and get a lowered car on ramps.. or even a stock car for that matter. we lost the bumper of that Wrecked EF Ghia i had on the ramps and it was stock ride height.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
14-02-2005, 05:16 PM | #11 | |||
Interceptin'
14-02-2005, 05:17 PM | #12 | |||
Interceptin'
14-02-2005, 09:10 PM | #13 | ||
I couldnt get my old EA with stock height on a set of ramps due to the front bumper, had to make an additional ramp with timber to go up the ramp at a less of an angle.
They've been making the same style ramps for 30 years, they really need to update them for newer cars.
14-02-2005, 09:15 PM | #14 | |||
They're about an inch thick and two of them each side seems to work well.
14-02-2005, 09:47 PM | #15 | ||
02/90 EA II Fairmont
ahhaha ramps i've got a set of really kind, gradual slope ramps here from when dad was into cars more, and i can't even begin to get up them, i drive the car onto some paving tiles on the driveway so i can get the jack under the k frame...
211RWKW EA |
15-02-2005, 04:55 PM | #16 | ||
Interceptin'
Well guys since im after a good trolley jack (one that can lift an EF), any recommendations on brands or where to look? Something cheap and durible would be nice Are the K-mart one's worth it?
'95 EF II Falcon, 'INTERCEPTOR' '72 XA Fairmont Coupe, 'XA Muscle' Last edited by Interceptor'85; 15-02-2005 at 05:53 PM. |
15-02-2005, 05:50 PM | #17 | ||
go to supercheap (if they're still for sale), I picked one up for $20 at one of their sales and it seems to do the job... just wouldnt trust it to support the car or anything of that nature. But as they say, you get what you pay for.
Me fail English? That's unpossible.
15-02-2005, 10:04 PM | #18 | ||
haha werent they the ones recalled?
211RWKW EA |
16-02-2005, 12:16 AM | #19 | ||
I wouldnt use a Supercheap $20 jack to raise the Gemini, letalone a Falcon.
The ones that were recalled was their top of the line 'heavy duty' ones which were way overrated in its maximum weight limit.
16-02-2005, 07:36 PM | #20 | ||
Interceptin'
There's a 15% of sale at K-mart this thurs and friday. I reckon I'll just grab a jack then.
Got one from Burson Automotive the other day. got home and it had rust, looked dinted and used, and resprayed! Definately got a refund on that peice of trash!
