Old 07-06-2006, 10:21 AM   #1
nat_daly
Nat D
nat_daly's Avatar
Default E cluster?odometre?
hey all,
my odometer is not working, and neither is the trip meter..
i have replaced the cluster with another one and have connected all the wires up properly, however i didnt check if all the wires were ok, as i thought that it would be the cluster?
what could it be that is making this not work? what do i need to fix it and where can i get it from?
thanks
old ride#1: ED XR6 5 speed-gone to new home:(
old ride#2:dumped EL fairmont 5l
new ride: Winter white AU2 XR8-manual
nat_daly is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2006, 10:24 AM   #2
RG
Back to Le Frenchy
RG's Avatar
This may sound like a silly question but have you checked the globes?
Old 07-06-2006, 11:07 AM   #3
Perana
Perana's Avatar
If your speedo is working fine then it is the cluster that is the problem.. If wiring was a problem then the speedo wouldnt work either.
The problem is that a gear inside odometer breaks.
Perana is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2006, 11:14 AM   #4
nat_daly
Nat D
nat_daly's Avatar
can u replace the gear inside the odometer?
cuz i replaced the cluster.. dont tell me i have to broken clusters here that cant be fixed..
Old 07-06-2006, 11:15 AM   #5
nat_daly
Nat D
nat_daly's Avatar
when you say globes what do you mean? the globes inside the cluster? the cluster works fine apart from the odometer..it all lights up and everything works... includint volt meter, oil pressure etc
Old 07-06-2006, 11:18 AM   #6
RG
Back to Le Frenchy
RG's Avatar
Sorry don't mind me i'm just not thinking this morning.
Old 07-06-2006, 11:27 AM   #7
Perana
Perana's Avatar
The gear can be replaced... a bit fiddly to do. I just found a cluster at the wreckers that had a good gear and got that... I think you can buy new ones now though, it's a fairly common problem.
Old 07-06-2006, 11:37 AM   #8
nat_daly
Nat D
nat_daly's Avatar
how do you get to the gear to replace it?
and where would i be able to get them from do u think?
Old 07-06-2006, 01:51 PM   #9
martO
meh
martO's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For his efforts in creating the monthly Photoshop competitions and advice/tips on how to use Photoshop.
I'd love to know too as I have the exact same problem. I looked for some at a wreckers but they were either not the right one for an eb2 xr6 or they had like 300,000+ kays.
1992 EB II XR6
2004 BA XR6 Turbo
martO is offline   Reply With Quote Multi-Quote with this Post
