Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 17-11-2010, 03:31 PM   #1
Pepscobra
Call me dirt... Joe Dirt
Pepscobra's Avatar
Default Best Brake fluid for track day
Hi Matt - can you help me understand brake fluids better?
I have a pretty much stock 2007 BFII FPV Super Pursuit ute with the Brembo 6 piston calipers on the front and the (pbr?) single piston calipers on the rear.
I'm doing a tuning/track day at Barb's raceway in a couple of weeks and want to flush and replace my brake fluid, as advised by most here.
First question; what is the spec of the standard factory brake fluid used by FPV?
Secondly; what is the best brake fluid you stock for occasional circuit work and 'spirited' street use?
I have to admit, I'm very confused... Do I need DOT 4, 5 or 6? Mineral, synthetic or silicone?? What does it all mean?
Cheers in advance,
Joe.
2007 BFII FPV Cobra Ute|Boss 302|6M|#23/100
Mods so far:
Billet Products Shifter|X-Force Exhaust|Herrod Oil Breathers|Whiteline Sway Bar|Tein SuperStreets|Kings FOR-303SL Rear Springs|Melling Oil Pump|Mace Manifold Spacers|Powerbond Underdrives|Pacemaker Headers|Ballistic Cats|XFT Custom Tune @ 308.3rwkw|DBA T3 Rotors|Ferodo Pads|Goodridge Braided Lines
Mods to come:
4.11 Diff Gears|Chromoly Tailshaft
I use & recommend:
Castrol|Motorcraft|Mainlube|Penrite
Check Out My Build Thread
Pepscobra is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2010, 06:11 PM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Cheers in advance,
Joe.
Joe the brake fluid in the car would more likly be a Dot 4.The performance fluid like AP Racing 5.1 raises the boiling point and AP600 is better and so on.Silicone fluid is very expensive and not used in everyday cars these days but some people use it in old cars or when storing them.The higher the boiling point of the fluid you will find the more often you should also change it as it breaks down quicker when contaminated by condensation etc.
AP Racing 5.1 is a good fluid for street and track and is $20 a 500ml bottle.If you change your fluid from any brand it is best to do a fluid flush.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
FLOORED is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2010, 06:19 PM   #3
Pepscobra
Pepscobra's Avatar
Thanks for your response Matt! really appreciate it.
The AP racing fluid seems to be the one most mentioned on the forums.
Any benefit in using the Brembo fluid over the AP racing product with these brakes?
Penrite SIN seems to be used alot too, but I believe its only DOT 4. Any opinion on this fluid?
So, to flush the system, I'll need 2 bottles then?
Seems a good price. I'll send a PM as I'll need them posted to Perth... Is this ok?
Cheers again,
Joe.
Mods so far:
Mods to come:
I use & recommend:
Old 17-11-2010, 06:35 PM   #4
FLOORED
Race Brakes Sydney
FLOORED's Avatar
There are many fluids out there that we do not use but if forum members are having success with them then that is a good start to find out what is best.
A PM is fine thankyou
MATTHEW PEARCE
Phone 02 9609 1101
Old 18-11-2010, 03:34 PM   #5
Pepscobra
Pepscobra's Avatar
PM sent
Mods so far:
Mods to come:
I use & recommend:
Old 04-01-2011, 10:22 PM   #6
Phildo
Phildo's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent work on the BF Brake information. Technical Contributor: For members who share their technical expertise. - Issue reason: Photo Essay - Centre Console Disassembly
Thread revival time.
I flushed the fluid in my taxi back in mid August. The brakes have required more pedal pressure than normal for a month or so now, so that's telling me that it's flush time again.
Took the reservoir cap off yesterday and sure enough, it was all sludgy. I'm obviously going to have to do a fluid flush on a very regular basis.
After speaking with Matt on the phone recently I was keen to follow his recommendation and go with either PBR 5.1 or AP Racing 5.1. Either one is about $15 for a 500mL bottle.
But I don't own the taxi so I have to justify costs to the owner. So now I'm looking at going with Super Dot 4 instead, which works out to a similar cost to normal Dot 4.
So:
1) Any recommendations on a Dot 4/Super Dot 4?
2) Is Super Dot 4 worth getting instead of normal Dot 4?
3) I'm going to be doing flushes often, so buying it in bottles larger than 500mL would be preferable. If I buy a 4 litre bottle, use a litre or so and then leave the bottle sealed in the shed, will the fluid become ineffective because the bottle has been opened?
Phildo is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2011, 10:48 AM   #7
FLOORED
Race Brakes Sydney
FLOORED's Avatar
So:
I think you should find the Super Dot 4 will have a higher boiling point than normal Dot4 and we use a protex brand super dot 4 for many street vehicles and have no issues and this can also be purchased in larger sizes i think but i can check when i get back to work.
MATTHEW PEARCE
Phone 02 9609 1101
Old 05-01-2011, 11:46 AM   #8
Tocchi
Sandtrap Motorsport
Tocchi's Avatar
might as well ask in here.
Matt, i use brake fluid that has a dry & wet boiling values, what's the difference in wet & dry?
'71 Ford Capri -- 510rwkw Barra powered Capri - new race engine being built
Sandtrap Motorsport's BF XR6T wagon -- to tow around the Capri ^^^
www.facebook.com/SandtrapMotorsport
Tocchi is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2011, 05:52 PM   #9
Phildo
Phildo's Avatar
Yep, scroll down towards the bottom and it's available in 500mL, 5 litre and 20 litre bottles. A 5 litre would be good. I wonder would the cost would be - there isn't any info out there about retail pricing.
http://www.atap.com.au/wn_products.html
and
http://www.atap.com.au/documents/March2008.pdf
Old 07-01-2011, 07:15 PM   #10
Trevor 57
is now there
Trevor 57's Avatar
We use the PBR BF600, it is bloody great, it has never ever let us down and it is in a race car, it does get black after a while, but never ever any brake fade, never ever boiled the oil.
Trevor 57 is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2011, 11:37 PM   #11
Grum
Bringing the Spartan back
Grum's Avatar
Dry refers to brand new fluid out of the bottle. Wet refers to fluid that may have come in contact with water, being hydroscopic the fluid may have absorbed some water molecules which can reduce boiling points.
Think of dry as breaking load, wet as safe working load.
PS, Hi Matt
I hope you and the family had a good Xmas and new years.
East Coast Suspensions
Road - Race - Performance & Prestige Car Service
BOSS 5.4L Silicon hose kits for sale
BA/BF FPV parts for sale
The only negative thing in your life should be camber
Blue Power Racing Enhanced
Chris & Craig - Thanks!
Grum is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2011, 12:54 PM   #12
FLOORED
Race Brakes Sydney
FLOORED's Avatar
PS, Hi Matt
Thankyou and yes i did.
MATTHEW PEARCE
Phone 02 9609 1101
