Goes like an AU
Hey guys. Just wondering. Tried to search this up but didnt find anything. My question is. Will an au automatic bell housing match up to the ef / el t5 manual? I know a straight swap wont work because the bellhouse is shorter. But when I am changing it out. Will the old auto bellhouse fit to the manual from the el? Cheers
1998 Series 1 AU fairmont GHIA:King Springs lowered - Tickford VCT six - Recod transmission - full TS50 body kit - 17'' BA rims - 25% tint - full leather - Exhaust system Soon to be: Extracted (pacey comps) - Flash Tuned - Dyno |
#2 | |||
LIFELONG DJR SUPPORTER
ive herd rumors from various forum members on here that some e series t5s will fit the su and be in the perfect postion and not hit the dash board
Petro-sexual
The E-series extension housing is about 50mm shorter than the AU.
The E-series T5 will fit up to the AU engine when used in an E-series, but I reckon you would be changing the radio station in 1st, 3rd and 5th with an E-series box in an AU. And as above, the auto bellhousing will not work with a manual box. |
Goes like an AU
Thanks guys. Was feeling optomistic. Its all good. I can pick up a manual tranny for the au for 1120. After that I need the clutch assembly, clutch cable? Its that or a full kit from ftg for 1700. What do you guys think?
#6 | |||
Get the FTG Kit. It will be complete. Add to your list Flywheel, pedals.......
#7 | ||||
Back to Le Frenchy
An E-Series Bellhousing can be used with an AU Manual, just extention housing is shorter and shifter is 70mm further forward
GT 335 11.3@124.1mph 383rwkw/513rwhp Forced Performance Tuned |
