30-06-2021, 12:38 PM | #1 | ||
Hi All,
Anyone got any idea on what this high pitch metal on metal sound in the background might be? Its noticeable when im going straight, but worse if i turn left, and pretty much goes when im turning right. Braking doesnt seem to have an impact from what i can tell. Its coming from the front left wheel (passenger side). Thanks in advance (its the noise in the background that kinda sounds like two metal dishes rubbing...? ) https://soundcloud.com/chris-barre-2...V9XZdXjJhH6N-A |
30-06-2021, 09:17 PM | #2 | ||
Could be the cv shaft rubbing against the seal or even the hub? You need it up in the air so you can spin the wheel and listen & inspect.
01-07-2021, 10:57 AM | #3 | ||
it is also possible you have failing carrier bearing in the hub, check play in the wheel when jacked up.
02-07-2021, 03:50 PM | #4 | ||
Hmm, im not too sure what that means/looks like...any further info/youtube help? Cheers
07-07-2021, 11:54 PM | #5 | ||
I had an earlier model focus that had a high pitched sound that changed when turning as well.
It turned out to be a piece of brake pad had fallen out and lodged itself between the rotor and brake shielding. Might be worth checking nothings stuck in there somewhere. |
