Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link |
17-08-2011, 08:29 AM | #1 | ||
Hi there,
A couple of questions. I have Brembo 4 pots on the front of my BA with the standard solid rear disk single piston rears. I attend a few track days a year. I had QFM A1R pads on the rear which on two occassions have crumbled down to nothing leaving steel on steel and damaging my discs after 3 sessions out on the track....obviously I don't want to use these again for the track. I am now thinking I will probably be better off swapping pads in and out for the track days so I can get the most out of a pad and heopefully get 8-9 laps of Eastern Creek in without fade (got 7 on Saturday with the QFMs and stock Brembos on front before fade and destruction). What pad do you recommend for the track? As an alternative is there any pad out there that can be used for street and track that will cope with high speed stops for 9 laps and still have pad material left over for the drive home? The stock Brembos on front have done 2 track days and approx 20000km and while only have a small amount of material left now, have served me extremely well....but some more braking power would be nice from a race pad.... |
17-08-2011, 09:49 AM | #2 | ||
Sandtrap Motorsport
6pot Brembos (monoblok caliper), good fluid, and a good pads
I have the 6 pot front 4 pot rear, stock rotors, stock pad rear, aftermarket pad front (project mu HC+), with high temp fluid ::: I have had no issues around the track since putting high temp fluid in. With old brakes the other week I did a total of 60 hard laps (over 3 sessions) with no brake troubles or fade
'71 Ford Capri -- 510rwkw Barra powered Capri - new race engine being built Sandtrap Motorsport's BF XR6T wagon -- to tow around the Capri ^^^ www.facebook.com/SandtrapMotorsport |
17-08-2011, 09:55 AM | #3 | ||
I have some high temp fluid ready to go in, the Castrol 5.1 stuff, can't remember the name of it though it is very expensive.
Do you run those front pads on the street as well? I am not against a street pad for the track as long as it performs on both. I was looking at changing pads for the track front only hopefully. Rears should be OK if I can find a street/track that won't crumble. |
17-08-2011, 10:58 AM | #4 | ||
BF Ute...
Go the DS performance pads for the track - 2500's I think.
Speaking to Matt, he didnt recommend the Project U pads for the track, although some are using them. |
17-08-2011, 11:23 AM | #5 | |||
17-08-2011, 02:30 PM | #6 | ||||
Race Brakes Sydney
The Project Mu HC+ and the Ferodo DS2500 can be used for both street and track although the DS2500 is not made in the rear DB1376 shape that you need. The AP Racing 5.1 fluid should be enough for your needs and is only $20 a bottle to forum members. I would suggest you upgrade the rear brakes to the larger PBR caliper and 328mm slotted disc and run some DS Performance rear pads in them or even the A1RM's.This upgrade should balance the brakes better. Quote:
We are a Project U pad supplier and can get them when in stock
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop Street to track is what we expertise in Phone 02 9609 1101 sales@racebrakessydney.com.au www.racebrakessydney.com.au |
17-08-2011, 04:27 PM | #7 | ||
Thanks for your help.
I am looking to keep the solid rears I have for now and try another pad....definitely not A1R from QFM as they disintegrate. Waste of money for the track and a waste of a day because they do not last. Is there anything in a DB1376 I can use that will not crumble? As for the fronts with the 4 pot brembos, DS2500 sound good and I have heard good things about them...but they are still a compromise pad. What will a race track orientated pad give me over say a DS2500 on the track? I have heard terms like initial bite etc being very different on road compared to track pads. Any advice on a pad and why would be greatly appreciated. |
17-08-2011, 05:44 PM | #8 | |||
Went with the rear Territory upgrade 328mm Ventilated and recommend it as a cost effective option compared to Brembo rears. Have used front dba400 (transferred too much heat to centre and stuffed 2 sets of front bearings). Now use lighter dba500 with alloy centre hats and recommend them. About to try the new slotted dba style rotor too.
FG XR6T ZF 350,000kms+ Road registered Lap record holder at Wakefield for any Ford or 2wd 4 door, of any make.....ever!! Wakefield 1.07.4 SMP GP 1.48.1 Marulan 43.4 Winton 1.35.4 |
17-08-2011, 06:30 PM | #9 | |||
Race Brakes Sydney
Have you run some heat temp paint on the rears to check what temp they are getting or maybe run the 4000 series rotors as they have heat temp paint and you could see what temperature they are getting too. As far as what rear pads to run you could try the HC+ or we could even cut the DB1376 pad shape from any material you want as we have done this many times over the years for plenty of race cars. A brake pad that is used for track work will have better stopping qualities than a street/track pad that will have comprises to work better on the road. If we can find out why the pad is overheating and disintegrating first then that will help with the choice of pad to run.
MATTHEW PEARCE
18-08-2011, 10:18 AM | #10 | ||
The rear pads were only 3 months old and had covered only 2000km or so, no track days, pretty much brand new. It would make sense that it is heat related as to why they disintegrate, as to when they disintegrate I don't know. My theory would be they get hot and wear out very fast, each session I could see a lot of brake material covering the back wheels, literally pools of dust with small specks of metal were evident from the pads.....much more than the front which take most of the braking effort. I didn't think they should wear out that fast though...given that the front stock Brembo pads have now been through three track days and still have about 3mm material left.
Is there a pad that can be manufactured that will take the heat? Is there an off the shelf product than can be used. I have no issues with having a set of track pads which I change in and out. I think it would be more economical anyway since they should last longer if a little endurance is in the compound...my street pads then will last forever and a day considering how much I drive this car on the street. |
18-08-2011, 10:20 AM | #11 | |||
18-08-2011, 12:10 PM | #12 | |||
Race Brakes Sydney
We have customers who's factory front pads have done the same as your rears and this shows all cars and drivers are different but there are more than enough race pads available to choose for the front brakes.
MATTHEW PEARCE
09-09-2011, 03:01 PM | #13 | ||
Done some research in between then and now. Can you get some pricing for me please?
My car has front Brembo 4 pots and the standard 303mm solid BA rear disk. Project mu HC+ front and rear, Ferodo 2500 and 3000 front only and lastly performance friction 10 Z Rated rear (what are your thoughts on the 10Z given I'm after something to survive track days?). Thoughts on the EBC Yellow for road/track use? I know I am hassling you a lot, but I guess pads are quite expensive so making the wrong choice can be a painful exercise. Thanks. |
09-09-2011, 03:57 PM | #14 | |||
Race Brakes Sydney
Brembo 4 piston 355mm front PBR 303mm solid rear Project mu HC+ Front $440 Rear $375 Front Ferodo 2500 $300 Front Ferodo 3000 $385 ZRated rear - N/A Yellow stuff - Not a fan of them sorry PS. I think you should still upgrade the rears to atleast the larger PBR single piston caliper with the 328mm vented rear rotor.This kit starts from as little a $1000 with dba 4000 slotted rotors.
MATTHEW PEARCE
16-09-2011, 11:24 AM | #15 | ||
I am pretty much settled on the Ferodo 2500s, just one last question. How much do you guys do a front 6 piston setup for? Can these be run with the single pot rear territory type caliper?
16-09-2011, 12:10 PM | #16 | |||
Race Brakes Sydney
MATTHEW PEARCE
16-09-2011, 12:40 PM | #17 | ||
Which disks and pads does that come with?
Can I run them with the standard 303mm rears and move to the 328mm rear setup later on? |
16-09-2011, 01:02 PM | #18 | |||
Race Brakes Sydney
We can supply the 6 piston 355mm front kit and 328mm single piston rear kit from as little as $3100 complete but you can upgrade to slotted rotors,painted rear calipers and even better quality brake pads all at additional costing.
MATTHEW PEARCE
16-09-2011, 01:08 PM | #19 | ||
I will give you a call in the next few days to sort all this out. Thanks for your time.
16-09-2011, 01:12 PM | #20 | |||
Race Brakes Sydney
MATTHEW PEARCE
23-09-2011, 09:46 AM | #21 | ||
Thanks Matt for sending the pads so fast. Great work.
I have a general question for you if you don't mind taking a minute to answer please. I bought some second hand rear territory brakes for a very nice price, but one of the hoses has a block where it mounts up near the body with two brake line fittings on it. One of the lines goes directly in line, the other line is on the side of the block basically making it into a t piece type arrangement. One line in , two out. I have never seen this setup before, what is it for? I can just plug the hole with a brake nipple so no problems there. I am just curious. |
23-09-2011, 10:32 AM | #22 | |||
Race Brakes Sydney
Cars with traction contril do not have this TPiece.
MATTHEW PEARCE
23-09-2011, 10:41 AM | #23 | ||
Cheers. Makes sense now.
