Old 08-10-2022, 02:03 PM   #1
Hannibal1
Hannibal1's Avatar
Default Tickford AU2 XR6 VCT Drive belt (again)
My power steering pump chewed itself up, along with tensioners pulleys and belt.
I can get a 6pk 2515 belt which every one seems to agree is the correct one, but it's a very tight fit, and I will have to use some force to make it fit.There is a 6pk 2530 available, meant for a Mercedes (says Repco). Is the 2515 the go or the 2530. Seems a lot of us have the same trouble, so I'm looking for something concrete to go on, Repco is next to useless on this.
Thanks in advance.
Bobc.
Hannibal1 is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2022, 03:39 PM   #2
Hannibal1
Hannibal1's Avatar
Default Re: Tickford AU2 XR6 VCT Drive belt (again)
Thanks in advance.
Bobc.
Old 08-10-2022, 03:44 PM   #3
sgj66
Run a straight edge across the front of the pulleys to make sure they are running straight if a pulley, idler or pump is on the **** a bit it'll chew stuff up can make em squeal as well if you can get it on its not too tight best of luck
sgj66 is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2022, 05:44 PM   #4
Hannibal1
Hannibal1's Avatar
I should have thought of that, will check it straight away. The drive belt will go on with force, but I didn't want to be to heavy handed with it. I Have probably read to much and got myself confused (again). Will get onto it again tomorrow. Thanks for your advice , cheers, Bobc
Old 11-10-2022, 05:52 PM   #5
Bill M
Bill M's Avatar
Check your parts numbers, http://www.fordforums.com.au/showthread.php?p=5303319
AUII XR6 VCT ute
20 years and still going strong!
Old 23-10-2022, 12:49 PM   #6
Bill M
Bill M's Avatar
Default Re: Tickford AU2 XR6 VCT Drive serpentine belt
Gates AU 6 cylinder Serpentine belt part numbers.
Ford number AJK6995 (NON VCT)
Ford number AJK6956 (Fits VCT)
AUII XR6 VCT ute
