Old 29-06-2020, 08:01 PM   #1
TeamSAXON
TeamSAXON's Avatar
Default Replacing antenna assembly
I've just bought an aerpro ap5, to replace the factory automatic assembly in my xr6 (the antenna snapped off) and just wondering if there's any guides to do this. The ap12 does not fit in the factory mast assembly, so I had it swapped for the full aerpro assembly. To be clear this is not a *mast only* swap. Is it simple to do just by disconnecting the wiring of the factory assembly? I note on the aerpro website it says this assembly is for converting lock down to automatic, so would the wiring have a harness?
Current daily:
AUIII XR6 Silhouette 164kW
Sedan
383xxx kms
Previous drives:
AUII XR6 Silhouette 172kW VCT sedan 256xxxkms
AUIII ForteWinter White 157kW sedan 201xxxkms
TeamSAXON is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2020, 08:40 PM   #2
foxtrot3
foxtrot3's Avatar
Default Re: Replacing antenna assembly
Hi. The AP5 comes with a bracket that bolts to the base of the antenna and picks up the factory mounting stud below the antenna on the inner guard (you may need to supply a 6mm nut). Fitting is easy as pie, turn wheels hard left lock and remove mudflap and the back of the plastic stone shield, use a 10mm socket to remove the 6mm bolt and pull the antenna down from the guard. go inside the car and disconnect the antenna cable near the end of the dash and then from outside ease the rubber cable gland out of the hole in the inner guard. mount bracket onto motor with the earth wire from the motor as well and push the antenna up into the factory plastic mount in the guard and sit the bracket over the stud under the antenna. Use the factory bolt to earth the antenna pole (short wire attached near the top of the antenna) to the lockdown mounting bracket holt. pass the antenna cable and 2 wires into the car ( may need to re-use the original cable gland) and plug in the antenna cable. Run the red and the green wires to the radio and using the memory wire provide a feed for the red wire and use the blue wire from an aftermarket radio or the red/blue antenna trigger wire from the factory radio (check with a test light) to the green wire on the antenna. Check that it works by turning on the radio and adjust the bottom bracket in needed and refit the trim and mudflap. Beer time. Cheers MD
PS: never seen a factory power antenna that didn't take an ap12 there was another antenna that replaced the factory full auto unit that is NLA, it might pay to ring around and see if anyone has some old stock. Cheers
HI
I'M MICHAEL
Old 29-06-2020, 10:09 PM   #3
foxtrot3
foxtrot3's Avatar
Hi. The replacement for a factory power antenna is AP3 but its NLA. Cheers MD
HI
I'M MICHAEL
Old 29-06-2020, 10:14 PM   #4
TeamSAXON
TeamSAXON's Avatar
Unfortunately already purchased the ap5
Current daily:
Sedan
383xxx kms
Previous drives:
Old 30-06-2020, 08:07 PM   #5
TeamSAXON
TeamSAXON's Avatar
Run the red and the green wires to the radio and using the memory wire provide a feed for the red wire and use the blue wire from an aftermarket radio or the red/blue antenna trigger wire from the factory radio (check with a test light) to the green wire on the antenna. ...PS: never seen a factory power antenna that didn't take an ap12 there was another antenna that replaced the factory full auto unit that is NLA, it might pay to ring around and see if anyone has some old stock. Cheers
Where would one find the memory wire and factory red/blue trigger wire? Are they a part of the the wires running out of the headunit? .. As the old plug which was connected to the factory antenna wires (red and green) has green/yellow (power) and red/white (unsure?)
The motor on the ap5 is not making any noise when I tested it on a battery
Current daily:
Sedan
383xxx kms
Previous drives:
Thread Tools
Display Modes
