05-04-2020, 02:08 PM | #1 | |||
Cougar King
Thank you, I appreciate the kind words The Jaguar engine I believe is a slightly different setup to the standard Escape and Tribute engines, due to the VVT (Or so I've been told). There is actually a guy on the newcougar forum who is attempting the Jag X Type Engine and AWD swap but I'm not sure he updates very frequently. You are right about it not being a straight swap, but other than the modification I listed, it is pretty much plug and play. The longest/most difficult part of the project is sourcing the parts as 95% will have to come in from the States or UK unfortunately. I haven't fully opened her up as yet, as I'm still breaking in the engine (New piston rings, new valve springs, timing gear, gaskets, clean up, etc) so she's still on slightly heavier oil. But you can definitely tell she pulls massively more than the 2.5l, especially when she's above 3000rpm. Half throttle feels like full throttle on the 2.5l for me. Speaking of Tickfords modifications, I was curious when I bought my Eibach back in 2017 the injectors on her I found to be from a Ford Crown Vic 4.6l V8 installed (Cross-referenced the numbers), they are orange ones not the standard white. So I was wondering whether Tickford did intend to make more power with these injectors (If your old one had them too), as I find it hard to believe the previous owner put them on as the whole car was basically unmodified (Apart from the Tickford gear) WildRacer
00 Eibach Cougar Mods: Escape 3.0 V6 ST220 UIM and LIM NPG Fuel Adapter California Clutch Stage 2 Disk and PP ST200 Flywheel Torsen LSD Updated Shift Forks ToyoSport Exhaust Headers Custom 2.5" Exhaust dual BAT 21mm RSB PRT Heavy Duty rear drop links Energy Suspension Polybushes all around Eibach Suspension Eibach body kit 01 Gauges 01 Steering Wheel Aluminium Sports Pedals Sony Double Din HU ST200 Airbox ST200 TB Direnza ST200 Aluminium Radiator Goodridge Brake Hoses |
09-06-2020, 06:59 AM | #2 | |||
Mine came with white injectors and I have seen some SVTs and ST24s with green injectors but haven't heard of orange ones. Cheers
Ex Cougar - 00' MTX 2.5L (Limited edition Eibach Cougar); Dark Green Tourmaline; Lowered with Eibach tuned suspension from factory; SVT UIM, LIM & Throttle body; Supercat 2.5" dual exhaust with twin pipe quad outlets; Custom headers; Custom coloured instrument cluster; K&N Apollo CAI kit; Calibre oil catch can. Now driving a Lexus RX 450h. Your guess is correct that I am a family man now. |
