03-08-2020, 11:28 PM | #121 | ||
Maybe not but it's towed a 2 tonne boat before my ownership no worries so I'm getting frustrated on these technicalities that don't seem real at all.
03-08-2020, 11:37 PM | #122 | ||
Rob
Not that small. As mentioned, European vans are often designed to run around 5% ball weight. They are reasonably light as well. You could find a van around 1.5t that should suit your requirements. As long as it's correctly set up it should be fine.
Get on caravansales.com.au and have a search.
UA2 TREND 4WD BI TURBO |
03-08-2020, 11:42 PM | #123 | |||
10% is 140. My bar says 90kg. (2200 braked vehicle) Hence I can't get it (according to here, others say no problem at all like Tassie F100 |
03-08-2020, 11:44 PM | #124 | ||
Probably the best small van around that weight would be the Avan A frame fold down.Around 3.5 metres long 750-800 kg, different interior layouts,as in either single bed each end or double at rear.Great litle van,but not real cheap.
04-08-2020, 12:22 AM | #125 | ||
i,m not sure of your year but i googled r36 passat tow capacity and got this.
https://www.google.com/search?rlz=1C...sclient=psy-ab and https://www.carsguide.com.au/volkswa...-capacity/2009 understand that unbraked is with NO brake assist for trailer, so this limits you to 750kg if you have have electric or hydraulic brakes then the tow capacity is greatly increased. but i quickly looked at those numbers and they look to match or close to your caravan. the 2009 r36 has a maximum braked capacity of 2200kg.(you install and electric brake controller in the car) . if your van is 1400kg , your well under the maximum limit. |
04-08-2020, 12:32 AM | #126 | ||
that bar is for towing box trailers around.
if your tow capacity numbers stack up, and it looks like they do. get a heavy duty bar. we did it all the time on the falcons, some towbars were to small so just get a high rated one. and an electric brake controller. |
04-08-2020, 12:50 AM | #127 | ||
As previous mate my handbook says 2200 braked.
The towbar itself itself says 1500 braked (Haymen Reece) The Tow ball limit is 85 0r something stupid which is causing all the problems. I have no doubt it will pull a 1400kg van easily. Legally I was told I can't as Euro cars rate towbal capacity very low |
04-08-2020, 01:52 AM | #128 | |||
Rob
Legally, you can't tow that van if the ball weight is higher than what VW specs are, which it appears it is. There will be a reason why VW have put that limitation there. Its not just to annoy people that want to tow. It doesn't matter if it has towed heavy loads previously, or if other members say 'it will be fine'. What I am suggesting is to just search for a different van that suits your needs and meets the specs of the car. Otherwise, look for a different tow vehicle as well. Legally, that's your options. If you disregard the law, you may well find the car will tow the van you want fine.... If you want to take that chance, well thats up to you.
04-08-2020, 09:32 AM | #129 | ||
I'd be worried about the durability of the VW wheels with the excess weight.
They don't have a reputation for strength even without a load. Google cracked vw wheels... I knew someone who kept cracking Touareg wheels while towing.
04-08-2020, 09:53 AM | #130 | ||
So you are trying to say that it is alright to fill the back of the car with shopping and put 2-3 100 kg + passengers in the back seat, but you will crack wheels if you put 140 kg on the towbar.
04-08-2020, 10:12 AM | #131 | ||
The static ball load on the tow bar is just that when the care is not moving what comes into play is the dynamic load it can increase many times the static load due to variations in the roads the manufacture take this into account when setting these limits the cars chassis is just not suitable for loads higher than recommended.
04-08-2020, 10:22 AM | #132 | ||
Buy one of these..
https://www.ebay.com.au/itm/TOWSAFE-...frcectupt=true Go & see what the Actual Ball weight is of the van.. Maybe if you Load all your Luggage ect to the rear of the Van, You'll be able to get It down to 90Kgs... |
04-08-2020, 10:59 AM | #133 | |||
to me i doesn,t make sense, the car can tow 2.2t with a ball weight of 90kg, thats less than 5% of 2200kg. imo, at least 10% ball weight would be safer than 5% for towing, in fact some float manufactures would set there axles further to the rear of the trailer in a effort to aid towing balance. in contrast, a finely balanced trailer is more likely to dance around behind the car, possibly aiding a jack knife situation. european roads are better so that will help the trailer - car balance. i think its good that your trying to figure it out, i towed horse floats for 30+ years and in all that time, me and no one else used to check ball weights, and the police didn,t check either. but that didn,t mean we didn,t care, as we knew what that falcons could take, load wise. horse owners would always chat and compare how well there floats would tow, and float and car towing combinations. if i was in your shoes , i would tow the van. if your concern for ball weight ,you can internal adjust ball weight by moving weight around in the van, forwards or rearwards, or add a water tank. i did say before, buy a towbar weight tester. i still don,t own one. https://www.campsmart.net.au/tow-bal...kaAhp2EALw_wcB https://www.towbars2u.com.au/passat Last edited by Pis-ton broke; 04-08-2020 at 11:16 AM. |
04-08-2020, 11:24 AM | #134 | |||
The seller then advised he couldn't sell it to me (fine). Then the local towing company said that's nonsense and at 1450kgs braked my car would pull it easily and tow ball weight vastly underrated and it's never checked anyway. Hence I'm so confused. |
04-08-2020, 11:36 AM | #135 | ||
Rob
The manufacturer sets the limits for a reason. The rear axle will also have a weight limit. These ratings will be in the owners manual or available online or from the manufacturer.
04-08-2020, 03:34 PM | #136 | ||
Seems to me, as a late-comer and an outside observer, like there is a little confusion about what the towing limits are that are applicable and that some on here may be in need of some further reading to clarify the terms and requirements.
I'm sure other state organisations have similar pages, but perhaps this link will explain a little more: https://www.racq.com.au/cars-and-dri...specifications E: this article also has a good diagram and description: https://magazine.rvdaily.com.au/rv-d...w-weight-legal
Labels are for jars, not for people. Life is a journey, not a destination. ~~~~~~~~~~~~~~ Daily: 2013 FGII EcoLPi in Winter White Play: 2015 FG X XR8 in Emperor Show' N Shine thread Gone, but not forgotten: 2015 SZII petrol Titanium Territory in Emperor Last edited by FoxtrotGolfXray 5.0; 04-08-2020 at 03:43 PM. |
3 users like this post: |
04-08-2020, 04:12 PM | #137 | |||
Experienced Member
Any caravan that has a tare ball weight over 90 kilograms stamped on its ID plate effectively stops you from towing it legally regardless what others here are telling you. It really sux having a decent towing capacity to be hamstrung by your light tow ball rating designed by the car manufacturer. |
04-08-2020, 04:31 PM | #138 | ||
After this thread, I decided I'd better check out my Mondeo.
I have the diesel with the heavy duty (1,600kg) towbar. The figures I got from the web were many and varied. A quick check of the owners manual put my mind to rest; 1,600kg tow capacity (braked) with 160kg nose load, but consideration to be given to total rear axle load. Now normally, I would tow around the 750kg (unbraked) load, but the manual says to use load levellers with the HD tow setup. This sets up an interesting dilemma; at what point do you "have" to use load levellers?
Steve Current rides 2012 Mondeo Titanium wagon (TDCI) Moondust silver 2016 Focus Trend, 1.5ecoboost, 6sp manual. Frozen white Previous 2004 Berlina Wagon (LS1) Vespers Blue 1995 Camry 2.2, white 1971 Ford Fairmont wagon 302w, C4 Polar white 1971 TC Cortina, 2L 4sp, Ermine white |
04-08-2020, 07:58 PM | #139 | |||
Rob
Having said that, they are more about ball weight than overall weight and trailers come in all different shapes and sizes so they can't really put an actual figure on it. Some trailers, like some horse floats have less weight up front while trailers like hard floor camper trailers have substantial ball weight due to the axle being rather rearward. I'd say it would be based on how much your vehicle drops once the trailer is hooked up that determines whether or not you need to use them. I'll check my manual once I get home and see what that says.
04-08-2020, 09:08 PM | #140 | ||
Prydey.The reason different trailers have different axle configurations is so that when loaded the weight distribution is correct.A caravan is set up in the factory with very close to even weights front and rear,wheras a horse float has the wheels quite a bit towards the rear because when loaded with horse(s)the bulk of the weight is near the centre and rear of the float because of where the legs are fitted to the animal.Likewise boat trailers because of the weight of the outboard or engine and drive have the axles closer to the rear.As another poster said yacht trailers have the axles near the middle because there isn’t any real weight difference between front and rear
04-08-2020, 11:17 PM | #141 | |||
Experienced Member
04-08-2020, 11:21 PM | #142 | |||
Experienced Member
PS: Yes it does help the sag but you should really upgrade the suspension for sag issues. |
05-08-2020, 12:10 AM | #143 | |||
I know it can tow it easy (having the quality Haymen Reece a reason I bought it) |
05-08-2020, 01:24 AM | #144 | ||
You want to drive a Passat AND tow a Caravan. I'm starting to see a pattern...
Time to Make the Hippies Cry Again |
05-08-2020, 02:04 PM | #145 | ||
05-08-2020, 02:25 PM | #146 | ||
I guess the upshot out of this, MT, is that, whilst you know your vehicle has been used to tow something heavier than what the car and tow bar were designed for and there doesn't appear to be any consequences as a result, was there any longer term damage caused as a result or could it make the car more susceptible to damage should you tow with it in the future, even if you follow the manufacturer's requirements here on out?
Labels are for jars, not for people. Life is a journey, not a destination. ~~~~~~~~~~~~~~ Daily: 2013 FGII EcoLPi in Winter White Play: 2015 FG X XR8 in Emperor Show' N Shine thread Gone, but not forgotten: 2015 SZII petrol Titanium Territory in Emperor |
05-08-2020, 05:02 PM | #147 | ||
Oh, and the other thing to add, for the previous owner of your car, is that there is a saying related to this:
just because you can doesn't mean you should.
05-08-2020, 10:24 PM | #149 | ||
John Cadogan's YouTube Auto Expert from today is very relevant and is actually one of his more watchable videos https://www.youtube.com/watch?v=4Uj5b4lWyXM
regards Blue |
05-08-2020, 10:27 PM | #150 | ||
