14-09-2014, 03:17 PM | #1 | ||
Hi,
The clutch pedal of my ford focus 06 is stuck, my car is currently not drivable. Fixing this requires a new slave cylinder, which requires the gearbox to be taken out and a possible new clutch. A mechanic has quoted between $2000 to $4000 to fix, which I think is a bit excessive. Do you guys know any Brisbane clutch repairers that can do this for cheaper? |
15-09-2014, 09:00 PM | #2 | ||
dont know of any repairers but..... you will have to do the clutch as well as the slave cylinder. no point in just doing the slave while the box is out. these also run a dual-mass flywheel and that is a throw away item so hence the high price tag
27-09-2014, 12:07 PM | #3 | ||
If its an xr5 turbo the book time is just shy of 5 hours labour
Its what we charge. - Remove them often as we do Quaife LSD upgrades. |
30-09-2014, 06:05 PM | #4 | ||
Please read my post from today regarding DMF failure if you haven't already repaired your car.
Cheers |
