Ok I know there's some aircraft buffs on here, so what is this... two of these flew over and landed at the local base.
I'm 99% sure what it is, just want someone to confirm it. ![]() Last edited by MAGPIE; 01-06-2005 at 02:45 PM. |
Beats me why I posted it in this section
![]() can a mod move it to the Bar please |
Fairmont Ghia
Boeing C-17 Globemaster III!
For interests sake, our earlier H model Hercs have been considered to be replaced by a few of these. Tim |
I was goin to say hercules. And they are absolutely massive.
#5 | |||
FORMERLY TX3DUDE
antonov>?
hey,
i know there are two huge planes called the Galaxie and the Starlifter. This one looks like the Starlifter. It wouldnt happen to be on an RAAF base in Richmond would it? I know heaps of those huge planes pass through there every now and then.
Glenn 1980 mk2 Escort |
Fairmont Ghia
I am definitely telling you guys, it's a C-17 Globemaster III. I work in the air force, I should know.
It's not a Starlifter nor a Galaxy, the Starlifter has a longer sleeker fuselage and completely different aeros. And yes, all three of these planes have been seen around Richmond, though I have been on exercise in Darwin with all three as well. They get around. Tim |
Dual O2 sensors
Timmeh stomps on the competition
Black 1990 300zx Twin Turbo 5 Speed Manual ![]() Blue 2004 Mini Cooper S 6 Speed Manual - Yes, thank you Amanda. I realise now that you updated my signature to include your car. ![]() |
#9 | |||
#10 | |||
They're an impressive piece of aircraft, I saw one when i went to Avalon Airshow back in 2001. The Short-Field Landing and Reversing techniques are paticularly impressive.
1998 Ford Fairlane - 4.0L
18x8 RJR rims - Tinted - King Suspension - 2.5" D&T Cat Back Exhaust |
Foo Fighter
Pretty cool looking plane, didnt realise we had cool looking military planes in action in NZ anymore...
#12 | ||
Lane HO
I'm amazed by how many people know their aircraft here lol.. Definitely as Timmeh said. I don't believe that is at Richmond NSW, although they are there often. There are too many trees in the background (and green grass?) for it to be Richmond lol.
As said, Starlifter is basically smaller, Galaxie is the bigger mofo. |
#13 | |||
Foo Fighter
#14 | |||
Virtuous Bogan (TM)
![]() Join Date: Jan 2005
![]() And no offense, but I dont even think the Aussie SAS would need a plane that big. Mighty impressive though.
#15 | |||
LPG > You
Antonov AN124 Ruslan ![]() Antonov AN225 Mriya ![]() Antonov AN124 Ruslan (World's second largest aeroplane) Wing span: 240 feet (73 metres) Length: 227 feet (69 metres) Wing area: 6,760 sq ft (628 sq metres) Gross Weight: 890,000lbs (404,545kg) Engines: 4x 51,590lb (23,450kg) DT-18T Antonov AN225 Mriya (World's largest aeroplane) Wing span: 290 feet (88 metres) Length: 275 feet 07 inch (85 metres) Wing area: 10,280 sq ft (955 sq metres) Gross Weight: 1,300,000lbs (590,909kg) Engines: 6x 51,590lb (23,450kg) DT-18T Just to compare them to two well known huge planes... Boeing B-52 Stratofortress Wing span: 185 feet (56 metres) Length: 157 feet 07 inch (48 metres) Wing area: 4,000 sq ft (372 sq metres) Gross Weight: 450,000lbs (204,545kg) Engines: 8x 8000lb (3636kg) J-57 and... Boeing 747-100 Jumbo Jet Wing span: 195 feet 08 inch (60 metres) Length: 231 feet 04 inch (70.5 metres) Wing area: 5,500 sq ft (511 sq metres) Gross Weight: 850,000lbs (386,364kg) Engines: 4x 50,000lb (22,727kg) P&W JT9D Some big planes....
LPG Lovers Association President & Member #1. ![]() ![]() |
#16 | ||
Foo Fighter
I like it, the design looks really nice....
#17 | ||
More info in the C17 for the aviation buffs (like me!)
http://www.airforce-technology.com/projects/c17/ Very impressive transport aircraft. Aus should consider replacing the Hercules with these. |
#18 | |||
What are the big Black Russians ones called ?? ![]() |
#19 | |||
No offence but what qualifies you to judge ![]() By the way there's two of these suckers, so there :hihi: Last edited by MAGPIE; 01-06-2005 at 04:57 PM. |
#20 | ||
#21 | |||
These planes don't just carry people. They can transport supplies, vehicles and even tanks as well. |
#22 | ||
Cesna? Piper Pup?
#23 | |||
Fairmont Ghia
There's alot of big Russian planes, can't think of any all painted Black though, as being their only distinctive feature. Tim |
#24 | ||
Hmmm Gold!!!
the antinov was actually in brissy dropping off some new helicopters on monday, , its HUGE!!! it pulled up outside the window at work.
1990 EA Series 2 Fairmont, Low Springs and shocks, 17 x 7 Advanti Flash Mags running on Falken rubber ![]() Now Sporting - OED666's 202+ RWHP engine!! :dj: fully
#25 | ||
Actually it is a VE commodore prototype cleverly disguised with a 3 wings off a Chapel St Hyundai and 4 sooper doof doof subwoofers (2 on each side)
Note how they have extended the idea of nostrels (VZ Monro) into a fully fledged black snorkle nose. Also note after all the bitching about the lightweight spare tyre the new model has LOTS of spares |
#26 | |||
LPG > You
#27 | |||
Hmmm Gold!!!
#28 | |||
LPG > You
#29 | ||
Errr, unless they were moving Landies the SASR wouldn't need more than a few Blackhawks.
#30 | ||
Hmmm Gold!!!
it must have been the AN124 then, only 4 engines. They took one helecopter and about 4 trucks worth of equipmet off it. The same plane was in Brissy about 6 months ago too, they took of 2 choppers and a shite load of equipment
