24-06-2007, 08:28 PM | #211 | ||
Lukeyson
I have a couple.
(1) Is there a part number for the BA ICC Harness from BEM interface J4 - ie, the harness that always drives the Remote Key Receiver, but also has variants that drives the ICC Video input, Cabin Temp Sensor and Clock? I've searched with most of those as keywords without much luck. (2) Is there a Part Number for the courtesy light with integrated switch that you see over the rear seats in BA XR's, and in behind the Sunvisor in Fairmonts and above? Once again, keyword searches have drawn a blank. (3) In your database I found mention of the part number AU2 17E704 A 'MODULATOR MIRROR CTR, WITH MEMORY MIRROR' when searching on the word 'Mirror' and selecting BA. Since I'm interested in adding Memory Mirrors with Reverse Dip - is there any chance that anyone knows what this module is and what it does? It's not listed in the BA Workshop Manual anywhere. I've often been curious as to how the Memory Module under the seat could control the mirrors, and have been suspicious that there's another undocumented controller somewhere - and this is the first possible evidence of something like that. Luke
If the human brain was simple enough to understand, we'd be too simple to understand it. |
05-07-2007, 12:14 AM | #212 | |||
Chairman & Administrator
(2) There are 2 seperate parts that make up this lamp but it is available as a kit: BA 13A701 A LAMP ASSY - 13.40 (3) You are correct in your assumption as it is only fitted to vehicles with Memory function. The little pic below is it in diagrammatic form. Cheers Russ
Observatio Facta Rotae
28-07-2007, 08:30 PM | #213 | ||
The Beast
Hi Russ , a mate of my has got a au Ford trying to fit a Au Hawk front grill, holes line up but there is a gap of about 2-3 inches .From bonnet to grill is there another part he needs?THANKS.
30-07-2007, 02:31 PM | #214 | |||
AU2 8C104 A Moulding, Radiator Grille 52.10 Cheers Russ
30-07-2007, 06:46 PM | #215 | ||
The Beast
Thank You So Much Russ . Cheers & Beers,
13-08-2007, 08:41 PM | #216 | ||
Hi Russ
The plastic guard type thingie, under the front lower bumper has split, makes a load of noise. Question is do you have a part number & price, and would a second hand unit do. Normell
Every day above ground is a good day. Still Drinking & Driving, But Not At The Same Time |
13-08-2007, 11:33 PM | #217 | ||
I presume you are referring to the undertray that sits under the engine?
I can't find a listing for it but a 2nd hand one would be fine I would think - they don't seem to last very long anyway and it is better to use screws and speed nuts rather than refitting them with the bloody useless xmas tree clips. Cheers Russ
11-11-2007, 03:46 PM | #218 | ||
Sly like a G6
I think it's called a "deflector", kinda rings a bell, I've had 4 in 320,000km & have given up replacing them for now.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
11-11-2007, 04:02 PM | #219 | |||
19-12-2007, 01:51 PM | #220 | |||
Me AU's cheap and clean.
THE MIGHTY MANLY WARRINGAH SEA EAGLES Daily - 2013 SR5 Hilux Toy - 2000 AUII Falcon Toy - 2010 Kawasaki ZX10-R Her's - 2017 Camry SX |
19-12-2007, 08:16 PM | #221 | ||
No - just the cover and insert.
Russ
30-01-2008, 07:28 PM | #222 | |||||
AU Falcon Man
also is this the red stripe in the doors of the AU XRs...? Quote:
2015 SZ MkII Ford Territory TS Aero Blue, RWD Petrol, Standard Sat Nav. 2013 TF Ford Kuga Ambiente Panther Black, AWD, 6 Speed Auto, 1.6lt ecoBoost Turbo Petrol. Was 2012 FG Mk2 Ford Falcon XR6 Swift Green,6 Speed Auto, Stock... 2001 AUIII Ford Falcon Forte Genuine T2 TS50 bodykit, 18" BF Cobras, Boge and Eibach Suspension and Complete AU2 Fairmont Ghia Interior 1994 EF Ford Fairmont Gun Metal Grey, Lumpy Straight 6 Last edited by cam.giles; 30-01-2008 at 07:37 PM. |
03-02-2008, 01:42 AM | #223 | ||
AU Falcon Man
anyone...?
2015 SZ MkII Ford Territory TS Aero Blue, RWD Petrol, Standard Sat Nav. 2013 TF Ford Kuga Ambiente Panther Black, AWD, 6 Speed Auto, 1.6lt ecoBoost Turbo Petrol. Was 2012 FG Mk2 Ford Falcon XR6 Swift Green,6 Speed Auto, Stock... 2001 AUIII Ford Falcon Forte Genuine T2 TS50 bodykit, 18" BF Cobras, Boge and Eibach Suspension and Complete AU2 Fairmont Ghia Interior 1994 EF Ford Fairmont Gun Metal Grey, Lumpy Straight 6 |
03-02-2008, 03:17 PM | #224 | ||
On your first point the answer is no. That is only the conversion kit.
You are correct with the body side mouldings. The front bar transfers are not the moulding as it is listed on it's own but it's not clear from the diagram what they are. There are a similar set for the rear bar. Cheers Russ
03-02-2008, 03:52 PM | #225 | ||
Hey Russ, can you check if floor carpet is still available for AU XR ute or sedan?
Also price please. cheers, phil. |
03-02-2008, 11:21 PM | #226 | ||
Sedan appears to still be available:
ER F13000 A6 CARPET, 4 DR SED, FORTE/FUTURA/S/XR, WARM CHARCOAL $ 664.30 Can't find a listing for the Ute but it is likely to also be available at about half that cost. Cheers Russ
04-02-2008, 12:16 AM | #227 | ||
Thanks Russ.
13-02-2008, 11:07 PM | #228 | |||
18-06-2008, 02:13 PM | #229 | ||
EL GT 082
Does anyone know if the little T-Series badge that is in the centre of the dash on automatic TE50's, TS50's and TL50's (excluding T3 TE50) is still available and what the part number is? Thanks.
18-06-2008, 07:18 PM | #230 | ||
The part number is
TAU F04460 A Sadly no longer available (see your other thread). However if you can get one ... get two! I'll have one please. BTW the list price was $27.90 the last time I bought one. |
09-11-2008, 05:22 PM | #231 | ||
Hi
I need to know the part number for the item in the picture and price if you know. Its for a au1 Falcon Sedan. The left hand side front cover fell off after my last service. Thanks Jeff
:eclipsee_ MY CAR :eclipsee_
09-11-2008, 06:57 PM | #232 | ||
ER F001A06 A DEFLECTOR AIR FRT RH, (-)XR - about $13
Cheers Russ
29-04-2009, 05:12 PM | #233 | ||
[ 5L ]
anyone know the part number for the REAR IRS MOUNTS?
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline) www.ignitionimages.com
30-04-2009, 06:19 PM | #234 | ||
If they are the ones I am thinking of then:
AU2 5T120 B (RH) AU2 5T121 B (LH)
09-01-2010, 01:52 AM | #235 | ||
The Villan
Whats another name for the side guards?
New addition! 2010 FG XR50 Turbo in Lightning Strike The PX Ranger has arrived! XLT Metropolitean Grey Previous Ride - 2007 BF MK II XR6 in Lightning Strike
09-01-2010, 02:58 PM | #236 | ||
When you say side guards I presume you mean the bodywork at the front side? If so, they are referred to in Ford speak as fenders.
Cheers Russ
03-04-2010, 04:04 PM | #237 | ||
I have a set of ACL Duralite pistons that came out of an XD motor that I built years ago. The engine had a crack in the block and was pumping oil into the water. Very dissapointing at the time, but does anybody know wether I can uyse these pistons in an AU block?
30-05-2010, 01:04 PM | #238 | ||
fordmuscle
Hi I just purchased a AU XR8 SERIES 2 I'm wanting a set of headlight protectors any idea on price of new or second hand thanks fordmuscle
30-05-2010, 01:19 PM | #239 | ||
ER 13000 B HEADLAMP PROTECTORS, FITTING TOOL MUST BE USED, XR - around $100 for the factory units.
Cheers Russ
30-05-2010, 01:33 PM | #240 | |||
T3 TS50 075
Cheers John My car T3 TS50 #75 Blueprint manual 1/4 mile 13.38 @ 102.97 mph TS 50 = 237.1 rwkw |
