31-08-2009, 09:28 PM | #181 | ||
Owner Of The Evil ST
Thanks mate, you are a legend
01-09-2009, 05:48 PM | #182 | ||
i know this will seem probably a bit of a stupid question but. ive been looking and was wondering about using the pipe that Ben85 used on his intake paired with an Apexi Universal Power Intake Filter, along with the apexi sizing adaptor.
Pipe: http://purchasenet.com.au/shopping/a...ose-p-871.html filter: http://www.modyourcar.com.au/apexi-u...d-85mm-id-p511 Adaptor: http://www.modyourcar.com.au/apexi-p...nch-neck-p4844 Im trying to go somewhere a little bit different hence the jdm. just throwing it out there to see what u guys and ur perpetual wisdoms think of it as a set up.
2004 Ford Fiesta lx 3dr 3M Black Tint, NGK Laser Platinum Sparks Alpine W203-CDE Double Din iPod Connected Head Unit, JL Audio 5x7 Front Speakers. More To Come.... Eventually. : |
01-09-2009, 11:19 PM | #183 | |||
Because i dont think the pipe i bought will go over the intake manifold (its too high).
2006 WQ Fiesta Zetec Sea Grey Interior:- MOMO Blue Leather Gear Knob, Window tint, Scuff Plates, ST Black & Blue Leather seats, Soundstream Amp & 5x7 speakers, Sony Headunit, Pioneer sub & Amp. Under the Hood:- Superchips ECU Flash Tune, Denso Iridium plugs, KV85 Magnecor Leads, BMC CDA Induction. Exterior:- Spoiler, clear side repeaters, Lowered (35mm) King Springs, Whiteline 22mm Rear sway bar, 2" cat back exhaust with a dual conversion, Konig 17" Hotswap with Kumho Rubber, HID's. |
02-09-2009, 07:27 AM | #184 | ||
04 fiesta zetec
There's no real way of knowing until you measure everything up and see whether things will fit...remember... measure twice, cut once!
'04 WP Fiesta Zetec moondust-silver. Exterior: 16" MP3. zetec bodykit w spoiler. Red brake calipers. Colour-coded trims. Gun-Metal grey 'ZS' side stripes. Tint. Phillips Diamond Vision beams w white LED parkers + n.p. lights. ST repeaters. Euro wipers. Interior: Colour-coded trims. ST leather gear knob w leather gaiter. Brushed Aluminium pedals. Scuff Plates. Performance: Denso Iridium sparks. CAI. 2" cat-back with Hi-tech stainless muffler & dual chrome tips. Lowered. RSB soon! |
09-09-2009, 10:28 AM | #185 | ||
HI guys
With these pod filters you are using are you removing the panel filter or using both? and if you are removing the panel filter do any changes need to be made? other than adding the pod. Thanks |
09-09-2009, 08:57 PM | #186 | ||
04 fiesta zetec
If you have a look at the engine then yes, you need to change the setup when using a pod filter. You totally remove the panel filter and 'air-box' and replace it with any of the setups in this thread. therefore you don't use both.
10-09-2009, 11:24 AM | #187 | ||
I thought would be the case....that will be my next project.
10-09-2009, 03:49 PM | #188 | ||
Just a thought,
Looking at the stock intake configuration with the engine cover forming part of the airbox with a panel filter inside it and the induction pipe going into the engine cover deliver air through a pipe that goes back down into the throttle body, I can easily make a conclusion that this setup is crippling performance, simply becuase the air has to travel through heaps of piping also lowering its velocity (speed it travels at). After removing the engine cover and installing a pod filter, I've essentially made the journey shorter for the air going in. The engine feels more responsive in the lower rev ranges but my question to you all is: Are there any real-life power figure increases? Has anyone actually put their fiesta on the dyno after installing a CAI (boxed in or not)? What is the power figure for a stock fiesta and what kind of increase would a efficient Cold air induction setup produce? |
10-09-2009, 07:24 PM | #189 | ||
04 fiesta zetec
there's probably a thousand threads about this... We've all been there done that, some have simliar piping that stock air-box but with a pod instead... some take the shorter route over the headers. to answer the power increase, i'd say with exhaust work like some of us here... anywhere from 1-5kw increase... AT BEST. Mainly it's better throttle response and smoother top end.
10-09-2009, 09:36 PM | #190 | ||
Da Shifty One
+1 for mainly better throttle response and smoother top end. And apparently a Turbo Sucking sound.
I had my WP 1.6L Auto dynoed. 61.4ATW with 2 inch Redback Cat Back + K&N Apollo CAI. A friend had his WQ 1.6L with the same exhaust minus any air filter mods 56.3 ATW. These were done on the same day.
2013 Ford Fiesta ST - Frozen White - AU 0072/XXXX
- Mountune ST180 Intake Hose - Mountune Quick Shifter - J1 ST180 MAF Adapter - K&N Apollo CAI - Triple R Front Splitter - Richbrook Shorty Aerial - DMB Gel Overlays - LED Interior Bulb Upgrade - |
10-09-2009, 09:56 PM | #191 | ||
Lmao at turbo sucking sound,but your rite it does suck some.
http://www.facebook.com/pages/Steve-...861161?sk=wall http://www.ambient-aperture-photography.com (PLEASE DONT HESITATE TO PURCHASE MY WORK) http://www.flickr.com/photos/stevemack |
07-12-2009, 09:35 PM | #192 | ||
Thought i would bring this post back from the dead anyone else experimented with induction kits in there fez ?
08-12-2009, 01:33 AM | #193 | ||
lol all these setups are making me seriously lol...I cant believe the position of the intake manifold and throttle body on these things..Yall be better off pointing the intake system towards the front bar grill and wedging a mini conestac filter in there. Not only would u get CAI but you'd get great Air compression as well.
It's why i love the old model festiva's especially the 97's. Fantastic to work on!
Proud Owner of a 97 Festiva WD. www.FordAspire.com <--Find Her here All Festiva's, All Aspires(US-VER), all the time! |
08-12-2009, 02:31 PM | #194 | ||
04 fiesta zetec
haven't done much more experimenting NJM586... cleaned + oiled the filter! thats about it.
I'm lol'ing that you'd begin even modifying a Festiva... each to their own though.
08-12-2009, 04:49 PM | #195 | ||
pullin 290horses? i gotta say, ill stick to my own. :P I like the shape.
09-12-2009, 04:38 PM | #196 | ||
04 fiesta zetec
i'm pullin 295horses... with added 'ZS' side stripes. Cant imagine what you get with the decal on the side of your car ;)
10-12-2009, 05:00 PM | #197 | ||
haha, yea true if i had a fiesta with already built in zetec i'd be fast too...
Not many people out there who actually put in the spanner time and rebuild the 1.5's. B5T 16v. mine isnt exactly doin 290horses. But im happy to say at 7psi's of boost it gets along alright.
12-12-2009, 04:29 PM | #198 | ||
Hi guys,
Ive just installed the BMC DIA system but i have a question regarding the little filter on the engine. The one i bought doesnt seem to fit so can someone tell me what size to get and where from, also did do you remove the tube and and fit it straight on?? Thanks |
13-12-2009, 12:45 AM | #199 | ||
Finally rollin on 20's
Pics..........
Fiesta ST..... Colorado Red...... SOLD Territory Turbo Ghia ..... Winter White SOLD - Good bye my little buddy!!!! K&N, F6 Snorkel, Debung, 20" Enix Turbine in Gunmetal, 7 seat rear springs. |
13-12-2009, 07:06 PM | #200 | ||
I think i need to clean my engine.
14-12-2009, 10:36 PM | #201 | ||
This is a bit of an odd question but i am getting inspired by all these awesome custom jobs and am tring to do something similar with my Festiva. Its a 1.3 98 festiva manual (WF). i have tried just about every performance specialist around and can not find anything that is even close to compatible. the only option i was left with is installing a pod but there is no fesh air where the pod would sit (pointing toward the driver along the front fender) and it just seems like a lost cause.
Please any suggestions?????
Proud owner of a 98 WF Festiva , Mags, Spoiler, 2" Stainless Steel BackCat exhaust system, LED Interiour, MP3/USB/Bluetooth Kenwood soundsystem, Manual!!!! Yeah Baby : Runner up at 2010 All Ford Day (4 cylinder class). |
31-12-2009, 12:50 AM | #202 | ||
Hi Guys/Girls
I was reading this thread yesterday ( got inspired ) so I rung a mate of mine last night and we knocked up a sysem, still need to to make two brackets and polish one more pipe ( too late last night to finish ). It is over the top and probably not the most efficent way but we had fun doing it and I think it looks good ( sounds fantastic even over the top of the loud exhaust ) and best of all it did not cost a cent, can't seem to post and picture will keep trying |
01-01-2010, 12:42 PM | #203 | ||
yeah keep trying i want to see what this looks like.
03-01-2010, 11:42 PM | #204 | ||
I think this is it , if not i have no idea
04-01-2010, 12:16 AM | #205 | ||
thanks for posting but that pic is way too small upload it at 800x600pixels.
04-01-2010, 01:12 PM | #206 | ||
Howdy all,
I installed the BMC DIA before Xmas and it has improved my top end so im able to rev it out better with the bigger wheels which was a struggle previously and response which i am very happy with also a nicer engine note. The only problem Ive had is with starting the car, the car turns over then dies and it would take a couple of attempts to get i going. Ive also noticed that the fuel and and temp gauges will flash some times while trying to start it. would this be a timing issue? Advice. Thanks |
10-05-2010, 08:43 PM | #207 | ||
Reviving an old thread, but I thought it was appropriate.....
As we all know, the hardest thing with the 1.6 intake is the fact the t/c is nestled nicely down between 2 manifold pipes..... So we all envy the XR4 bots with their side mounted t/b's! I have done the unthinkable...... I have bought a Puma 1.7 manifold. Puma, what is the Puma car he speaks of. It was a vehicle Ford produced for the European market as a semi sporty 2 door with a 1.4 and a 1.7 engine (and what is know as the Ford Racing Puma which produced around 180bhp I think.) Any way back to the 1.7 manifold, it is basically a bit of a performance type (i.e tries to have equal length runners etc) for the Zetec SE engines and has been seen to produce around 6-8bhp with a performance filter... More to come when I can sort out postage!!!
10-05-2010, 09:29 PM | #208 | ||
Death B4 Decaf
Interesting. Not something I've heard of before. May I enquire as to the price & how hard they are to find?
I believe the FRP put out around 155bhp according to Burton Power
06 fiesta Zetec in Tango. Factory scuff plates, mats, spoiler & leather gear knob. K&N panel filter. Focus clear side indicators. Colour coded. |
10-05-2010, 10:01 PM | #209 | ||
The few I have seen have been 180, but may have been modded. 153 from here http://www.carfolio.com/specificatio...car/?car=87571 .
At this stage it was 44 pound with a K&N and a gasket, they don't seem to come up often, but if you find one, you also have to get someone who is willing to help get it posted. Here are some pics of a 1.7 in a Mk5 Fez. The second pic is the best to see the manifold
10-05-2010, 10:17 PM | #210 | ||
Here are some better pics.... This isn't mine....
