View Poll Results: Which one would consume more fuel? | |||
60kph at 2000rpm |
25 | 35.71% |
70kph at 2000rpm |
24 | 34.29% |
Neither |
21 | 30.00% |
Voters: 70. You may not vote on this poll |
#31 | |||
FPV GT 0915
Take you BA XR6/8, FPV GT 4 speed auto, 3rd gear should be a 1:1 ratio and 4th gear being the over drive will be about 0.65:1, basically you get more out then you put in!
Bluprint BA GT 2004 Model - Mods: Tinted Windows, Premium Sound, BBS Mags, 245/35R19 fronts, 285/30R19 rears, BMC POD Filter, SS cold air induction, HM tri-y headers, Redback cat back system, Herrod power snorkle, moded Herrod helix spacer, 4" ram air induction, More to come.. |
#32 | ||||
Official AFF conservative
Or yes... CVT.... Quote:
Similarly, you can have it in first gear and take forever and a day to creep up to the redline by resting a featherweight on the throttle... its not going to use much fuel because the engine is hardly under any load. Sure, with those RPMS the injectors are firing "more" frequently... but they'll be injecting SFA each time....
A cup half empty... but full of euphoria. |
#33 | |||
Generally missunderstood
Now of course you would never match those fuel consumption numbers on the road, because you can not drive under those ideal conditions all the time, but they are within the scope of the question. Also if you raised or lowered the speed, and added hills and corners in to the equation, you might end up with a different answer. I hope this helps, or perhaps it is just a catalyst for further discussion! Jzab |
#34 | ||
Given that in both scenarios the cars are doing the same revs, I would expect the car to use more fuel at the higher speed as there is more wind resistance.
That being said, I have driven cars that used 25% more fuel at 80 km/h than 120 km/h. The answer to your question will depend on the car. |
#35 | |||
