Old 30-06-2006, 07:01 AM   #31
Full Noise
Life begins at 40
Full Noise's Avatar
Location: Melbourne. Socialist capital of Victoriastan.
Originally Posted by anto
I was going to try it with water but I'll take your word for it mate..why wouldnt you be able to fill it at a servo ? it is a proper jerry can/container not a generic container..
I know they make them for fuel, however, it’s generally better to use a metal jerry can if you have one available. It’s all to do with the static charge that is produced with the movement of fuel. Because the container is plastic there is nowhere for it to dissipate leaving the charge on the surface of the fuel. In a worst case scenario, what can happen is when you pour the fuel, the charge will find the easiest path to earth which will be the filler neck of the tank you’re pouring it into, and the end result isn’t good for one’s health.
I’m not saying not to use the plastic container, just be careful not to slosh the fuel around too much and when you pour fuel, do it slowly.
Here’s a link that points out some of the problems with static.
http://www.aip.com.au/industry/safety.htm
Cheers, Danny
Marriage is like a deck of cards. In the beginning you’ll have hearts and diamonds. Towards the end, you’ll be looking for a club and a spade.
Justice is what you get when you run out of money.
Full Noise is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2006, 11:25 AM   #32
xbgs351
I would be more impressed if when I went to fill up with it, if they hadn't yet again run out.
xbgs351 is offline   Reply With Quote Multi-Quote with this Post
