06-02-2006, 08:28 PM | #31 | |||
07-02-2006, 02:04 AM | #32 | |||
Highway Taxi
Close only counts in Horse Shoes & Hand Grenades. :evil_laug |
07-02-2006, 07:37 AM | #33 | |||
Speaking of servicing. Had mine done yesterday. A clean bill of health for Ford. Still using those Purolater oil filters. I actually had the oil changed before Christmas for the trip to Adelaide, and I've only done 4,000 k's since then. Interestin thing I found out is that I was having problems with the sunroof switch. I had them check it out and asked for them to replace the switch as I think it's broken. When I picked the car up yesterday, they said they never replaced the switch, but reset it instead. Apparently they hooked my car up to the big computer in the workshop and reset the switch on the sunroof through that. This information is held in the cars computer. I thought it was weird. But anyway, it worked. Roof Goes open, roof goes closed :1syellow1 |
11-02-2006, 09:07 PM | #34 | ||
Bucky, when you polish the bulge does the sunroof suddenly pop up? Maybe all the polishing broke the switch.. not as young as it used to be :
11-02-2006, 09:09 PM | #35 | ||
Often if I my bulge is rubbed, something always goes pop. Sunroof this time
24-02-2006, 05:21 PM | #36 | |||
This system of reply is new to me, my question is does the transmission have a filter? I always thought the internals are oil lubricated but no oil filtering system.
04-03-2006, 07:21 PM | #37 | ||
The filter is flat and fits just above the pan ... it is clipped in place (after being pushed back into place) ... it doesn't look like a normal oil filter ... the filter is internal to the auto gearbox.
05-03-2006, 12:27 PM | #38 | ||
Greetings
Could one of you more experienced ford fans please tell me if my 2001 ford Au wagon as a belt or chain driven cam. Thanks Marco |
05-03-2006, 12:34 PM | #39 | |||
05-03-2006, 08:57 PM | #40 | ||
Thanks for parting with your knowledge Mechan1k.
P.s what's the hee hee for ?. |
05-03-2006, 09:05 PM | #41 | ||
I haven't been trusting my memory too much lately ... and it's a bad habit I keep typing it after sentences for some stupid reason
10-05-2006, 12:21 PM | #42 | ||
Temporary Australian
Hey guys, im a noob to AU's what would be required on a AU XR6 80, 000 k service? and how much if it all runs ok?
18-05-2006, 10:35 PM | #43 | ||
was not sure what forum to put this.. how many Kms is to many i have a 2001 AU II XR8 220kw... it has 157,000kms on the clock.. it that alot for this car...
02-06-2006, 09:23 PM | #44 | ||
I have 172,000km on my 2001 AUII XLS ute .... and it's still young.
I have done 70,000km just this year alone. These motors can handle high kilometres .... as long as you regularly maintain your vehicle ... i service mine regularly because I have to ... it can cost a bit do to the amount of kays I do ... but to me it comes down to being preventative measures. If i look after my car ... it looks after me. There's always going to be parts that needs to be replaced and fixed .... but I do them ... cos if i leave things too long it can end up worse. At the moment I need to do the following to the ute to keep it in good running order: brakes all round. transmisson service oil and filter change sump gasket clean air filter out and re-oil (lightly) new tyres will be comming soon (curent set of 17" rubber has lasted me just over 60,000kays) handbrake adjustment needs a decent detail job as well also up for another diff flush/service as well Will be doing braided brake lines and a brake fluid flush. Cooling system might need a flush as well. I think my battery has seen better days as well ... it may need replacing ... wil see how this winter goes. It may seem a lot ... but if I can do it bit at a time ... instead of leaving it till it breaks ... it will last longer ... and i know I have car that will be constantly running with minimal or no downtime when i need it most.
05-06-2006, 04:42 PM | #45 | |||
Melbourne Lad
Where from? Can I get the gasket and filter from Autobarn, Repco and SupaCheap Auto? |
05-06-2006, 05:42 PM | #46 | ||
Melbourne Lad
No worries, found the transmission service kit from Burson for $24.
05-06-2006, 08:58 PM | #47 | ||
Make sure you get the right fluid too
It's not your normal DEX III auto trans fluid
06-06-2006, 07:46 PM | #48 | ||
Melbourne Lad
I grabbed the Auto transmission service kit from Burson for $24 today, also bought 4L of Castrol TQ95 transmission oil for $33, and a handpump to refill it
Wynode, you said it cost it costed you $100 from Crescent Motorsport, that must have included labour or some very fancy transmission fluid? |
06-06-2006, 07:51 PM | #49 | ||
Yeah that's what it cost me ... and they that did include labour.
The drum of fluid i use there already has a pump in it Plus i get to use their hoist as well ... plus the fluid i use it Gulf Western as well (hence I think it's a slightly higher price for that as well.).
06-06-2006, 07:56 PM | #50 | ||
Melbourne Lad
Sounds like a good deal for $100 to me
06-06-2006, 08:00 PM | #51 | ||
I know ... it's a hell of a filthy job ... I leave that one to my mechanic ... I might give it a go one day ... meh. I'll give other things a go though (replacing all of my brakes tomorrow after nightshift).
13-07-2006, 10:22 AM | #52 | ||
Melbourne Lad
I just performed the transmission service - my gosh the amount of gunk and metal bits in your oil and on your oil pan is amazing.
Parts costed about $55 in total including the Castrol TQ95 oil and transmission kit, however it was a bloody messy oily job and I would NEVER do it again. Tip: Prefill the oilpan with about 1L before you refit it; saves some hand pumping time. Have some newspaper handy and a full can of degreaser. |
24-07-2006, 06:29 PM | #53 | ||
hey, was just wondering wot the best engine oil to use in x66 series one?
13-08-2006, 08:17 PM | #54 | ||
[QUOTE=bazz] Parts costed about $55 in total including the Castrol TQ95 oil and transmission kit, however it was a bloody messy oily job and I would NEVER do it again.
QUOTE] As a qualified mechanic it always makes me laugh when i hear about people working on there own cars. Is your driveway covered in oil, or how about yourself? lol |
15-08-2006, 11:04 AM | #55 | ||
Hi, ive just handed my AU2 in for a 60K service and they just rang me to say they want to service the injectors, is this a scam to make more money?
cheers |
15-08-2006, 11:09 AM | #56 | ||
Man that's a low kay AU2 ... I have done 3 times that ... LOL
They asked me the same on thet Territory for the 45K service ... i didn't want it ... they wanted something like $150 for the service ... I said it didn't need it. If you were having cluffishness issues or surging ... then I'd ask for it ... but otherwise it's not needed.
15-08-2006, 08:12 PM | #57 | ||
17-08-2006, 10:47 PM | #58 | ||
when your workshop rings you and tries to sell an injector clean, i would reccomend you decline. the ones they sell are the on-car ones where you just connect it up to the fuel line and run the vehicle. the only way to truly clean your injectors is to remove them and put them in an ultrasonic bath.
i know this cos i have done many on-car flushes. usually the advisor has a monthly target of sell ups, and if he reaches that mark, he gets a percentage of each flush he has sold |
19-08-2006, 04:18 PM | #59 | ||
As well as the injectors, they wanted to change the brake pads. I declined and when I brought the car home looked at the pads myself and laughed so I took it to a brake place and the mechanic laughed harder than me. How many people do they put the bite on every day? what a joke!
20-08-2006, 04:12 PM | #60 | ||
Treasure your balls?
On a different note...
I recently replaced the O2 sensor since I don't know if it's been done before. AU1's done 210K. Since the change I've gained approx 40-50 Ks a tank full after two fills. At $70 with postage it was worth the gamble. I have since read that it's recommended to change them 160K.
Meteorite T3 TS50 ESS |
