#31 | |||
RIP...
Further to the above correction by prydey, air bags do not perform the same task as a WDH. Air bags only reduce rear sag on the tow vehicle. A WDH redistributes some of the weight from the rear axle to the front, therefore reducing rear sag, and restoring some steering weight and more balanced braking.
. Oval Everywhere... |
4 users like this post: |
#32 | ||
Rob
another critical aspect is tyre pressures. for max loads, increase rear pressures only. Ford do actually recommend a slight increase in front pressure, but it is the difference in pressure between front and rear that is critical. should be about 7psi minimum. increasing front pressures when weight is transferred rearward will increase oversteer (steering more sensitive).
on a dual axle trailer, the front axle should have a slightly lower tyre pressure than the rear axle also, by a few psi. |
#33 | ||
Rob
i'm sure you know what you are doing, but I was under the impression airbags with leaf springs was a bit of a recipe for bending the chassis. reason being the airbag is adding an additional load point where the chassis wasn't designed to have one. it no doubt depends on the load behind the axle and the amount of air being used in the airbag.
#34 | |||
FAWD - No Boundaries
![]() Join Date: Jun 2010
For the trailer, as the nose of the trailer drops... more of it's weight balance is shifted forward, affecting it's front axle load (dual axle trailer) and the additional weight now distributed onto the towball. The WDH helps to restore the distribution of the normal weight of the car, forward... and the trailer, rearward... more evenly spreading these weights across all axles (also allowing the front brakes & steering of the car to work more effectively) whilst also shifting some additional weight off the towball (which came from the weight balance shift of the trailer tipping further forward, pushing down on the towball as the back of the car dropped). D
View My Build thread 22 DJR Shell V-Power Mustang Eskymobile (my first EV) 07 BF2 AWD Falcon Wagon (Daily driver) 04 BA Falcon 1Tonner Ute (New Project) 03 BA Falcon Wagon (Spare) 98 NL Fairlane Ghia V8 (Weekend cruiser) 70 VG paddock racer (Cain it til it breaks.. fix it.. Cain it all over again !)
#35 | |||
BA/F6 BF/F6 SSV/R TTG
https://youtu.be/zubTFR0I_mk ![]()
BA BF FPV starter button repairs. PM me. Nizpro equipped and Tuned by the BEST in the west Xtreme Ford Tuning 479RwKw Fuel limited, more pumps and power too come. F6#0507 & #0639 Pro racer and Tech expert NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below. https://youtu.be/oa4IfguGQ-A |
#36 | |||
Rob
a wdh works by making the hitching point less flexible, and thus transferring weight back to the front of the car, and a small amount to the trailer axle. the towball mass is still there and still the same. the rear of the car lifts because the join is being made more solid. a wdh is not a fix for an overloaded rear axle. |
3 users like this post: |
#37 | ||
Rob
#38 | |||
2 users like this post: |
#39 | |||
Rob
#40 | |||
Experienced Member
Tow ball weight from van/trailer will never alter with a WDH fitted. |
#41 | |||
![]() And wash ya hands!
www.bseries.com.au/mercurybullet 2016 Falcon XR8. Powered by the legend that is - David Winter. XC Cobra #181. 1985 Mack Superliner, CAT 3408, 24 speed Allison. |
#42 | |||
They were posted in that sequence and it was said that they binned it while towing. I know that area and the direction they are driving does head towards bushland with high speed limits. Other direction is the city will slow limits. Probably a good chance it is exactly what it looks like. |
#43 | ||
I've towed the gross trailer mass (2300kg) on MANY occasions and the falcon (leaf spring preferably) does it with ease.
Two pointers.... - Get rid of the the factory trans cooler and fit a remote. - Winch the towed vehicle as far forward as possible (load up the tow ball), helps prevent jack knifing at the speed limit :/ |
#44 | |||
Never argue with an idiot, they will bring you down to their level and beat with experience every time. Last edited by Warrenk; 18-05-2020 at 11:45 AM. |
#45 | ||
#46 | ||
so, every old fart towing a caravan needs a truck licence - I think NOT. Prydey is absolutely correct, check your facts
I reserve the right to arm bears
#47 | ||||
#neuteredlyfe
![]() ![]() Join Date: Apr 2012
Am I missing something here Big Trev? From what I'm reading jstanovic has said that you can't drive a vehicle with a GVM over 4.5t with a standard licence. As far as I know that is true. |
#48 | ||||
The 4.5t only applies to the towing vehicle, not the vehicle and what is being towed.
From Vicroads website: Quote:
#49 | ||||
#neuteredlyfe
#50 | ||
I understood him to be talking about the tow vehicle only, hence my reply
years ago I worked as a heavy vehicle driver trainer (for 13 years) - so this stuff is kind of 2nd nature to me, I sometimes need to update myself, but this is basic stuff
#51 | ||
When in doubt, GAS IT!!
Just yesterday I was given a S1 AU Fairmont Ghia and towed it home on my mates home made car trailer with the wifes BFIII wagon and it was good as gold. Mind you, the wagon is set up for heavy towing with custom reset rear springs with an extra leaf added, stiffer front Pedders springs, big trans cooler and of co**** the 2300kg tow bar. Once the 'mont was positioned correctly and tied down it towed perfectly on the 60km trip home.
#52 | |||
2005 BAII Falcon XR6T - Velocity Blue Factory Options; Sunroof, Premium Sound, Plexus Blue Cloth Trim. Genuine Accessories; XR Scuff Plates, XR Blue Carpet Mats, Boot Liner, Cargo Net, Aux Audio Input (Boosted Type), Front & Rear Mudflaps, Headlamp Protectors, Bluetooth and Mobile Phone Holder. [B]2000 AU2 Fairmont Wagon - Congo Green Factory Smart Bullbar, Hayman Reese Heavy Duty 2300kg Towpack and Front and Rear Mudflaps. |
#53 | ||
not much chance of photos Id guess, yesterdays weather was not one for stopping and taking happy snaps.
Dont p i s s off older people. At our age the term Life in Prison is not a deterrent |
#54 | ||
Here's the wagon, but the trailer went home and the Fairmont is your average light blue AU sedan, Im sure you can work out the rest, lol.
#55 | ||||
![]() ![]() Quote:
Well if you get desperate, give me a call. |
#56 | ||
The answer to the OP's main question is relatively straightforward:
The mass of the trailer and cargo must be within the specified tow capacity of the towing vehicle and hitch. Where there is no specification, it must not exceed 1.5 times the empty mass of the tow vehicle. (WA law) So, for example, your average BA Falcon, fitted with HD hitch, weighs around 1,500kg, but can tow 2,300kg. Which yes, is approximately 1.5 x So providing your trailer weighs less than around 750kg, a BA could tow a BA. How much does a trailer weigh? Interestingly I would have estimated around 6~800kg, but I don't actually know. In WA, where you are more likely to come unstuck is that most hire trailers will be limited to 2,000kg GTM. (Over that requires remote-controlled brakes.) As to whether its safe, that depends on the condition of the tow vehicle, the condition of the trailer, weather and road conditions, the care and skill of the driver, and the balance of the load. I've done it, with great care and moderate speed, on good roads and freeway. One way to look at it, is that any problem is going to be multiplied threefold or worse. I wouldn't do it in the wet, or on gravel. I keep the speed down, leave massive gaps for braking, and take corners at a snails pace. |
#57 | ||
A BA BF FG weighs around 1900kg and a car trailer 750kg. SO......
#58 | ||
Hi Trev, I think you misunderstood my post as I am saying the same as Prydey. My first paragraph clearly says about single vehicle weights (GVM), the second talks about towing (GCM).
#59 | ||
Former BTIKD
![]() Join Date: Mar 2005
If the thread title was Falcons towing Falcons - Illegalities, I could post this......................but I wont
#60 | |||
RIP...
That's not right. It's just as easy to overload the ball as it is to not have enough on the ball. Aim for between 5% and 10% of the loaded trailer weight on the ball. For example, if the loaded trailer is 2000kg, somewhere between 100kg and 200kg will tow well.
