Site Support If something isn't working or you have a suggestion ( a nice one !! ) let us know here. |
09-03-2013, 07:16 PM | #31 | ||
Chairman & Administrator
I'd suggest an issue at your end - we've been monitoring the server loads and performance since before the upgrade to see what impact it had and it has substantially improved the average response time compared to a week ago (from 1300 to 600 ms) as well as resolving the query cache low memory prunes issue.
Cheers Russ
Observatio Facta Rotae
09-03-2013, 07:23 PM | #32 | ||
Just a note - it will be slowish for the next 30 minutes while I rebuild the master indeces.
Cheers Russ
09-03-2013, 08:09 PM | #33 | ||
thanks for the work you are doing russ
just a quick one around 7 this morning the site was down ( not sure if it was just my end ) or was it just down Jason
09-03-2013, 08:21 PM | #34 | |||
I am Groot
+1 on the work Russ is doing.....
.. McLaren F1 Dick Johnson Racing "Those were the days when the cars were cars, they weren't built out of an Ikea pack like they are now and clothed in plastic; they were real cars." John Bowe |
09-03-2013, 10:00 PM | #35 | ||
No it was down twice this morning for a few minutes the first time and about 20 minutes the second. Not sure why but I'm reviewing the logs currently to get to the bottom before it happens again!
Cheers Russ
3 users like this post: |
12-03-2013, 12:13 AM | #36 | ||
Awesome
Location: In my own little world..Everyone here knows me :)
AFF has been painfully slow for me tonight. It has taken me over 2hrs to even be able to login. All other pages are loading fine.
Cheers Col
12-03-2013, 08:51 AM | #37 | ||
Hi. Dreadfully slow for me yesterday as well and got worse by 7.00pm, tried a couple of times after that and it was still going downhill so I gave up and quit at about 10.00pm. Cheers MD
HI I'M MICHAEL 2003 ACID RUSH BA FUTURA WAGON light up window switches | auto on cruise control | doubleclick window lift from remote |
12-03-2013, 08:55 AM | #38 | ||
No reason why that should be the case - looking at the logs from last night the average load times were below 500ms right through until well after midnight they had been around 650 earlier in the evening but even that is quick.
Need to check whether those having issues use the same ISP. Cheers Russ
12-03-2013, 09:04 AM | #39 | ||
Also worth noting that I am doing the remaining indices this morning after rebuilding some corrupted database tables that were damaged in the crash Sunday night.
Will have some impact on performance but probably not a lot. Cheers Russ
12-03-2013, 09:10 AM | #40 | ||
Awesome
I rang my internet provider last night (Optus) and had them reset my modem and check my settings in case it was on my end and they said everything was working fine, however the exchange for my area does seem to be running below it's usual output.
It was just odd that it was only AFF I had an issue with. If our service goes slow for any reason, we generally tend to load a youtube video to see if there is a delay and that was working fine last night. Cheers Col
12-03-2013, 09:27 AM | #41 | ||
Hi. We use Optus as well but I could load autospeed in the blink of an eye as with google and google images. Cheers MD.
ps: dont you ever sleep Russ. Cheers MD
12-03-2013, 11:15 AM | #42 | ||
Isn't it obvious?
adam internet here
everything else was loading fine and quick aff was much much slower but its fine this morning loading up pages very quickly
08 Strike G6E T. 10 Ergo G6E Sept 75 XB Falcon in mushroom beige, 3 on the tree 200cid for sale, offers in the teens |
12-03-2013, 11:46 AM | #43 | ||
Missing a sock...
Yesterday evening between 6-7pm (QLD) AAF was very slow for me. Pages would begin to load then stop loading after the first 4-5 posts were displayed, same would happen on refresh. Tried other sites and was ok, did a cold boot and no difference. I'd been logged in most of the day without a hitch. Tried later on at 9pm and all was good. It's flying right now.
I'm not complaining, these things aren't just peculiar to AFF. Optus cable, IE9, Win7. Cheers!
Real friends + great times = sheer bliss! Considering becoming an organ donor? Click here QLD Events, Cruises and Get Togethers: Click here Gain success instantly - lower your standards. It's not government funded - it's taxpayer funded.
12-03-2013, 06:31 PM | #44 | ||
It's odd - if anything it should be somewhat slower at the moment - in fact the average load times are terrible at 1210ms although (thankfully) the slowness is in the apache layer and not the database so we at least fixed that bit!
At about this time we normally have around 500ms in the apache layer and 200ms in the database - the latter having gotten to the point where it was over 700-800 on it's own which is why we did the upgrade. What I am seeing now is 800ms in apache and 200-250ms of database response so something has now gone awry with the former. I'll do an apache restart shortly (at 6pm) and then watch it for awhile as I suspect a rogue thread or two. Cheers Russ
12-03-2013, 08:05 PM | #45 | ||
Hey Russ have you explored putting nginx as a reverse proxy in front of Apache? Some good improvements to be had.
Sent from my Nexus 4 using Tapatalk 2
12' FPV Mkii F6 Vixen -= ID1000 - Venom Cat - BPR SRI - PW Stage2 Cooler - Tune=- (348Kw) Mazda 3 MPS Aurora Blue Gone :( -=PG SRI - PG Inlet - ETS TMIC - GFB Hybrid BOV - Best Mufflers DP - Eibach Pro - AccessPort STG2 - Autotech HPFP - ITV22 - Michelin PSS=- (198Kw/466NM ATW) |
12-03-2013, 08:07 PM | #46 | ||
Awesome
AFF is now starting to run a little slower as it did last night. I am finding when I hit refresh, or go back to the main page, the top of my address bar just keeps spinning, like it is trying to load the page and hasn't found a finish point.
Perhaps it is just due to the amount of users logged on? Forum appears to be busier from 7-10pm most nights. Cheers Col
12-03-2013, 08:33 PM | #47 | ||
XB,XF,ZL,EA,EL,BA,SY,SZII
I don't think the number of users online is the problem. It's working fine for me right now with more users online than at times when it has taken minutes to load rather than milliseconds. I gave up at 7 AM this morning. BTW, my ISP is SpinTel using Telstra ADSL2+ infrastructure. Other sites are OK.
12-03-2013, 08:36 PM | #48 | ||||
Server uptime: 1 hour 14 minutes 19 secondsTotal accesses: 179,851 - Total Traffic: 2.8 GBCPU Usage: u2163.59 s16.51 cu2.34 cs0 - 48.9% CPU load40.3 requests/sec - 0.6 MB/second - 16.3 kB/request52 requests currently being processed, 33 idle workers.. all within normal tolerance but having said that the bulk of the load times are still in the PHP layer currently around 900ms average. Cheers Russ
12-03-2013, 08:38 PM | #49 | |||
Cheers Russ
12-03-2013, 08:55 PM | #50 | |||
Missing a sock...
To check the performance of my connection I go to http://www.speedtest.net/ Once you follow the simple set up the site will remember up to your 10 last tests for comparison - no need to join for the premium package. It's not the be all to end all, just another tool in the box for referencing. Cheers!
12-03-2013, 10:15 PM | #51 | ||
Awesome
Thanks for that supershifty. I have been running speedtests on the hour for the Optus tech's and currently we are running at 76757kbps upload speed and 1338kbps download speed which is within the norm but AFF is still running slow.
I know Russ is working on it and hopefully it will be resolved soon. Currently it is taking me over 20secs to load an AFF page. I hope some of this information helps you Russ. Cheers Col
12-03-2013, 10:38 PM | #52 | ||
Doesn't match what I'm seeing - page loads were high earlier in the evening but have settled down into the mid 500ms bracket as per the chart below.
Apache stats have also settled substantially - Server uptime: 3 hours 41 minutes 49 seconds Total accesses: 580,709 Total Traffic: 8.8 GB CPU Usage: u551.47 s8.86 cu.73 cs0 - 4.22% CPU load 43.6 requests/sec - 0.7 MB/second - 15.9 kB/request 49 requests currently being processed, 33 idle workers
12-03-2013, 10:47 PM | #53 | ||
Whatever just happened in the last ten minutes - pages are now loading super fast.
----------------------------------------------------- 2012 Focus ST Tangerine Scream Continually having a battle of wits with unarmed opponents. Sez Photo's by Sez |
12-03-2013, 11:22 PM | #54 | ||
Awesome
It is faster but my webpage is still spinning. I seem to have intermittant issues. It is sometimes fast and then slow again.
It is not an issue with the optus network as I just got off the phone to the internet tech and all other pages etc are loading fine. Cheers Col
13-03-2013, 04:43 PM | #55 | ||
I gave up this morning trying to get on here on my tablet. All other web pages I was browsing were fine but I could never load AFF gave up after 10mins of white.
1976 XB Falcon 500 Wagon - BUILD THREAD Sherwood Green | 3spd/250CI | Running Whitewalls on a 2.5" Drop |
13-03-2013, 09:12 PM | #56 | ||
After some tuning last night to take advantage of the additional memory we now have things running at a nice level. Average response times today have been good (including at 0700 when I was on) with a peak (thus far) around 1000ms at 1500 and an overall average of 623ms.
It's still spending way too much time in the PHP serving end (Apache) - not sure if this is caused by compressing pages before they are delivered (which we do to minimise bandwidth) or whether there is something else in Apache that I can do. At least this is now the reverse of what we had before where more than 70% of the time was taken in the database - it's now 20-25% in the database and the balance serving the PHP. Realistically I am targeting average loads in the sub 1000ms bracket (which we are doing) but with a near enough 50/50 mix between database and PHP which should result in sub 500ms averages. For those interested in the details, I've created a little page where the live response times are monitored HERE which shows the rolling 6 hour average and the mix between PHP (cyan) and database (orange) time. Cheers Russ
13-03-2013, 09:19 PM | #57 | ||
Maximum Derek
Interesting indeed
2008 FG XT 6 Speed 18's, Tint, ZF Conversion, LED Conversion, Exhaust.
13-03-2013, 10:13 PM | #58 | ||
Awesome
It is running great for me tonight. Thanks for all your efforts Russ. Greatly appreciated
14-03-2013, 08:20 PM | #59 | ||
Mystery solved as to why things have been strange.
In tracking down another issue with thread views not updating, I found that that table was corrupted and there were several hundred temporary tables being created to cache that data which, in turn, was locking the database intermittently. Hopefully fixed now although we will wait and see what happens next. Cheers Russ
6 users like this post: |
14-03-2013, 10:52 PM | #60 | ||
Need More Cubes!
Not sure if its just me but I cant get any of the smiley things to work, same goes for bold and italic etc...??
1992 EB GT 418 Windsor, T56 Magnum! Engineered/Modification Permit! STREETBUILT Racing 1993 DC LTD EB GT Drive Line! |
