#31 | |||
that they didn't have or want to spend the time and resources on an emerging technology. Ford had technical and supplier problems with EcoLPI that held the car up for a considerable period. So in the long run, will customer satisfaction be improved by offering LPI over multi point vapor injection? If we were talking retail sales, then I would say yes but Ford & Holden are clearly pitching to fleets. So is EocLPI wasted on fleet sales, do fleet managers just want an LPG system that saves them money? I say this because a lot of people are zeroing in on performance, the last thing on fleets minds... |
#32 | ||
Rob
i just don't get this place. ford bring out a state of the art system. members praise it up but then holden bring out an inferior system and suddenly the ford is over engineered and the holden system will probably sell more???
#33 | ||
Lukeyson
![]() Join Date: Mar 2005
As I understand it, Sequential Vapour Injection is more complex on a dual-fuel svi car because you have to alter the duty-cycle of the injectors with a complex interception unit, since the injectors need to be open longer when on lpg as compared to petrol.
On an LPi dual fuel the LPG feed pressure is regulated so that the standard PCM injector pulse width can be used on either petrol or LPG, so no pulse-width intercept is required. HOWEVER, that means you need a pump in the LPG tank with a pressure regulator and a return line for both unused fuel in normal operation, and for priming the lines to remove any 'gas' bubbles at startup. On single fuel I reckon the playing field is levelled regards complexity. Is there any word on whether the Holden LPG solution is pressure fed like gas-ring converters, or pressure-fed like LPi? Because if they are pressure fed, then SVI could rightly claim to be less complex in a single-fuel application. I'm just saying..... Lukeyson
If the human brain was simple enough to understand, we'd be too simple to understand it. |
#34 | |||
sales over inferior product, especially in fleet markets. If you consider that criticism of an over enginnered product then you are reading way too much into my posts. I'm merely asking the question because Holden chose to go vapor injection, do you think they feel disadvantaged? Let's just wait a bit before rushing off to decide either way, Ford and Holden both need to win sizable fleet sales because if we don't know what ordering in the future will be like but as of this month, Ford has no major fleet orders. |
#35 | ||
Lukeyson
As always, it boils down to superior engineering and product vs superior marketting.
The prime example was Post GFC. The first thing Ford does is invest in new product for a product led recovery (LPG, Diesel, Ecoboost). The first thing GMH are seen to do is spend $3M on 'buying' T8...... Lukeyson
#36 | |||
#37 | |||
No, it boils down to who gets the sales.....and who sits on the side lines wondering why they missed out. This time Ford needs to get in there with fleet managers and get those sales, don't sit back and let Holden take the market away from Ford with an inferior product... |
#38 | |||
the big change is the preheater that allows cold start on gas only... |
#39 | |||
Rob
holden's product is largely unproven except for their PR spiel, which everyone seems to have lapped up as gospel and 100% fact. the falcon is a superior product, end of story. sales figures don't determine which product is better. |
#40 | |||
Lukeyson
It sounds like you're swayed more by marketting than product here <pokes ribs> ..... so far from GMH marketting we've seen questionable numbers on distance travelled, economy numbers that can't be matched in the real world, and statements about uncompromised boot space despite still needing to have a separate spare tyre or space saver. Ford need only spin the same web of 'marketting' on EcoLPI, Ecoboost and Diesel. They have the superior product by many measures. Lukeyson
#41 | |||
SiX_iN_a_RoW
As far as I know the Ford system primes as soon as you open the drivers door?
Oh yeah, my G6ET eats diff bushes for breakfast! |
#42 | |||
Rob
#43 | |||
Rob
even still, no one would be in that much of a rush that you need to start the car within seconds of hopping in. |
#44 | |||
#45 | ||
SY TS AWD LPG TEZZA
Many times someone has said "the EcoLPi should be marketed a lot-no ones even heard of it much" or words along similar lines, someone comes back and says, "but do you know how much advertising costs- it's very expensive you know - maybe Ford can't afford it". My answer to that is, when a product by any manufacturer is discussed for production and timelines and costs are looked at to test it's marketing viability etc etc, a percentage of outlay should be put aside for marketing. If Ford didn't do this, well then someone should get a serious talking too.
Why go to the trouble of making an outstanding vehicle, miles ahead of the opposition, then run out of money right at the point that counts when it comes to sales - advertising. You can have the cure for cancer but if no one knows about it, what's the point. Why design and build a car, without any ability or drive to market it??????????
1st car 75 XB Fairmont wagon 302C converted to 351C. 2nd car 82 ZK Fairlane 351C 4spd AOD LPG/Avgas 3rd car 97 EL Falcon police car 4L auto dual fuel 4th car 90 XF ute (work car) 5th car 06 SY TS AWD Territory Orbital LPi 6th car 95 XG ute 7th car 2014 SZ Territory TX Petrol Fords all my life. |
#46 | ||
Gotta love al the Holden bagging … people you still seem to miss the point … its SALES numbers and profits that count, nobody cares who has more KWs or Torque numbers …
Holden has most likely spent very little money and resources of the development of this system VS Ford … Holden also has one massive advantage for the targeted market and it’s called a WAGON. So I have a feeling Holden will end up selling a whole lot more LPG cars and if they invested less money in R&D it will equal profits … (unless they Fit up in some other area …) |
#47 | ||
Lukeyson
Yes, we agree dimka. You've missed the point about us getting the point.
Marketting vs Superior Product. Holden - Good Marketting, Crap Product. Ford - Crap Marketting, Good Product. Lukeyson
#48 | |||
#49 | ||
Guys, you have all missed two important points.
Firstly, which system do you think is more future-proof and has more scope for fuel economy and/or power improvements? Secondly, even if Ford were to have gone the gas injection route, their result would still have been more torque and power than if Holden were to have gone the liquid injection route. That's because the GM HFV6 in its base form is a torque-less, underpowered, poor excuse of an engine to begin with. Even if Ford were to drop the displacement of the I6 engine down to 3.6L, it would STILL produce more torque than the GM HFV6 in 3.6L DI form.
PoweredByCNG: Sick and tired of all the ignorant 'gas is crap' comments out there. |
#50 | ||
The 'Stihl' Man
![]() Join Date: Jan 2005
With regards to Ford over engineering that has been happening for ages and ethically its the right thing to do..but unfortunately in today's business world ethics has little in common with those who continue doing business.
So who is stupider? The one that spends more to create value that no one cares about or the one that spends less, potentially sells the same or but offers an "inferior" product. Tough one..there are examples all over the place of this, look at GMH vs FoA small car policy. One has quality euro imports and the other has cheaper Asian derived cars... BUT..thats why I have continued respect for Ford and the path they choosen, but sometimes its an unnecessary direction and it seems all for nothing. Its going to be very sad if this "ethical" standpoint they push is the cause of them to have sale/financial trouble. As for the LLPG commy, did you guys read the cars guide? I try not to but of course they had the commy all over the front page. Running comparison with a Skoda TDi, Petrol VE2 and a Mazda 3...they go as far as trying to discredit TDi by bagging out the "dirty" diesel pumps...seriously... They mention the Ford system and use wording like "complex" as if its too much, or cumbersome...FFS
#51 | |||
#52 | |||
The 'Stihl' Man
![]() For what its worth the running cost difference between the Skoda TDi and Commy LPG was $50 per year............$50....and the Skoda AFAIK is a more useable wagon.
#53 | ||
Oh my goodness, in the article they have images of
Wagon + surfboards + LPG their marketing genius knows no bounds! Oh Ford, why, why why?!~?! |
#54 | ||
Even if Ford stepped up their Advertising its not going to make any difference.
Whats killing them is the journos. It seems that what ever Ford do is either not good enough or its too complicated...either way they find some sort of negativity with the car. The press is way more lenient with Holden and lets things slide. I think the problem here is Fords (PR & Marketing) relationship with the journos and press....i think Ford need to show them some lovin' Either that, or be a bit more strategic with who they give their cars to review |
#55 | |||||||
I guarantee you that they lap up PR spiel and also published economy numbers and all the costings provided by fleet leasing companies, so maybe "best car" technically Quote:
As mentioned above, think about this from a fleet managers perspective and what they are fed to make leasing decisions, you'll soon see why it's vital for Ford to get out there and sell their EcoLPI and not just rely on past good name.. Quote:
#56 | |||
it's then obvious that fleets also get a significant reduction on their price and now pay less for FG II...... |
#57 | |||
#58 | ||
Guys, let's also reconsider the COST difference per unit comparing Falcon XT EcoLPi and Commodore Omega LPG. The price difference alone, even after heavy fleet discounting, would be enough to buy AT LEAST a year's worth of LPG, or the difference in consumption over the lifetime of the vehicle. That kind of swings the favour back to Ford...
#59 | ||
Bit of a comparison between the two engines based on the advertised figures.
3.6L LPG Power: 180Kw CO2 emissions: 189g/km Consumption: 11.8L/100km 4.0L EcoLPi Power: 198Kw CO2 emissions: 199g/km Consumption: 12.3L/100lm Per 1000cc Comparison: 3.6L LPG Power: 50kw/1000cc CO2 emissions: 52.5g/km Consumption: 3.28L/100km for every 1000cc 4.0L EcoLPi Power: 49.5kw/1000cc CO2 emissions: 49.75g/km Consumption: 3.075L/100km for every 1000cc While the FG makes a bit less power per 1000cc, it produces less CO2 emissions and is more fuel efficient if you take engine size into consideration. There is no point comparing torque. How can the vapour system be more efficient? |
#60 | |||
The 'Stihl' Man
