#31 | |||
Bad Music and Litre Bikes
We have a 98 Barina, 1.4L MPFI with a 5sp manual.
I think its a good little car, we also have a Combo at work, and for what you described, with the advertising, its fantastic. Great mass of white space for any sign writing that you need. If its a work vehicle, does it really matter if you can't get to 100kph in 10 seconds? The only things to be wary of are being conscious that its only a 1.4l engine (I went from a 5L), and that they're prone to blowing head gaskets.
XY Wagon - NAKED! Quote:
#32 | |||
______________________________________ ![]() ![]() |
#33 | ||
Wait? What?
One of our partner Businesses had a Combo until recently. It was left in the yard and some idiots tried to steal it but it didn't have enough go to drive through the gate so they torched it. what a shame.
#34 | |||
Virtuous Bogan (TM)
![]() Join Date: Jan 2005
We have had no issues mechanically whatsoever, its great, other than the Holden badges. Going from a falcon to the barina I quite enjoy skimming through round abouts..LOL But like any car, get the latest model you can, I know these Barina's (Corsa's) had issues with the earlier ones. And to top it off we get 600-650 k's per tank easy, from 42L I think.
#35 | |||
Watts a panhard.
Neither your ED Windsor nor the LS-series are SOHC... |
#36 | ||||
Fuel economy is great too.. ~7.5L/100 Keep it serviced, and drive it within its limits and i'm sure it should be a good car for you.
#37 | |||
XP Coupe
#38 | |||
XP Coupe
#39 | ||||
Nutty Professor
#40 | ||
XP Coupe
Oh I see, we are supposed to be comparing the superiority of your ED XR8 351 stroker to the stock LS2? Or do we take a 6.5l stroker, whack a turbo on it and compare apples to 388s?
#41 | ||
Virtuous Bogan (TM)
This site surprises me sometimes, why is there talk of a ed, V8 or stroker in a Barina thread..LOL
#42 | ||||
Nutty Professor
#43 | ||
Watts a panhard.
No, he is saying that it is a bit silly to compare your modified Windsor to a stock LSx. We're all adults here; even if we dislike Holden the LS-series are damn fine engines.
#44 | |||
How old are you, 10? Do you even read the drivel that you write before you post it? |
#45 | |||
Nutty Professor
well i wouldnt necessarily call them damn fine, but fine to do the job of putting a smile or your face nonetheless.
my question is, why does my 1994 302 windsor with less than $2k put into it make more power than some of the LSx motors? i just dont think GM tries that hard anymore. well, not as hard as they could.
#46 | ||||
Nutty Professor
are you serious?
#47 | ||
XP Coupe
Nice going if you can knock over an LS2. Mind telling us your uprated 302 bore, stroke and rods? Is it 4.030", 3.80" and 6.25"? I hear it's a pretty good combination.
#48 | |||
Nutty Professor
not sure of the rods, my mate did most of the work.
i didnt want to bore it out because i wanted to retain as much block integrity as possible, so its running the stock bore (or very close to it) with a 3.8x stroke. i was worried we would have to put some deck plates on and longer rods to stop the bottom of the pistons from hitting the crank weights but we are using a 351 crank which has smaller counterweights and it seems to be running alright. its one hell of a sleeper tho, its still got the factory paint and exterior. i like it.
#49 | ||||
BF XR6, oh yeah!!
Maybe you could consider some other things, if you don't want a full size van or Wagon, Howabout something like an older model small or midsize wagon, something like a Mazda 626, or an older shape Camry (back when they were doing wagons) or even a Corolla wagon, if there is one in your price range. That way you still have a proper car the rest of the time.
Otherwise you could probably look at something like one of those older Suzuki vans, or even a Toyota townace van. Just a few things that you may not of considered. Then again, if you want something that will stand out, why not try and find an original Mini van. Might cost a bit more, but would be well worth it. Quote:
Current ride: 2005 BF XR6 Sedan, Lightning Strike, ZF Auto Previous ride: 2001 AUII Futura Sedan, Narooma Blue |
#50 | |||
Current Rides: 2012 KK Jeep Cherokee Limited CRD - Still going strong 2019 MG ZS Essence 1988 RD Mitsubishi Colt GL - 59kW of Fury 2022 Kia Stinger GT |
#51 | ||
Clevo Mafia Inc.
![]() Join Date: Dec 2004
I'm trying to recall the topic but fail to remember after the Windsor vs LS1 debate....
Oh that's right, the Holden Combo with 44kw. |
#52 | |||
Back to Le Frenchy
Oh look, a quality thread.
#53 | |||
BF XR6, oh yeah!!
#54 | ||
XP Coupe
These specs indicate it's 66kW instead of the 44kW quoted
Engine location: Front, transverse Displacement: 1364 ccm (83.23 cubic inches) Engine type: Inline, 4 cylinder Max power: 90.00 PS (66 kW or 89 HP) at 5600 Rev. per min. Max torque: 125.00 Nm (12.7 kgf-m or 92.2 ft.lbs) at 4000 Rev. per min |
#55 | ||
Where were those from and what model. Mine were from carsales research (who knows how accurate) and for a 96 model. The later ones are more powerful.
#56 | ||
BF XR6, oh yeah!!
Are you sure that is the '96 model there Wally? Not that I doubt you, but that sounds like a lot for a 1.4 from that time period. If that is correct, then you would think that would have to be plenty of kilowatts for a small van.
#57 | |||
Windsor Warlords
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming. Project Thread |
#58 | |||
XP Coupe
No, you're right they are the 2007 specs 2004 Holden: Displacement: 1598 ccm (97.51 cubic inches) Engine type: Inline, 4 cylinder Max power: 87.7 PS (65 kW or 86 HP) at 5400 Rev. per min. Max torque: 133.00 Nm (13.6 kgf-m or 98.1 ft.lbs) at 3000 Rev. per min. Fuel system: Injection Valves per cylinder: 2 Gearbox: Manual, 5-speed 2005 Holden: Displacement: 1598 ccm (97.51 cubic inches) Engine type: Inline, 4 cylinder Max power: 87.00 PS (64 kW or 86 HP) at 5400 Rev. per min. Max torque: 133.00 Nm (13.6 kgf-m or 98.1 ft.lbs) at 3000 Rev. per min. Fuel system: Injection Valves per cylinder: 2 Gearbox: Manual, 5-speed Others: 2003 Opel: Engine location: Front, transverse Displacement: 1596 ccm (97.39 cubic inches) Engine type: Inline, 4 cylinder Max power: 90.00 PS (66 kW or 89 HP) at 5800 Rev. per min. Max torque: 138.00 Nm (14.1 kgf-m or 101.8 ft.lbs) at 3000 Rev. per min. Compression: 9.6:1 Bore x stroke: 79.0 x 81.5 mm (3.1 x 3.2 inches) Fuel system: Injection Valves per cylinder: 2 Fuel control: Overhead cam (OHC) Lubrication system: Wet sump Cooling system: Liquid Gearbox: Manual, 5-speed 1996 Opel: Displacement: 1389 ccm (84.76 cubic inches) Engine type: Inline, 4 cylinder Max torque: 104.00 Nm (10.6 kgf-m or 76.7 ft.lbs) at 3000 Rev. per min. Fuel system: Injection Gearbox: Manual, 5-speed etc So it seems they managed to get the 1.4 upto the 1.6 peak power output by 2007. Last edited by Wally; 26-03-2009 at 09:31 PM. |
#59 | |||
XP Coupe
https://www.mynrma.com.au/cps/rde/xc...car_review.htm
#60 | ||
what are you all whinging about. 44kw is plenty to run a computer with.
Get a skoda roomster....ugly as hell but actually useful. Make sure you get the 1.9 diesel. Plenty of hot up gear from the US available for it. Easy to get over 200 HP with a turbo, and injectors. And before you ask...yeah its only 200hp....at 4000 rpm (think of the torque ~400 nm) |
