#31 | ||
i adjusted mine about 2 years ago and it's still fine, may need it again soon, takes about 8 clicks to hold the car on a moderate hill before putting it into park... au1 by the way, as above, if you know how to adjust them properly there is nothing wrong with them, think about it, it needs a working handbrake to pass rego....
#32 | ||
Bear with a sore head
They are a huge problem. I used to work at a dealer up until 2 years ago. I would adjust BA's all the time. Nearly as frequently as we would machine discs. Theres a full TSB (Technical Service Bulletin) about them, such is the problem. I have to say that I do beleive on the BA's that people do often overload them, but they aren't a good design never the less.
We had our BA for 5 years, 130,000km and I only ever adjusted the handbrake once. My AU XR8 on the other hand needed to be adjusted a few times. But the problem is that there is usually a number of problems. Not many people seem to be able to get it sroted the first time because they aren't exactly sure why it's not adjusting properly, and sometimes it's too hard to tell. It could be the cable stretched, it could be the shoes worn, it could be the adjusting wheels seized, it could be an issue to do with the banksia arm location/wear. There is many threads about this issue including an self adjustment guide based on Fords TSB that I have compiled some 2 and a half years ago. If anyone needs it search for "proper fix wanted for dissapearing handbrake" in the B-series section. |
#33 | ||
There's a good sign.
A mechanic who doesn't think that adjusting a handbrake is merely tightening the cable from the cabin. |
#34 | ||
Afterburner + skids =
![]() Join Date: Dec 2004
Well, people shouldn't have problems with their handbrake if they park their cars in gear though..........
#35 | |||
As ford lists hanbrakes and components as servicable items, no warranty issues can be claimed unless it's proven that there was a fault with in the components themselves, which caused premature waear of something else, rather than just wearing out. We made it mandatory to report if the handbrake needed adjustment, as just adjusting the cable would result it problems arising later on, usually the end result being more costly to the customer. |
#36 | ||
OMGORDZ
can't fault my BA utes handbrake at all... will happily lock the rears at 30kph with the clutch engaged
#37 | ||
![]() ![]() Join Date: Jun 2006
Apart from the mechanics who dont adjust them correctly, its probably because of drivers who habitually pull up the handbrake lever tightly every time even when parking in the garage at home when its not necessary. This causes the cable and mechanism to stretch and wear unnecessarily, then when they really need the handbrake to work properly when parking on a slope, it doesnt.
Also, it is dangerous to put the transmission into Park before applying the handbrake, as you are then unaware the handbrake is ineffective, since the car is then held by the transmission. If you correctly apply the handbrake first, then release the footbrake, the car should hold on the slope before you shift the transmission into Park. Sorry for bringing that up in this thread, but that is an important point when discussing ineffective handbrakes, as you dont know the handbrake is ineffective unless you try it every time on its own. Last edited by Silver Ghia; 04-09-2008 at 02:41 PM. |
#38 | ||
Secret Sleuth
The wifes BA XR6 was bought new and had handbrake problems from almost day 1 - everytime you took it in, they wanted to charge you to adjust saying it did not come under warranty. That attitude really pi$$ed us off, if its broke from day 1 then how is it not under warranty...idiots. I havnt come across a BA that hasn't had handbrake problems so I dont know what some of you are on about either...
The swoosh, swoosh, swoosh noise always gives away a late model falcon or commodore in an underground car park as well.
BF Mk2.5 XR6 Turbo |
#39 | |||
#40 | ||||
Previously ScottishXC
Fair comment Russ, I have only owned 2 myself but we have had plenty of fleet BA's BF's etc and haven't ever had an issue....I guess the main reason that I am surprised by this (maybe a little blunt and blanketing on my last statement, my apologies!) is that I have done way more miles in these cars than your average commuter or owner, including innumerate rental Fords in all states too.From some of the posts in another thread, I frankly am not surprised some have problems with their handbrakes if they choose not to bother putting their cars into park............the biggest problem with devices tends to be the people using them! From this experience which covers more cars than most folk would use I thought that I would have come across it- please don't get me wrong, clearly it is an issue from what posters here are saying but I must be lucky as I nor anyone I know who owns one of these cars has had it!
Great transactions with the following members: BJ Gilesie XAGTCoupe Pilch Aussie_afroman Donut King Bad Boy Benny BAWITHLOT Greenmachine Pinkbits CUZ351 OhioXB Falconunbelievable 4VXC Uncleraggy FG G6 Ego, tech pack, Tropic gold 1973 Landau, Cosmic blue 1975 P5 LTD....long term project Quote:
#41 | ||
proud member of the MFCC
as a friend of mine says there are just too many ford out there
#42 | |||
Hmmmmmmm!!
I already commented on the handbrake design. Poorly engineered, on a 1 piece ring than a 2 piece double leading edge (floating) drum system. (IMHO is the best there is). Don't know what Ford were thinking in going away from this design. I think Ford tried to re-invent the wheel. One's wheel doesn't need fixed until a spoke is broken. But the only way to fix these issues, is to adjust it slightly tighter than looser. Maybe Ford do it tight, so you will be less often to come back to them. (complain less) I've done a few adjustments, and the only one that really works well and for a long time, is to do it up tight (just where the disc stops) and back of a couple of notches on the adjuster wheel. I did it the proper way (Ford's way) and all it did was create the squeak sqeak noise in about 4 weeks. Handbrake lever was around 2-3 notches. Never felt better. ![]() |
#43 | ||
The one in my BA 'mont is about as useless as a one-legged man in an kicking contest.
Has had the problem since I picked it up (second hand) a few months back, but I haven't been -too- worried as it's an auto and the Park Brake works fine. Never had an issue with the handbrake in the ED, EL or TX5.
2009 LV MkI TDCi Focus Hatch |
#44 | |||
#45 | ||
playing in my big shed
had my BAute for 5 years and only needed to adjust the hand brake once , about 2 years ago. it was starting to squeak sometimes as i started to move off. was getting a couple of things fixed up before warrenty ran out and mentioned it to the ford guys. they cleaned the brakes and adjusted (no charge ) and its been fine since.
117000km and i could not fault it.
`75 XB FAIRMONT sedan . mushroom beige, injected 351, toploader, 9inch `10 FG XR50 Turbo ute. Nitro blue, 6 sp Auto, Leather trim. `04 BA RTV tray back, Red, V8 auto, `04 BA XR6 Turbo sedan. Blueprint. auto, Leather trim. `03 BA XLS ute . Acid Rush, factory lpg, auto, `48 TEA20 Grey Ferguson, `62 Willys 6-230 , 4x4 light truck `04 Yamaha TTR 250 |
#46 | ||
Performance moderator
![]() Join Date: Feb 2005
Nearly ALL our fleet Fords hand brake is hardly adusted up correctly..
I would say bad pre delivery work..
#47 | |||
Regular Schmuck
#48 | ||
149 rwkw of Style
Ford have had 4 attempts at my car. I have given up now.
2004 XR6 Mercury Silver |
#49 | ||
I should open a business, I reckon I'd make enough money adjusting handbrakes all day. LIke I've said before, these handbrakes CAN be fixed, theres just a range of reasons as to why they are not holding, and it's very difficult to to get it right thr first time. In a time concious work place, often things can be overlooked. If you're getting Ford to do your handbrake, make it clear from the very start that you want your handbrake fixed PROPERLY. Just be preparied to pay, as it could mean you'll need hub machinging, new handbrake shoes, new cables and all the labour associated with it. This is more likely if your car is a pre 04 BA that has had problems in the past.
#50 | |||
Life's a Gas
A handbrake should not be designed so that it's "difficult to get right the first time". FFS, it's only a handbrake! An owner of a 4 year old car should not have to consider paying for "hub machining, new handbrake shoes, new cables and all the labour associated with it". FFS, it's only a handbrake!. This problem should have been picked up in pre production AU testing. Having missed that, Ford should have fixed it with the change over to AU2, when they sorted some of the other brake stuff ups. There is absolutely no excuse for it still being a problem from BA onwards. It is a shocking reflection on Ford's engineering skills and quality control, and would have been so easy to rectify. FFS, it's only a handbrake!. |
#51 | ||
FGII XR6, Focus Sport, XR
It's coz there are so many damn engineers out there and so many middle management idiots that need to be fired, and keep trying to justify there job title.
If Ford done a good clean out of all the engineers and middle management types, a lot more would get done quicker in stead of having the same meeting everyday where you come away with nothing and don't move any further! We'll see how the FG pulls up hey? It's a different setup that hopefully will work and stop this line of crap handbrakes!
Living Ford dreams
2011 Purple FGII XR6 2016 LZ Focus Sport BA XR8 Build Thread (SOLD) 1966 XR Falcon Build Thread |
#52 | ||
As was said before, its the mechanics who dont adjust them correctly and rectify as necessary, either dont know how, or take the lazy way.
#53 | ||
^^^^^^Agree. I adjust mine properly and don't just do it by the cable nut. Haven't had any probs with my handbrake at all. And I work at Ford!! Believe it or not
Living Ford dreams
#54 | ||
Tschhh, tschhh, tschhh - there goes another BA past me down the road. You can hear most of the things before you see them. It seems that you either get one that works, or one that doesn't. Our BA one never really worked from day one - hence two bits of timber in the boot for steep hills and the boat ramp. Just what you would expect from a $40K car??? Never pulled it up over tight, never did handbrakies, always, always used the park brake (or my car would be somewhere else when I returned). Ford never mentioned anything about cost though when it was returned each time though so not sure if I was charged or not.
My NC Fairlane underdash job is fantastic though. My two EF's weren't as good as the NC, but still not as bad as the BA. Some AU work fleet cars had the issue too. No other cars I have owned have had the problem though, even a cheap new Hyundai. The Tschhh's seem to come from some Commo's and Magna's as well. Who is the supplier?
93 NC2 Fairlane Ghia Sportsman. Standard Tickford 162kw engine and touring suspension, factory LTD trim option plus EF Ghia wheels. Other rides: Range Rover Sport, Mini Cooper Chilli Cabrio |
#55 | ||
I had a problem with an AU handbrake, mechanic said the ford AU on are easly damaged if driven with them partly on as they are a mini shoe that operates on the inside of the bell part of a disk rota, only way to fix them is to re-line the hand brake shoe if they are left on when moving, he also said they can be damaged if pulled on suddenly with the vehicle rolling backwards.
#56 | |||
Regular Schmuck
#57 | ||
Snake Oil
Only my thoughts....2 BF's (the current vehicles) 3 BA's 2 AU's
No handbrake issues that I can recall but have changed Pads a bit earlier than in previous models but as cost time is SFA no bother Cheers
Snake 2015 Mercedes C180 Coupe White/Black 2011 FG GS Ute manual #246 White/Black 2010 Chrysler Sebring limited hardtop Silver/grey 2003 UX Explorer V8 White/grey 2008 Suzuki Bandit GSF 1250 Black 2016 Victory Cross Country Tour Black 2011 Glastron GT 185 (USA made bowrider)White/Black 1988 Komatsu FG10 Forklift FPV & XR Owners Club of Victoria #975 Ullysees Member #18,554 |
#58 | ||
hawkeye
Having worked for a ford dealership from xf - au we were one of the rare workshops that still pulled wheels off to check brakes and adjust every service. The trick is how many guys back the adjustment off in the cabin before adjusting at the wheels? 98% of handbrake adjustment problems I have encountered have been due to people shortcutting ie: adjust in cabin and not wheels or adjust at wheels without backing off in cabin. I think in doing that we had little if not no complaints about EF onwards handbrakes. If done right the handbrakes are great. There may be some out there that would need further investigation, but try that method first.
#59 | ||
I had an EF 95 MODEL i bought it near new 1998 with 33k on it. Always used the handbrake when parking was in schmik condition with 230k in 2016 when I sold it. Adjusted it once.
#60 | ||
2003 BA Falcon XT
Nice dig!
I believe a lot is the user. I've had mine adjusted once in 10 years. Also when I stop, I place the car in natural, take my for of the brake, apply hand brake, then put into "P". Side that awful "clunk" sound when you move from "P". I hold the button down most of the time when I apply the hand brake as well. 7 clicks and she's on firm. I think people are just too rough. You're applying a hand brake. Not trying to tighten up truck wheel nuts!
2003 BA Ford Falcon XT IMPCO LPG Vapour Injection. DETAILING Meguiar's NXT Car Wash Collonite #845 Insulator Wax Bowden's Own Happy Ending & Fully Slick Chemtech CT-18 Truck Wash (Wheels & Chassis) Bowden's Own Wheely Clean & Tyre Sheen Bowden's Own Three Way Paint Decontamination Spray OILS AND FILTERS Nulon Full Synthetic 10w-40 Nulon Long Life Coolant Ryco Oil & Air Filters My Instagram Account: @ba_falcon2003
