19-03-2008, 12:32 AM | #31 | ||
Jim
I run NGK XR6 plugs gapped to .8mm on my duel fuel AU. Mines a Xcab and had the stepper motor issue (disconnected when I got it) but it was the O2 sensor that was shagged, got a second handy from a wrecker for $20 but have now replaced it with a new one (so I know its good). Run Spiral core 9mm leads also. Runs friggin great, never misses a beat. got 98.4rwkw on the dyno on LPG when it was stock last year.
even squeels of the line too!!!! mines a tickford factory gas setup so has the ECU with the lpg maps. oh just had another thought...... check the pcv valve as the tend to stuff up and drop the end off sucking in vacuum all the time. must get the grey AU one as they have a smaller hole (stops sucking in oil)
The Daily. White 2017 ZG Escape TDCI AWD Wagon The Wifes. Grey 2015 MD Mondeo TCDI Hatch The Old Daily.......2003 Octane BA Taxi Pak Egas Falcon Build Thread |
19-03-2008, 11:15 AM | #32 | |||
Sales Representative
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! |
24-03-2008, 01:55 PM | #33 | ||
Well i recrimped the terminal yesterday... and surprise surprise... something new is wrong...
Car started with about 218DTE, by the time i got it backed out and up the driveway, it was 186DTE... there was also the fans running on cold and with the A/C turned off... yet i was getting refridgerated air on my legs with the A/C off and using my face vents only... plus there is a MASSIVE flat spot... i was told it would be minor!... i had to switch it back to ULP just to drive to my sisters for lunch... any suggestions? new O2 sensor should be here soon...
24-03-2008, 02:11 PM | #34 | |||
Jim
check the aircon is actually switched off.. I know the switches stuff up all the time on AU's and lock the aircon on.... easy enough to check by lifting the bonnet and checking next time it happens. at what rpm is the flat spot occuring???
24-03-2008, 02:13 PM | #35 | ||
Jim
just had a thought, was the flat spot there when the car was cold??? not warmed up???
also check the pcv valve as they tend to crap themselves and fall apart sucking in vacuum all the time and would really screw up mixtures from idle up
The Daily. White 2017 ZG Escape TDCI AWD Wagon The Wifes. Grey 2015 MD Mondeo TCDI Hatch The Old Daily.......2003 Octane BA Taxi Pak Egas Falcon Build Thread Last edited by AU Falcon 99; 24-03-2008 at 02:19 PM. |
24-03-2008, 03:01 PM | #36 | ||
Ok... might have to get a PCV now... just in case... havent tested it when warm yet... this freaked me out to much... lol
25-03-2008, 10:18 AM | #37 | ||
Jim
another thought.....changed the thermostat recently???? they modify them so they flow for the LPG convertor. on the 2 stage thermostats must drill a hole thru it (top and bottom sections), other wise you convertor freezes due to no flow.... might idle ok but forget about accelerating. easy enough to check, just run your engine at 2500 rpm and watch your convertor freeze up. (turn white)
25-03-2008, 12:09 PM | #38 | |||
25-03-2008, 02:21 PM | #39 | ||
I don't want to worry you too much, but my flat spot turned out to be a totally rooted cooling system. All new radiator, overflow tank, and every single water carrying hose has now been replaced, and car runs really well.
25-03-2008, 02:37 PM | #40 | ||
Radiator and many hoses have already been either checked and/or replaced.. havent done water pump yet though... but right now i just dont give 2 hoots... look at my latest post in my build thread to see what i mean...
25-03-2008, 10:58 PM | #41 | ||
Jim
just read you build up sheet from start to finish.......
I was dumbfounded...... As you are aware I have an Xcab I bought in melbourne $1700 on ebay and has been pretty dam reliable (20k so far) 821k on the clock and still going. mine was originally a 6 seater as well (foot brake is a dead givaway) but now has a fairmont interior. pity you bought such a dodgy car but there is dodgy people out there. I will only by Ex Vic cabs for that reason. Cos they are yellow they cant be dodgied unless they paint them. And I wont buy it full stop. only easy way out if you have mates in SA bring it here and and sell it. wont need a full inspection they just check ID numbers and you can rego it here. easy as
26-03-2008, 02:47 PM | #42 | ||
Any other ideas for the DUAL fuel issue i have? :P
26-03-2008, 04:28 PM | #43 | ||
Jim
seem like you have just about changed everything... does it only happen on gas or is it both???
just about got me at wits end and its not even my car!!!!
26-03-2008, 04:46 PM | #44 | |||
06-04-2008, 05:16 PM | #45 | ||
Need to revive this thread... as i need suggestions on how to clean the mixer ring properly... i have a can of CRC carby and throttle body cleaner ready to start spraying... I need some help here guys...
Also... heres the comparison pics of the Oxygen sensors... New Vs Old.
06-04-2008, 06:16 PM | #46 | ||
never mind people... i went ahead and did it anyway... lol... its actually a touch more throttle responsive on ULP... will try it tomorrow just on LPG to see what happens...
06-04-2008, 11:47 PM | #47 | ||
Jim
how did you go with the new sensor and the clean up???
I cleaned my mixer ring then I polished & waxed it, hopefully that might stop some of the crap sticking to it, will find out next time I clean it
07-04-2008, 08:29 AM | #48 | ||
Drove it this morning... got 90% to work before it stalled and wouldnt start... and of course... it happened entering the highway... not happy...
07-04-2008, 08:43 PM | #49 | ||
Can anyone help me?
07-04-2008, 09:08 PM | #50 | ||
Hoon On The Rise
Check the converter, it could have crap built up in it.
Recently saw a ba that was an absolute dog on lpg, overhauled the converter and cleaned it all out and serviced it, car ran like new. Try finding a dedicated lpg specialist and ask him to quote on overhauling the converter. Cheers
Stomp 'n' Steer FGX-XR8 Manual, BFII E-Gas, '11 GSXR 1000 - Love 'em!
FPV Tickford Club of NSW - www.fpvclub.com |
07-04-2008, 09:10 PM | #51 | ||
The convertor was replaced just before christmas and has hardly been used due to issue's... but i spose, crap can still build up in there... :(
It seems to run fine, until is stalls... and thats the main issue i'm trying to get right... Got just under 2 weeks to get it sorted, as i need it to take to Geelong... :(
07-04-2008, 09:13 PM | #52 | ||
the converter isn't freezing up is it? can you start it after a few minutes or not at all?
07-04-2008, 09:13 PM | #53 | ||
Hoon On The Rise
How old is the coil pack? When it stalls, is it back firing?
07-04-2008, 09:22 PM | #54 | ||
It has back fired once or twice whilst trying to get it re-started after stalling... and on sunday when it was full of carby cleaner :P
No idea about the coil packs... leads are less than 10,000kms and are 9.0mm Eagles... plugs same age and are NGK gapped to suit LPG... Convertor doesnt seem to be freezing... as i drove it cold most the way to work on LPG (started on LPG too..)
07-04-2008, 09:46 PM | #55 | ||
how far is work from your house? it could be a few different things causing it, how long does it normally take to restart or does it vary?
07-04-2008, 09:58 PM | #56 | ||||
07-04-2008, 10:46 PM | #57 | ||
I cant figure out my car...
Reset ECU (disconnected battery for an hour)... reconnected and test drove... nearly half hour later and back at home... didnt stall once... i even fanged it trying to make it stall... small dead spot, and a slight studder once... but not stall... even took it lap around the Mountain and nothing... Want to change my thermostat too... what is the suggested one for dual fuel? BTW... everyone should atleast drive the track the opposite way around and at night atleast once... it is such a strange feeling, and the view is awesome!
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! Last edited by BLUEPRINT; 07-04-2008 at 10:53 PM. |
08-04-2008, 12:32 AM | #58 | ||
Jim
Just looking at your under bonnet pic..... the stepper motor is pretty close to the exhaust and the hose looks pretty tight to the mixer... wonder if it is getting heat effected.
I would try another stepper motor and lengthen that hose another 6 inches so the stepper motor leans away from the exhaust. just had to replace mine as it was tripping out everytime I floored it. it would kinda drop power and had to flutter the accelerator to get power back (bout 5 sec) but put another one I found from a car I stripped and it works fine.
08-04-2008, 08:32 AM | #59 | |||
Car stalled again this morning... at the same highway intersection... :
08-04-2008, 11:51 AM | #60 | ||
Jim
at least its being consistant........
