03-11-2006, 02:18 AM | #31 | ||
BrwnBstd
who cares about the shocks, just slow down yer gif so we can all have a decent look!!
03-11-2006, 02:57 AM | #32 | ||
I have the same prob with custom SL's in mine.
Hay OED666 How many counter weight's are saposed to be on an ED tailshaft n e way's |
03-11-2006, 11:00 AM | #33 | |||
Powered by Rollin Motorsport Turbo Barra ED 4L
03-11-2006, 11:03 AM | #34 | ||
Hmmm.... they seem to go to the 'magical land of missing weights'.
Similar to 'the magical land of missing left socks' 2 Piece shaft looks awesome. was it custom or used from another vehicle?
PX3 Ranger - family truckster
BF Fairlong Ghia - boostlounge 11.26 @ 121 |
04-11-2006, 01:18 AM | #35 | ||
whats the advantage of a two peice shaft???
04-11-2006, 01:46 AM | #36 | ||
advantages... doesnt hit the floor anymore, more angle. biggest benefit is with shorter diff gears, there is less likely hood of a tailshaft failure. due to the shaft spinning much faster, the single piece gets out of shape much easier due to the length of the shaft spinning. the shaft length is pretty much in half, so there is buggar all chance of the shaft getting out of shape and failing or falling out (which has happened)
14-01-2007, 10:58 AM | #37 | ||
has any one tried the puttin washers in between the top hat that what i was told to do and might have a go at
14-01-2007, 02:11 PM | #38 | ||
The workshop that did my suspension presented this (cut & shut supports) as a way of lowering the car into the weeds while retaining decent suspension travel, but recommended against it as i wasn't going low enough. I wanted (and got) the tyre to sit slightly in the guard but if i wanted half the tyre buried in guard I would've definitely had to have had the supports extended. The guy who did the work has had them installed in the car he uses for towing (ED Fairmont) for years and hasn't had any issues at all.
And for those who think its dodgey, keep in mind that the weld is actually stronger than the metal itself provided the two sections being joined are properly prepared. |
14-01-2007, 07:17 PM | #39 | ||
has any one had a problem with diff hittin chassin when they have done this? and how much should i cut out ect...
14-01-2007, 07:38 PM | #40 | |||
14-01-2007, 08:33 PM | #41 | ||
as far as i am awair it is not legal to cut any suspention parts without an engineers reprort
i could be wrong but thats the way i see it jason
14-01-2007, 08:35 PM | #42 | |||
Oops, I slipped....
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
14-01-2007, 09:23 PM | #43 | |||
14-01-2007, 09:41 PM | #44 | ||
can u put up a pic of how low ya car is mate very keen on this idea instead of doin the washers who cares if its illegal if u need to do this to ya car obvoisly ya car is at a illegal height neways...
15-01-2007, 10:52 AM | #45 | ||
PM me if you want
Nice job, I am getting this proffessionaly done as well for my EA SLS to give it better travel and stiffen it up a bit, I have set to low height at the moment and it works, but not as well as i would like.
16-01-2007, 02:07 AM | #46 | |||
16-01-2007, 08:30 AM | #47 | ||
where abouts should i cut the top hat on both of them to make one?
