Old 03-09-2024, 07:02 PM   #2101
outbackman59
Outbackman59
Sorry if this is in wrong area,
I am asking gt legend if
Air cooling module ((resistor)number
Ar29-8c609-ab
Is still available and how much are they worth
Is for a diesel territtory
Regards phil
outbackman59 is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2024, 10:37 PM   #2102
GTLEGEND
Ar29-8c609-ab
Regards phil
Hi Phil,
The part number you supplied is actually an engineering number, this corresponds to service part AR2Z8C609AB.
They are obsolete, but may be still some around. Let me check and get back to you.
Old 04-09-2024, 09:56 AM   #2103
GTLEGEND
Ar29-8c609-ab
Regards phil
Hey Phil,
Managed to track one down, did not realise they were so expensive @$770 plus postage/freight if required.
Let me know if you would like me to organise for you.
GT
Old 04-09-2024, 11:26 AM   #2104
outbackman59
Outbackman59
Hi gt,
Very much appreciate the effort but once the son gets over his heart attack he will say dont worry about it ,so tu very much
Rregards phil
Old 04-09-2024, 01:19 PM   #2105
Interestingly these https://www.ebay.com.au/itm/23560604...Bk9SR46xlK23ZA look extremely similar to these https://www.ebay.com.au/itm/37558034...Bk9SR46xlK23ZA and https://www.ebay.com/itm/37529034831...Bk9SR7KF3q23ZA Might be worth trying.
aussiblue is online now   Reply With Quote Multi-Quote with this Post
Old 04-09-2024, 04:33 PM   #2106
outbackman59
Outbackman59
Yeah i seen them to blue son been told so will see what he does
And just a big shout out and thank to all the help that is given on this forum tu all
Old 04-09-2024, 06:46 PM   #2107
swamp
hi
GT,
Mazda BT50 UN
single/regular cab 3.0lt diesel 4x4 5spd man
del date jun 011
build date 1/11
Vin MM00UNY0E400891415
Diesel injector price and availability please
Bosch no. 0445110249 ?
Bosch unit comes with copper washer ,,genuine ?
Warranty length ? Seems to vary alot
swamp is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2024, 08:08 PM   #2108
GTLEGEND
Originally Posted by swamp View Post
hi
GT,
Mazda BT50 UN
del date jun 011
build date 1/11
Hey mate,
Will have to do a bit of research on this as I really have Ford info.
If they are the same as Mazda, Ford injectors are around $1000 each and washers are seperate at around $4.20 each.
I dont have bosch equivalent numbers or bosch numbers at all.
Warranty for manufacturing defect is 12 month/20K kms.
Let me check with a Mazda contact and get back to you.
GT
Old 04-09-2024, 08:36 PM   #2109
XR Martin
XR Martin's Avatar
GT, can you still get the child anchor hook point for an FGX?
If so how much.
2004 BA wagon RTV project.
XR Martin is online now   Reply With Quote Multi-Quote with this Post
Old 04-09-2024, 10:16 PM   #2110
GTLEGEND
If so how much.
Hi mate,
Yes $30 plus postage.
Old 08-09-2024, 05:48 PM   #2111
PHANTMXR6
It's not an FG MKI.......
PHANTMXR6's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Willing to help out with useful advice in the technical areas of the forum.
Smile Re: Genuine Ford Parts
Hey mate.
Chasing a pair of windscreen washer jets for an FG.
Express posted to 0830 if available.
Thanks.
06/08 Manual FG XR6T. Not an FG1 or MKI, an FG...
Want to know how to do an A Service for an FG XR6T?
Look in this http://fordforums.com.au/showthread.php?t=11339404
Thinking of oil sampling your engine?
Have a look at this trend http://fordforums.com.au/showthread....ght=oil+sample
PHANTMXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2024, 05:49 PM   #2112
GTLEGEND
Originally Posted by PHANTMXR6 View Post
Hey mate.
Thanks.
Long obsolete unfortunately..
Old 08-09-2024, 05:50 PM   #2113
GTLEGEND
hi
GT,
Mazda BT50 UN
del date jun 011
build date 1/11
Checked and confirmed Mazda are the same but dearer at $1300 per injector, washer seperate also.
Old 20-09-2024, 12:54 AM   #2114
ArchonXR6
Looking for a headlight for my 2012 MkII XR6. Part number is BR2Z13006BA. Can you help with that one? Looked online but everyone seems to be sold out.
ArchonXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2024, 12:26 PM   #2115
GTLEGEND
Sorry but all gone...
Old Today, 12:52 AM   #2116
Mosquito
Mosquito's Avatar
Hi GT
Looking at taking the challenge to do the REAR suspension bushes in my Mar/2009 SY1 Territory RWD. (BIG job I know)
Can you help me with part numbers and pricing on these please: and if they are sold as each or pairs.
- Upper Control Arm - Inner Bush
- Upper Control Arm - Outer Bush/cross axis ball joint
- Lower Control Arm (also called toe arm?) - Inner Bush
- Lower Control Arm (also called toe arm?) - Outer Bush/cross axis ball joint
- The other lower control arm that carries spring - Inner bush
- The other lower control arm that carries spring - Outer bush/cross axis ball joint
- Control blade bushes
- The 3 diff bushes (do they come as a set, or each? ... and from what i can tell the outer two bushes are the same on all models, but the middle one seems to have a few different ones?
I can send you my vin if that helps.
Appreciate your help.
2007 BFII XT Wagon, 2009 SY Territory TX (Just Bought) & 1997 NL Fairlaine Ghia (Currently Parked with Blown Motor)
Mosquito is offline   Reply With Quote Multi-Quote with this Post
Old Today, 01:10 AM   #2117
GTLEGEND
Originally Posted by Mosquito View Post
Hi GT
Looking at taking the challenge to do the rear suspension bushes in my Mar/2009 SY1 Territory RWD.
the other lower control arm that carries spring - Inner bush
the other lower control arm that carries spring - Outer bush/cross axis ball joint
control blade bush
the 3 diff bushes (do they come as a set, or each? ... and from what i can tell the outer two bushes are the same on all models, but the middle one theres a few different ones?
Hi mate,
So, I think the easiest way to avoid confusion if for you to write the part numbers from below images of the suspension you want and we can go from there. Let you know if we need a VIN later pending on what we come up with.
Cheers,
GT
Old Today, 01:38 AM   #2118
Mosquito
Mosquito's Avatar
Mate! So quick! I went back to edit the post and by the time I'd finished you'd already replied!
Here's the numbers off your diagrams...
Upper Control Arm Bushes
5B639A
5A659A
Lower Control Arm (Toe Arm) Bushes
5A659B
5B659B
Other Lower Control Arm Bushes
5B638
There appears to be a bush missing on the diagram - goes on the bolt/nut between 5R649A & 5N649A - I'll see if i can attach a pic from the workshop manual.
Control Blade Bush
5A638
Diff Bushes
4B424
4B425 (this is the one I think can be different across models)
Thanks!
Old Today, 08:21 AM   #2119
GTLEGEND
5B639A
5A659A
5A659B
5B659B
5B638
Control Blade Bush
5A638
Diff Bushes
4B424
Thanks!
You got me just as I was online and about to head off to bed. Will look at this sometime during the day and get back to you. Pic below of the bush your referring to.
Old Today, 08:26 AM   #2120
GTLEGEND
For Quickie
Old Today, 09:53 AM   #2121
GTLEGEND
5B639A SX5B639A $100 EACH
5A659A 8R2Z5B719AB $125 EACH
5A659B SX5B639B $90 EACH
5B659B 8R2Z5B719AB $125 each
5B638 SX5B638A $38 EACH
There appears to be a bush missing on the diagram - goes on the bolt/nut between 5R649A & 5N649A - I'll see if i can attach a pic from the workshop manual. 5A976 BAF5A659A $100 EACH
Control Blade Bush
5A638 SY5A638A $170 EACH
Diff Bushes
4B424 BAF4B424A $60 EACH
4B425 (this is the one I think can be different across models) Correct different based on month/year and if AWD or RWD BAF4B425SF $110 EACH
Thanks!
Part numbers and prices above as requested, all individual, no kits as such. So if you need more than one you need to multiply by how many you need.
Old Today, 11:40 AM   #2122
Mosquito
Mosquito's Avatar
Thankyou so much...
At $1800 bucks, I'll need to rethink if I really need/want to do the job...lol
I'll get under and thouroughly inspect everying again.
I really appreciate your time! You are a blessing to the community!
