Old 24-06-2024, 10:03 PM   #3151
Default Re: Car Detailing - What products are your go to?
Originally Posted by FASTXR View Post
Hey DFB, what would you rate higher out of NV Nova EVO and CarPro Cquartz UK 3.0 (in terms of application and longevity)?
I haven't used either, so I would need fordomatic to chime in here on this one as he's used both. I've heard arguments for and against both of those coatings.
PX MK II Ranger
FG XR6
FG X XR8
Mustang GT
Old 24-06-2024, 10:24 PM   #3152
Top_Ghia
Technical Contributor: For members who share their technical expertise. - Issue reason: has been consistently providing good technical advice etc. to AFF members, by having the vast technical knowledge he has with the various Ford products. A valuable AFF member
You got me. NV evo, nv wheel, nv nova jet, nv boost V2, nv clarity.
I’m on the fence about glass and interior coatings. Someone push me off.
Top_Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2024, 10:29 PM   #3153
Don't coat interior surfaces, especially leather.
Glass is worth doing, especially if you do a lot of night time driving (bugs). I don't do a full coating on glass though, preferring to stick with the light duty products such as Gyeon Quick View.
In case you haven't ordered yet skip the NV Clarity prep spray, its not very good. NV Wheel is ok, but ADS Wheel Coating is the best available.
PX MK II Ranger
FG XR6
FG X XR8
Mustang GT
Old 25-06-2024, 10:26 AM   #3154
T3rminator
T3rminator's Avatar
Found a tub of CT18 in the garage, not sure how long it had been there, read some good reviews so decided to give it a go. Results came out pretty good, a nice clean gloss look after a wash. Works, somewhat, on the crappy Gerni snow cannon too!
Don't really hear much about the CT18, but seems to be great value for $.
Rides (past and present)
Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual
Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m)
AFF motto - If contrary views trigger, please use ignore button.
T3rminator is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2024, 12:39 PM   #3155
fordomatic
fordomatic's Avatar
Nova Evo everyday of the week. Easier application, less maintenance, better gloss, lasts double the time.
6 users like this post:
Old 25-06-2024, 09:04 PM   #3156
bfets
Sold. I ordered a bottle to play with
bfets is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2024, 11:27 AM   #3157
stannoplan
stannoplan's Avatar
Chiming in late, have done several cars with both recently.
CQuartz UK3.0 is super easy to apply, better than some sprays to wipe off. I usually do 3 coats as its so simple, coat a panel, wipe off straight away or even half hour later, high spots just go over again.
On a maintained vehicle still beading like mad over 1year later, clogged up on a rarely washed outside car. Beads similar to the better spray coatings, impressed. Easily 1 year, seems likely to do 2.
Fordomatic recommended the Evo, now on my second bottle, I got 3 cars out of the first. Its noticeably thicker and the applicator is rubbish so I swapped to the Carpro one. Buff is also more work but not crazy hard, but the flashing/rainbow isnt as easy to spot either and more of a wait time, i generally did 2-3 panels before coming back to buff. However its great as only 1 coat is required and once you understand it, its easy to apply. Beading slightly behind the Carpro but not much, I tend to use toppers anyways so no drama.
The slickness isn't great (or terrible) for either but the Evo has the edge in gloss. Where the Evo excels is that it always looks so glossy and clean even if its dirty.
In the end I chose the Evo when I was out of both bottles, for $95 its a steal, $32 per car for a 3 year coating.
ex owner of: Mk1 Escort, Mk1 Capri, BA Falcon but Fordless at present and punished by having 3 black cars and 2 teenage daughters.
stannoplan is offline   Reply With Quote Multi-Quote with this Post
Old Yesterday, 08:51 PM   #3158
Having ran the updated wide-mouth MTM foam cannon for a few months now, there is only one problem I have encountered, something I actually discovered very quickly.
I use a foam cannon with either soap or Brake Buster for wheel cleaning. I'm also seated when cleaning wheels, the stool and bucket on wheels so I can shuffle from wheel to wheel without getting up. This will sound like a first world problem, but with a bucket full of water and tools, there was nowhere to put the foam cannon when not in use. That was until Maxshine and MTM started offering a bracket to hang the foam cannon from the bucket. This of course was the perfect solution.
https://detailingshed.com.au/product...ee486336&_ss=r
https://detailingshed.com.au/product...e8721563&_ss=r
Having searched for something like that for ages, I even considered having one made for me, you can imagine my disappointment when I discovered the updated MTM bottle and cap arrangement is not compatible with either the Maxshine or MTM bracket.
I can't see how an updated version would work considering the lack of clearance between the foam cannon body and the black adaptor cap. So, I've been back to fumbling from wheel to wheel managing the stool, the pressure washer gun/hose, bucket and foam cannon.
My latest idea involves a foam cannon wall bracket that I spotted online.
https://www.amazon.com/dp/B0CWP2CTJ4...tem_image?th=1
These work different to regular quick connect fittings in that they a simple push to engage-release rather than pulling down the outer sleeve. I can't link a video, but the Amazon listing has a video showing it in action. These are actually very slick, way more precise than the budget price would indicate.
The plan is to mount the bracket to my detailing stool, which will have the foam cannon resting between my legs for quick and easy retravel. I think this should work, but like anything, it will be a case of trial and error.
PX MK II Ranger
FG XR6
FG X XR8
Mustang GT
