It may be a silly question but do any of the fuel additive injector cleaners actually work?? Short of removing the injectors what is the best way to clean the system?? I have an AU XR8 220
Cheers. |
My mechanic uses a Carbon Clean system.
It has a wand that fits in just before the thottle body and cleans that. It also has another process that hooks in to the fuel lines that cleans the lines, the fuel rail and the back end of the injectors for a short period. The car is then started which uses the cleaning fluid to clean the rest of the injector and combustion chamber. It's not the Wynns carbon clean system (they use a little bottle and something else), although it does a similiar thing to what the wynns one does this is much better and much more complete. I did this to my car at only 30 000 kms and it made a hell of a difference, much smoother on/off throttle and revs a little cleaner. Makes me think... I'm due to do it again! I think the addatives do work a bit, but like everything they really need regular usage to get the best results.
2002 TE50 Build No 165 |
An NRMA guy put me onto Holdens version "topend cleaner" which use to work beaut in my old VR and i still give it a run every now and then in the new car.
So i'd give that a go and see, i reckon it made a difference. |
where in sydney could i get this "carbon clean System" done as my XR6 has 137,000km on it and its never been done. Latly its been starting to idle rough,still goes hard , but just doenst idle like it did when i bought it. Have changed the plugs and put K&N filter and have cleaned the TB butterfly and surroundings numerous times... sounds like this might fix it as when i had my vs i pulled apart the whole TB and inlet manifold and cleaned it all with carby cleaner and it made it run loads cleaner and also soo much more responsive...
thanks.
10' FG XT in Edge (Company Car) 6Spd ZF!! ![]() 06' Mazda SP23 5spd auto Luxury pack |
Ex EL Falcon
I've seen the carbon clean system described above. In fact the company I used to work for had one in their workshop. The guy who ran the place swore by it but I do wonder - what do manufacturers think of these things? Does it have any side effects? If it cleans the carbon out, what does it do to oil also inside the cylinder?
Our Lady of Blessed Acceleration, don't fail us now! |
As far as I'm aware it doesn't harm anything and doesn't void any warranty's. I'll do some research on the one my mechanic uses. It also is part of a petrol and the chemical mix that pretty much getsburnt up during combustion. I can't really see any substantial amount getting in to the oil or oil system. It just runs in the fuel and air side of things.
I do know that some AU's actually have a sticker on the throttle body that does state not to use any form of throttle body cleaner. But I don't own an AU so I can't vouch for all of them, this one was on a Series 2 200kw AU.
#7 | ||||
Ex EL Falcon
Fordless
Of the add yourself ones I find my car needs one every now & again or it can ping a bit. The only 2 that have worked for me is the NF one & the Nulon the rest haven't made a difference.
for the in-tank additive i use redline
for the carbon cleaner i use a brand called threebond, its the same stuff in the subaru upper engine cleaner just comes in a different can. and for 1/3rd of the price ![]() |
I was told once by mate who is a fuel injection specialist that using injector cleaner is the worse thing for your injectors. He said something along the lines of it freeing up other particles in your filter. Allowing small bits crap to damage the tiny needle in your injector and the way it seats. So yeah dont know how true it is but thats what he reckons. He also said thats why he sells it because he reckons they'll be back someday.
#11 | |||
#12 | ||
yrs ago my mech at service put injector cleaner in my au xr6 at service time. it didnt effect the performance
#13 | ||||
He says it's all sh#t and does more harm than good
Fgx xr8 winter white manual, gone but not forgotten 22 mitsubishi outlander XLS PHEV Au11 fairmont Ghia ported gt40p heads ,comp springs and locks Xe 264 cam,custom intake,pacemaker tri y headers 524nm torque 19 Triton GSXR manual |
#14 | |||
Cabover nut
Old truckie trick is to use a little ATF in the diesel tank occasional and regularly change out fuel filters.
#15 | |||
Experienced Member
Funny how you say that, I heard both sides of this argument from veteran mechanics. What I do know especially from the diesel side of engines fuel additive is highly recommended from all diesel mechanics & service centres, I certainly use it for good reason. Cheers. |
#17 | |||
#18 | |||
Experienced Member
Here we have the big question, how do you know the condition of fuel tanks? I suppose you will know from your local regular servos you use but for others??? I will play it on the safe side, cheap insurance. |
#19 | ||
Yeah I was meaning more low use transport company site tanks , some small privately owned servos margins are small the first thing they stop is the tank and pump maintenance.....water testing is a thing of the past
