09-01-2023, 02:22 PM | #1 | ||
I know it is nearly 5 years old, but I am not sure if many have seen it
Flat 4cylinder, 1000bhp, about twice that in torque, two massive turbos, a supercharger, no valves, no cylinder heads, and it's a diesel. It's got 8 pistons. And two crankshafts. Despite being a 4cylinder. Yes, it's an opposed piston engine, ie two pistons per cylinder facing each other. This is a new Cummins engine designed for military use, and it's pretty badass. It's 14.3ltr, so 1000bhp doesn't sound a lot for that capacity, but for a super low revving diesel that's intended to work for literally ever at full load, that's a lot- Most OEM 14ltr diesels make under 600bhp. And thanks to only 4cyl and no cylinder heads, it's relatively small too. It's a 2stroke engine, so no valves, and the inlet and exhaust ports are opened by the pistons literally uncovering the holes on the sides of the cylinder walls- Much like ports on a rotary engine for anyone not used to 2stroke engines. The turbos are twin Holset HE500 VGT turbos, which are 1000bhp+ capable units if pushed to their limits- Beasts. The mix of 2stroke, supercharged, twin turbo, flat 4, and opposed piston, means this thing should sound pretty insane too. Rather than me explain it all here, watch the video as the last parts are animations that shows exactly how the cranks are geared together and how the inlet and exhaust port setup works. https://youtu.be/OfBB6uNkYKM |
4 users like this post: |
09-01-2023, 02:25 PM | #2 | |||
Cabover nut
3 users like this post: |
09-01-2023, 05:07 PM | #3 | ||
Very impressive indeed.
Alot different to previous NT/N14 and Signature 600 Cummins! |
09-01-2023, 05:47 PM | #4 | ||
There's a reason it's for military use - no emissions regulations.
09-01-2023, 08:27 PM | #5 | ||
09-01-2023, 09:43 PM | #6 | |||
It's an impressive engine for off-road use.
10-01-2023, 09:54 AM | #7 | ||
[Modern day Commer knocker motor lol
Fgx xr8 winter white manual, gone but not forgotten 22 mitsubishi outlander XLS PHEV Au11 fairmont Ghia ported gt40p heads ,comp springs and locks Xe 264 cam,custom intake,pacemaker tri y headers 524nm torque 19 Triton GSXR manual |
10-01-2023, 10:22 AM | #8 | ||
10-01-2023, 06:05 PM | #9 | ||
A lot of the yank military runs on a common jet fuel, not diesel
10-01-2023, 06:15 PM | #10 | ||
10-01-2023, 07:24 PM | #11 | ||
11-01-2023, 04:20 PM | #12 | ||
VFII SS UTE
i don't think it matters trev, it's still oil.
slightly less energy per liter.
I don't often hear the sound of a screaming LSX. But when I do, So do the neighbours.. GO SOUTHS
11-01-2023, 04:27 PM | #13 | ||
VFII SS UTE
Napier Deltic train engine.
https://en.wikipedia.org/wiki/Napier_Deltic https://www.youtube.com/watch?v=jPUy9a3xi4w
11-01-2023, 04:28 PM | #14 | ||
Peter Car
11-01-2023, 04:42 PM | #15 | |||
Cabover nut
11-01-2023, 07:39 PM | #16 | ||
12-01-2023, 12:58 PM | #18 | ||
Peter Car
12-01-2023, 02:58 PM | #19 | |||
Cabover nut
Quoted from trucksplanet site......."Gas turbine powered Kenworth had crossed the United States from north to south, and then worked briefly in commercial traffic plying on the western coast, between Seattle and Los Angeles, the tests, alas, failed. First of all, the trip lasted five or six hours longer than with conventional diesel engine: a gas turbine powered truck was accelerated slowly, heavily smoked, while squeezing the clutch pedal was a real torture (despite the fact that even the conventional old "Americans" have vere tight clutch). But the main problem was that the consumption of turbine was equaled a mile per gallon, or 235 l/100 km!" Makes the Cummins look like a fuel pincher.
12-01-2023, 03:24 PM | #20 | |||
Peter Car
